Go to Post I have caught a very strong case of FIRST fever. - weinbergmath [more]
Unread 10-04-2016, 12:56
ProfessorAlekM ProfessorAlekM is offline
FRC #6190
ProfessorAlekM has a little shameless behaviour in the past
How to eliminate lag on USB Webcam Java
Hello!
Our team was using the simple camera server code on our robot during our last competition. It worked, but it always had a 1-2 second lag. Is there anyway to just lower the resolution and frame rate of the video (preferable 160x120px) so that the video feed is at least real-time?
(We are using USB webcams)
Unread 10-04-2016, 13:03
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: How to eliminate lag on USB Webcam Java
Right click on the camera on the smart dashboard and you can change the resolution. You can also resize the window.
Unread 10-04-2016, 13:07
stundt1's Avatar
stundt1 stundt1 is offline
Steve
FRC #4930 (Electric Mayhem)
stundt1 will become famous soon enoughstundt1 will become famous soon enough
Inside the CameraServer Class there is a setQuality() Method.
You can use this to change the quality of the image sent to the Driverstation which should decrease the Lag.
Checkout the WPI Documentation on the CameraServer Class for more information.
Steve
-Programming Mentor
- Team 578 Alumni
Unread 10-04-2016, 14:54
FRC #6190
We heard from another team that you can preset the resolution of the HD-3000 Camera with the life-cam software, but we tried changing the size of the video in the LifeCam software, but all that does is change the resolution for that recording session, and doesn't transfer when we plug it into the roborio.
Unread 13-04-2016, 19:45
abigailthefox's Avatar
abigailthefox abigailthefox is offline
FRC #1711 (Raptors)
Rookie Year: 2015
abigailthefox has a spectacular aura aboutabigailthefox has a spectacular aura about
Try running the camera in its own thread during operator control.
Write the vision code like you usually would, and then during the operator control loop, call it in its own thread, separate from other functions of the robot.
We had major camera lag problems, and this fixed it for us.
Here's a bit of example code
    public void operatorControl()
    	isDone = false;
    	//Begin vision processing on a new thread
    	Thread thread = new Thread()
    		public void run()
    			while (!isDone)
    				if(RobotMap.visionSystemEnable != -1)
        				vision.vision();
    	thread.start();
Unread 13-04-2016, 21:23
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Use Resource Monitor to verify that you're not exceeding the 7mbps rate limit on robot <--> operator console communications. We had to set quality on the stream to 30 to do so.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
