delrin gears?
anybody think you could get away with delrin gears in a drivetrain with the drill mtor as the source???? let me know, if it's possible we'd be saving ourselves every headache in the book. thanks.
Anthony Lapp team 221---->now 857 |
It's possible you might get by with a delrin gear early in the drive train (say the 1st gear that mates with the pinion) but this depends on the ratio.
My feeling is you would certainly experience a disaster at some point early in the competition, why risk it. IMHO ![]() |
money!
the issue comes down to money at a certain point. off the shelf gears can often be out of our range but delrin gears are usually much cheaper. realistically i'd never consider it without a very wide gear and a very large pitch like maybe 12 or 16.......but only the check book will tell.
from experience
delrin for gears = bad
gears under full speed to full stop(hitting wall)= shattering of gears and people running and stepping on toes dahl |
| Regional & Division winners, did you shift gears or not? | DougHogg | Technical Discussion | 34 | 02-05-2003 16:10 |
| Helical gears that come with new drill motor | Joe P | Technical Discussion | 4 | 12-01-2003 11:09 |
| Best source for gears? Smallparts? drivetrain advice wanted! | Frank(Aflak) | Technical Discussion | 11 | 10-01-2003 17:22 |
| Need help! What kind of gears are we allowed to use?? | Randy_Ai | Technical Discussion | 3 | 23-01-2002 22:56 |
| replacement gears | joni_m | Technical Discussion | 1 | 22-01-2002 18:01 |
