Go to Post You're here for them, not for you. - Chris is me [more]
Unread 09-04-2016, 23:50
Cel Skeggs Cel Skeggs is offline
Robot Software Manager Alumnus
AKA: Previously known as Colby
FRC #1540 (The Flaming Chickens)
Cel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of light
FIRSTCodes: New Slack chatroom for FRC software developers!
Team 1540 has created a Slack team at https://firstcodes.slack.com for students and mentors in FIRST who want to talk about writing FRC software!
Topics include:
  • Newbie questions about getting started with FRC software
  • Advanced questions about difficult topics, like autonomous vision
  • Discussion of best practices for software development in FRC
  • Code releases of your team's code
  • Announcements and discussion of open-source libraries and frameworks for FRC software
  • General chatter about FIRST
  • And much more!
Members of all skill levels and all teams are invited - click here to receive an invite! Please read the instructions once you get the invite, and suffix your username with your team number!
If you have any questions, feel free to post them here or in the Slack's #meta channel!
Software manager alumnus. Developer of the CCRE, a powerful robot code framework based on dataflow and composibility.
Refer to as she/her/hers. Years of FRC: 2012, 2013, 2014, 2015, 2016. FLL for a few years beforehand.
Team 1540: The Flaming Chickens | Portland, Oregon | Twitter | Facebook
Unread 10-04-2016, 15:27
Peter Johnson Peter Johnson is online now
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Re: FIRSTCodes: New Slack chatroom for FRC software developers!
The concept is good, but I'm not sure Slack is the right tool for this. Slack is great for relatively small teams where everyone knows each other in real life and you have relatively tight management control, but it has very limited tools for more "public" membership and appears to not really be designed for that application. For example, you can't restrict people from changing their display name, so it's easy for someone to play the Ender's Game trick of adding a space to their name to appear like someone else. Easy to deal with in a small team, but difficult to manage in a larger semi-anonymous group.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 10-04-2016, 15:32
jds2001 jds2001 is offline
AKA: Jon Stanley
FRC #4263 (CyberDrgaon)
jds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud of
I'll stand and be contrary here - first, the Slack invite link expired, so I can't get on. Some large open source communities use Slack for their primary means of communication - whether that's a good fit or not I'm not sure, as I'm not actively involved in the one I'm a member of (Kubernetes).
For the invite problem, there's some open source stuff (this is an example) that will handle doing the invites for you - you can also simply allow non-admin users to invite others (which may be all you need for this).
- Official Scorer
Disclaimer: I volunteer for FIRST as a referee. All opinions are my own, and do not reflect those of FIRST.
Unread 10-04-2016, 15:57
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Don't we already have ChiefDelphi for this?
Unread 10-04-2016, 15:59
Slack is not the perfect tool for this, but I've been part of other large Slack communities and am aware of both the limitations and ways to address them. I am aware that moderation work can be harder with a case like this.
The most significant issue with Slack for communities is that large Slack groups have limits on their maximum size (around 8 thousand members) and only a very limited scrollback unless you pay a significant amount of money. This isn't perfect, but that's why we also have Chief Delphi for longer-term and more public posts.
Yes - I plan to set up an invite automation solution at some point, but that's going to have to wait. Non-admins are already allowed to invite others in the current Slack, but that doesn't mean that anyone has used that feature.
New invite link!
Unread 10-04-2016, 16:03
This is not a replacement for Chief Delphi, but a supplement to it. Chief Delphi is good for everything that should last a long time. For asking a short one-off question when it's not clear that anyone else will ever benefit from it, or for chatter about FRC software, Slack works well.
By all means - if this doesn't seem useful to you, don't bother using it. It's insufficient for someone to post things like code releases in it, because it doesn't count as "public" - so even if it were to gain a huge adoption, you'll still see everything important outside of the Slack.
Unread 10-04-2016, 17:00
Carl C's Avatar
Carl C Carl C is offline
Custom User Title
AKA: Carl Colglazier
FRC #2059 (Alumnus)
Carl C is a splendid one to beholdCarl C is a splendid one to beholdCarl C is a splendid one to beholdCarl C is a splendid one to beholdCarl C is a splendid one to beholdCarl C is a splendid one to behold
Why not use IRC? Easy to use, no invites needed, withstood the test of time for over twenty-five years.
Unread 10-04-2016, 17:03
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
I came here to say the same thing.
Unread 10-04-2016, 18:13
I haven't recently tried IRC, but the consensus I've heard is that it requires users to download extra software (a barrier to entry), doesn't support cohesive communities across channels, feels twenty-five years outdated in terms of everything, and isn't necessarily easy to use for people new to it. I'm sure that IRC is the correct tool for many cases, but it doesn't sound to me like this is one of those cases. If you really like IRC, you can even use Slack's IRC gateway to connect to Slack.
I've resolved the invite problem: this link allows you to ask for an invite and automatically receive it.
Unread 10-04-2016, 18:19
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
I have yet to receive an invitation code. +1 for IRC.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
F4 uses slack and I can tell you it will work well for this. We are a community of about 40 people who did not previously know each other which is similar to this. I might join just to see how it is although I'm not much of a programmer.
Sent from my LG-H810 using Tapatalk
Unread 10-04-2016, 18:36
Connor Worley did in fact receive an invite; it just took half an hour for it to get through email. There are now thirty-two members of the Slack, and climbing!
Unread 10-04-2016, 18:56
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
I much prefer Slack to IRC. It's more flexible and useful than the more barebones IRC.
Head Programmer / Driver
Unread 10-04-2016, 23:27
AKA: Jon Stanley
+1. Slack has a killer feature that IRC does not - persistence across reboots of your device, restarts of the app, etc. as well as effortless integration of multiple devices - mobile, web, and desktop apps. Try getting that for free with IRC.
If you're hard-set on IRC, there's even Slack->IRC integration. Not sure how well that works though.
- Official Scorer
Unread 11-04-2016, 10:58
Update: we're up to 55 members in the Slack after the first day, and having plenty of discussions!
Click here to join us, and make sure you suffix your username with your team number.
