Go to Post Thank you lord I knew there was a reason I got 10 books on autonomous robotics. - Adam Y. [more]
Unread 07-04-2003, 01:09
Patrick Wang Patrick Wang is offline
#0115 (MVRT Alumni)
Patrick Wang has a spectacular aura aboutPatrick Wang has a spectacular aura about
Send a message via AIM to Patrick Wang
OI Brownout
You should know that a sudden shift from full forward to full reverse under load on many transmissions causes a HUGE and sudden current draw. (In Excess of 100 amps for each motor for a brief period of time) This sudden draw is enough to cause the terminal voltage of your battery to drop low enough to reset your controller.
Best advice is to not drive that aggressively. This has been our solution to that problem, we encountered it last year in the tug-of-wars.
Patrick Wang
WRRF
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Visibility of Robot Controller and Reset Button Tracy Rules/Strategy 1 17-02-2003 07:36
Robot reset on OI doesn't work Carl Owenby General Forum 1 07-02-2003 07:23
Controlling a FIRST robot with a Lego RCX Controller? archiver 2001 5 24-06-2002 04:19
