Go to Post All the gangstas in FRC have solid gold CRios. It's called "blingage". If you don't have a solid gold CRio, you're not a straight-up G. :D - Jamie Kalb [more]
Unread 22-01-2002, 09:01
tareyton
Posts: n/a
SPROCKETS WHERE TO GET
Small parts is out of the sprockets we need!!!! They are on back order. Anyone else know where we can order some from fast.
Unread 22-01-2002, 09:20
Anton Abaya's Avatar
Anton Abaya Anton Abaya is offline
None #0419 (Rambots)
Anton Abaya has a spectacular aura aboutAnton Abaya has a spectacular aura aboutAnton Abaya has a spectacular aura about
Send a message via ICQ to Anton Abaya Send a message via AIM to Anton Abaya
you should try going through your local yellow pages and look for local companies that make gears. i'm in boston and there's a ton of them around my area.
the cool part of it is that they might give you a nice fat discount being you're a local team.
-anton
Unread 22-01-2002, 10:57
Keithicus Keithicus is offline
#0920 (Lancers)
Keithicus is an unknown quantity at this point
A few good small components sources:
www.wmberg.com
www.allieddevices.com
A few all purpose suppliers:
www.grainger.com
www.mscdirect.com
You can write them and sign up online for free catalogs.
Unread 23-01-2002, 07:40
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
mcmaster.com and stock drive products (sdp-si.com) are good sources.
Also, motion industries is a good source.
Joe J.
sprockets BBFIRSTCHICK Technical Discussion 21 09-02-2003 01:01
modifying sprockets gail OCCRA 3 05-10-2002 12:13
Chief Delphi sprockets archiver 2001 23 24-06-2002 01:46
Re: Connecting hub sprockets to shafts archiver 2001 1 24-06-2002 00:20
Attaching the Gears and sprockets to the shaft archiver 2001 2 23-06-2002 23:18
