Go to Post I don't think finding a way to defend the center goals is un-Gracious Professionalismistic (wow). - Sachiel7 [more]
Unread 09-04-2016, 21:41
medofbr medofbr is offline
FRC #5404
medofbr is an unknown quantity at this point
Re: Dlink DCS-933L connecting to roboRealm
Using settings in the browser got it to work!
Thanks.
Unread 20-01-2017, 18:47
RoboRealm RoboRealm is offline
FRC #0443
RoboRealm is a jewel in the roughRoboRealm is a jewel in the roughRoboRealm is a jewel in the roughRoboRealm is a jewel in the rough
Ben,
If you get the browser to view the video on the same machine then you know that the network connection is good, so that's a first test to check.
Then have a look at the Axis configuration. In more recent years the camera supports more formats. You need to specify MJPEG as the streaming format.
Finally, the authentication also changed. Try switching authentication off (i.e. don't require a username/password) or switch it to a basic authentication scheme (I think the newer models support more sophisticated authentication.)
Once you have made these two changes to the camera, check that the browser connection still works and then try the Axis module set to 900/920. This is an issue one team had last year and with the above changes seemed to fix the issue. Please post here if that doesn't fix the problem.
Thanks,
STeven.
