Go to Post Gracious Professionalism does not take a holiday. - JaneYoung [more]
Unread 10-04-2016, 16:35
Thardro Thardro is offline
AKA: Ethan
FRC #3042 (Cobalt Catalysts)
Rookie Year: 2015
Thardro is an unknown quantity at this point
Dealing with bright lighting at competitions and vision
This weekend we competed at the North Star regional and will be progressing onwards to Championship. However, throughout the regional we struggled to get vision tracking on the tower working due to other lighting at the event reflecting off of the tower and conflicting with our green LEDs despite tweaking of our HSV filter. Currently we are running an HSV filter on the image from our camera and then comparing the area of each particle found by NIVision to the area of the convex hull to eliminate solid lights found in the background. Is there anything that we could do to improve our recognition, especially for under the lighting at Championship?
Unread 10-04-2016, 17:06
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
Re: Dealing with bright lighting at competitions and vision
Your flaw is relying upon a HSV filter (and only a HSV filter) for identification of your target. That's like saying any orange car is a Dodge Charger. What are some ways you can verify that it is actually a target?
Unread 10-04-2016, 17:17
AKA: Ethan
Rookie Year: 2015
As I said in my post, we are also comparing convex area to the area of the particle found by the filter. I also forgot to mention that we have tried checking how close the particle is to a trapezoid along with checking the aspect ratio. Our main problem is that even with our LED ring the lighting at the competition can overpower our LED, causing no green light to be visible in our images.
Unread 10-04-2016, 17:24
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Based on past experience, I recommend using Purple. There's too much green/red/blue at competitions and around towers.
Unread 10-04-2016, 17:29
Sounds like you need to lower the exposure and/or brightness on your camera or put a filter (some teams ave used sunglasses in a pinch) in front of it.
Unread 10-04-2016, 17:51
AKA: Ethan
Rookie Year: 2015
Other than sunglasses, what would you recommend to use as a filter? Should it be a particular color?
Unread 10-04-2016, 17:56
A "neutral density filter" would be the correct thing to reduce light entering the camera without modifying hue.
Unread 10-04-2016, 23:10
If you have an image, that would go a long way towards being able to make a good suggestion.
The LV example uses aspect ration, moment of inertia, area/convext hull area, and an X and Y profile mask. None of these are expensive to calculate, and all of them help to compare analytical values of the U shape that is expected versus the computed values in your image.
Greg McKaskle
Unread 11-04-2016, 10:09
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
Exactly why we're using orange.
Unread 11-04-2016, 10:55
Owen Busler's Avatar
Owen Busler Owen Busler is offline
Build Captain
FRC #0303 (Test Team)
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
Team 303 had a similar issue at our competition last week. Im not convinced its the best way to solve this problem but we just added more and brighter green leds until it overpowered the reflection off the glass. In the end we had three of these rings concentric of each other.
https://www.superbrightleds.com/more...ghts-cob/1135/
They really are super bright, its pretty crazy. We also had a paper cup with white gaff tape on the inside to direct the green light. I couldn't find a good picture. Here is the best I could do:
https://goo.gl/photos/b7osRmTW6Vbs7uaZ9
2016: Deans List Semi-Finalist/MAR Mount Olive District Engineering Inspiration Award/Buckeye Regional Second Alliance Captain/MAR Montgomery District Event Imagery Award/MAR Championship Gracious Professionalism Award
2015: MAR Mount Olive District Chairman's Award/MAR North Brunswick District Winners/MAR Championship Finalists
2014: MAR Clifton District Chairman's Award/MAR Championship Regional Chairman's Award
Unread 12-04-2016, 23:36
AKA: Ethan
Rookie Year: 2015
Greg McKaskle
Here are a few images from on the field. Our two main issues were from cases like these two perspectives where lighting reflecting off of the tower would merge with or overpower the reflection from the LEDs or the reflection from the LEDs would not be different enough from the surrounding tower to be distinguishable using HSV values.
ID:	20590  Click image for larger version
Unread 13-04-2016, 00:00
jdesmond's Avatar
jdesmond jdesmond is offline
FRC #0177
jdesmond is on a distinguished road
You can program an exposure value, how do you implement your camera and vision processing?
Unread 13-04-2016, 08:07
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
It also happens to match your color scheme!
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 13-04-2016, 09:12
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
We use IR LEDs, an Axis camera, and a strip of developed film to cover the lens. Works great. All the camera sees is the IR reflection. Midwest had a banner running right behind the goals that could have washed out some other methods. Our camera couldn't even see it.
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 13-04-2016, 09:31
jweston's Avatar
jweston jweston is offline
FRC #1124 (The Überbots)
Rookie Year: 2015
jweston is a splendid one to beholdjweston is a splendid one to beholdjweston is a splendid one to beholdjweston is a splendid one to beholdjweston is a splendid one to beholdjweston is a splendid one to beholdjweston is a splendid one to behold
I believe you are allowed access to the playing field on day zero for camera calibration. At least, that's what we're doing. We use the green light ring too and I've seen camera calibration be the difference between silver tape and green tape in the image. Changing the camera settings for the field should make a huge difference if your image filtering is working fine at your practice field/workshop/etc.
