Go to Post You pick the best person for the job whether they are black, white, asian, hispanic, female, or male; NOT so you 'look good' when they publish your team picture in the school paper, but because they can get the job done right, on time, with a passion. - Pavan Dave [more]
Unread 04-04-2003, 19:31
AlbertW's Avatar
AlbertW AlbertW is offline
harker robotics :. 1072
AKA: Aonic
#1072 (Harker Robotics)
AlbertW is on a distinguished road
Send a message via AIM to AlbertW
running the OI off a battery
We need to run the robot on radio while away from the plug. I went out and bought an M-type connecter (the kind that the DC-In port on the OI uses) and soldered it to a 9 volt battery (cause the power adapter SAYS it outputs 9v)
but the problem is, that, when tested with a multimeter, it shows that the power adapter ACTUALLY outputs 12 volts.
will the OI run on 9 volts?
We were the first seeded first-year team at a first-year FIRST regional.
Unread 04-04-2003, 19:35
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Well, from the writing, the power adapter says it outputs 9VDC, 1500 mA. I would assume 9V would work, but I'm very puzzled as to why the multimeter gave you a 12V reading... Try it again; maybe you had something messed up.
Jeff Waegelin
Unread 04-04-2003, 19:37
AlbertW's Avatar
AKA: Aonic
well, it makes sense, considering the OI gets 12v through the tether and the competition port.
though don't know why it says 9 on the adapter.
Unread 04-04-2003, 19:45
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: running the OI off a battery
The OI should run on 9 volts, however I'd be surprised if a 9v battery lasts more than about 10 minutes! You'd be much better off hooking it up to a spare robot battery (it'd be a good idea to put a fuse in the line if you do this though).
The reason the OI power supply seems to put out 12v (I actually measured ours at 14) is that it's an unregulated supply and will output a higher voltage when there's no load connected to it (credit this answer to Al S. as I just asked him the same question last week!).
Unread 07-04-2003, 01:52
AlbertW's Avatar
AKA: Aonic
haha. the 9 volt didn't last very long (about 5 min) and the OI started doing constant resets after a while (PO5...5...3...2...1...1072...PO5...etc)
after discovering that, we made a quick run to radio shack, found a aligator-clip to car-12v-socket adapter, and a car-socket-adaptor to 9volt Mplug adapter (for about 20 bucks total) hooked em up to a 12volt battery, and used that
anyway, thanks for all your help! =)
Unread 07-04-2003, 02:25
Andy A. Andy A. is offline
Getting old
FRC #0095
Why not just power it through a competition port dongle?
All you need then is a 25 pin connector (or a 25 pin cable chopped in half) and a battery.
*shrug* seems cheaper, and you can put in switches for disable and auto mode while you're at it. It's something I've been meaning to do for a while now. I would like to find a better power source, something in between a 9 volt dry cell and a bot battery. I was thinking an old laptop battery, although it is rated at 14.4 volts. I know nothing about the power system of the RC, so I won't try it, yet.
But it would be so cool.
Maybe if I get bored in the pit...
-Andy A.
Unread 07-04-2003, 12:06
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Last year we had a switch on our control board that would switch the power from a surface mouned plug for the wall wart adapter that the OI normaly uses to a bunch of AA batteries we had under the top of the board...very useful when doing demonstrations, or just to drive your robot around to move it from point A to Point B
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 18-04-2003, 10:13
-Andy A.
Comp Pport has a 15 pin connector !
Unread 18-04-2003, 10:30
Crescent (#610) has used a battery pack for several years; a battery holder with AAA cells and a connector that goes in to the power connector used by the 1500 mA Wall Wart IFI supply. I don't know if they use 6 or 8 cells in series.
It seems reasonable that IFI would use a regulator on the power input, so it might not matter. but the power input is a diode away from the tether power supply line.
Practically every Wall Wart gives the rated voltage only if loaded down to the rated current, depending on the resistance of the transformer secondary for this "regulation". I'd design the "9 V" input to handle 12 V at least, and the 7800 Regulator line can handle 18 V max rated.
Unread 18-04-2003, 10:33
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
yes it will run on 9 volts
We have used a power pack to run at many outdoor events with our machine.....we use four 9 volt batteries hooked in parallel which gives us a good amount of run time on the interface.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 18-04-2003, 11:27
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
-Andy A.
Be careful when you do that. Innovation FIRST will void your warantee if you try to power it through the Competition port on your own, and it screws up. From what I can tell you, the OI gets its power from Pin 1. I believe when you power the OI from the Competition port you un-lock more channels than you get with a regular dongle. To check the voltage of the OI you can measure it from Pin 1 to a ground (Pin 8).
Unread 26-04-2003, 12:06
FreeBSDboy FreeBSDboy is offline
FreeBSDboy is an unknown quantity at this point
The wall power supply for the OI (like most brick style plug in power supplies) will not regulate properly with no load. So if you took the voltage reading with a multimeter while you wern't drawing any current off of it, it will read abnormally high. If you were to test it under load, I would bet the voltage would drop to ~9V.
Unread 26-04-2003, 12:54
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Correction to CAMTUNKPA...
We use 3 9 volt batteries hooked in parallel. Yes and when the batts die the controller cuts out.
I have used 12 volt power packs plugged into the operater interface and it does not seem to harm them...
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 26-04-2003, 13:41
ZACH P. ZACH P. is offline
Insert Custom User Title
#0321 (Robolancers)
ZACH P. is on a distinguished road
Send a message via AIM to ZACH P.
i dont have one of the powers supplys on hand, and so i have a question, Which part of the plug is positive and which is negative? i need the info to build one.
thanks
pi is exactly 3
IM me at: zmstr265
Unread 26-04-2003, 14:47
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
We've been using an old (can't hold a charge, etc etc) robot battery to power an equally old OI. It's been working since December, and we only charged it once.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
running bot off car battery? Trashed20 Electrical 25 06-06-2003 12:57
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
