Go to Post Use sensors to collect data about the surrounding environment, then discard it and drive into walls. - Jared Russell [more]
Unread 08-04-2016, 09:48
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Re: Vision Problems Under Regional Lights[GRIP]
This is what we ended up doing... They kept changing the lighting on us. When they turned the spotlights on, it was too bright.
Unread 08-04-2016, 10:04
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
I mentioned this problem to someone with a differential signalling background and his first suggestion is one I hadn't thought of. He said, why don't you look at the target with the ring light on and then off, and then subtract out the noise?
I can't promise it would work, but it's an intriguing idea...
Unread 08-04-2016, 19:55
derekhohos's Avatar
derekhohos derekhohos is offline
FRC #2338 (Gear It Forward)
derekhohos is an unknown quantity at this point
We also use GRIP to process the image produced by our Axis M1011 camera. In order to filter out the bright lights, we use a negative photographic film (covering the camera lense completely). Depending on how developed the film is, you may have to add multiple layers of negative film.
If you are looking for high goal calibration or auto, consider using infrared - it works really well with GRIP. (Initially I tried using a Microsoft Lifecam HD-3000 with IR, but it did not produce promising results on GRIP. After further research, I found out that the Webcam itself had an infrared filter, thus leading to our team using an Axis camera instead).
