Go to Post There is no exit strategy in FIRST - RoboMom [more]
Unread 07-04-2016, 17:02
first_newbie first_newbie is offline
FRC #1718
first_newbie is a jewel in the roughfirst_newbie is a jewel in the roughfirst_newbie is a jewel in the rough
Pocketing
How can one pocket in a triangular or X fashion using Autodesk inventor.
Unread 07-04-2016, 17:03
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is offline
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
Re: Pocketing
I really like this tutorial on pocketing: http://imgur.com/a/Qeuu7
It's written for Solidworks, but my students have been able to follow along in Inventor just fine.
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - San Diego Regional / Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
Unread 07-04-2016, 17:14
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is online now
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
Re: Pocketing
My only caution would be that pocketing/cheesing using patterned sketches can be difficult to edit if changes need to be made after the fact.
Unread 07-04-2016, 17:53
FRC #1718
Re: Pocketing
And this would be done through laser cutting? How would CNC or Waterjetting work for this? Is this the same process for box-tubing? Would you be able tp waterjet box tubing?
Unread 07-04-2016, 18:12
Re: Pocketing
CNC Milling, Water Jet Cutting, Laser/Plasma Cutting, CNC routing... all would work for this application. CNC Milling would be the best process IMO for box tubing, while you can cut box tubing on a water jet most often you have to use a piece of sacrificial material inside the tube to prevent the jet from cutting both sides at once. The top side will cut clean without the material inside, but the bottom will not come out as desired.
Last edited by Dave McLaughlin : 07-04-2016 at 18:13. Reason: I accidentally a word.
Unread 07-04-2016, 18:23
Roboshant's Avatar
Roboshant Roboshant is offline
Design Lead 17, Scouting Captain 16
AKA: Dikshant Sharma
FRC #0226
Rookie Year: 2015
Roboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to all
Re: Pocketing
Could wood be used as the sacrificial material?
Unread 07-04-2016, 18:29
Re: Pocketing
Depends on the thickness, but usually yes. We've cut 4x4 box tubing on a water jet using wood as sacrifice. The largest inconveniences end up being cutting the sacrifice to size to occupy the volume inside the tube, and getting the sacrifice out of the tubing as the wood will often swell up from being in water.
cxcad cxcad is offline
FRC #1683 (Techno Titans)
cxcad will become famous soon enoughcxcad will become famous soon enough
Re: Pocketing
For pocketing in general, I like 973 ramp video. Also just a great resource in general
Unread 07-04-2016, 18:31
Re: Pocketing
I agree. They can be found here.
