Go to Post Profesional Gracism - n. the blessing said before Robotics competitions begin. - Cynette [more]
  #41   Spotlight this post!
Unread 07-04-2016, 21:18
Edxu's Avatar
Edxu Edxu is offline
Strategy/Scouting Mentor
AKA: Edwin Xu
FRC #4476 (W.A.F.F.L.E.S Robotics)
Edxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud of
Re: Triple Cyclers or Defense?
Originally Posted by oliviat3357 View Post
What about the teams that place a defense bot in their own courtyard? It gets pretty crowded with four bots, but it allows for two to cycle shoot, and the last to stand it the way of the opposing alliance's defense. It worked well for our elimination matches in East Kentwood (and in some cases, the defense bot could still contribute scoring 3 low goals or so).
I'm pretty sure that you mean opponent's courtyard here, so I'm going to go off that.
IMO, this is lowkey potentially one of the strongest offensive strategies, but it relies of a few things:
1. Incredible coordination between Alliance Partners. I'm pretty sure that with 3 robots in the courtyard, it started to feel cramped for our drivers at Waterloo. Adding a fourth could potentially ruin cycle times as robots struggle to make space for each other while efficiently running cycles.
2. You believe that your 2 scorers are stronger than the opponent's 2 scorers. Not a difficult assessment to make, as hopefully you have scouting data to work off of.
I think that if you're able to secure >12 balls in the opponent's courtyard/side of the field, this strategy will guarantee a win. However, if you are unable to secure those balls, you run the risk of being forced to roll boulders into your opponent's eagerly waiting intake.
2013 FRC World Champions (1477, 1241, 610)
Queens University Computing Class of 2020
2013-2016: Team 610
2017-????: Team 4476
