Go to Post Take care of what's there and you never need a replacement. - Rich Kressly [more]
Unread 11-04-2016, 12:02
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Capabilities Needed to be Picked at Champs
What capabilities does a robot need to have in order to ensure they are picked to an alliance at champs? I suppose being a third or fourth robot doesn't really matter as it's highly likely that most 4th robots will see the field due to the nature of Stronghold.
What are teams looking for in a 3rd and 4th alliance member?
  • Consistent auton that puts a ball in the tower, high or low
  • Penalty free
  • Does their task at a high level
What else? What's a high level?
Another question as well, can a defense-dedicated robot be selected, or does it make more sense to take the top available scoring machine and cheesecake on a blocker? How about a defense robot with a scoring autonomous mode and a climber?
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns Project Lead:
Reveal Video
White Paper
Unread 11-04-2016, 12:10
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Re: Capabilities Needed to be Picked at Champs
The one thing I'll point out is in regards to your comment about "highly likely most 4th robots will see the field".
Yes, Stronghold is a brutal, brutal game. Yes, I've seen a ton of posts on Chief Delphi from people warning to tighten all your bolts, check all your electrical connections, bring spares of everything.
"Because you WILL break down", I've seen said.
But I'll counter with this: it's very possible to build a robot that can withstand the rigors of this game. It's absolutely prudent to be prepared, of course, but I wouldn't go in expecting that everyone else will break down. Many teams didn't, and going into Champs I expect that proportion will be even higher.
Unread 11-04-2016, 12:11
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
A robot that:
1) Does not get stuck on Defenses
2) Does not have connection problems
3) Does not break down (performs reliably)
4) Does not tip easily
5) Good driver
6) Round out defense crossing abilities
The Alliance captain could be looking for a 3rd shooter, and a Defender for the 3rd and 4th robot. A 3rd shooter that can also play defense would be a good choice. If you have 2 of those (defense capable, but not necessarily defense only) gives the alliance the most options.
Scoring (crossing) during Autonomous is a requirement. Shooting during autonomous and climbing would be a reason to pick your bot over another defense bot that could not.
Unread 11-04-2016, 12:14
At the Wisconsin Regional, no backup bots were called up for service. Although, our 3rd alliance partner did break it's frame playing defense. It was able to be patched and continued to play.
Unread 11-04-2016, 12:20
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
a good reliable defender that has a scaler will not be left unpicked
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 11-04-2016, 12:22
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
#1 Get on the Batter
#2 Don't roll off the Batter.
If you don't get on or roll off the batter (even just once) you will probably fall way down the pick list.
IMO this is the biggest responsibility of the 3rd or 4th robot. It's 30 points lost if you roll off or don't get on.
Unread 11-04-2016, 12:28
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
  • Penalty free
Did you mean that 3rd and 4th alliance members score a boulder autonomously? Or that the team has a consistent autonomous mode, and also puts boulders in the tower during teleop?
Hi!
Unread 11-04-2016, 12:30
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
Most divisions won't have anyone who can score a ball in auto by the 2nd or 3rd round (or at least they shouldn't if there are competent scouts). The biggest things are to easily be able to traverse the field, get on the batter, never break down, and have smart drivers. A scaler or good shooter is extra.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 11-04-2016, 12:32
TDav540's Avatar
TDav540 TDav540 is online now
Questionable Decisionmakers
AKA: Trevor Davidson
FRC #1648 (G3 Robotics)
TDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud of
1) Cross at least two classes of defenses reliably in autonomous
2) Score a ball, ideally in auton, but if not, then quickly at the beginning of the match
3) Speedy drivetrain
4) Intelligent, penalty-free driving
5) Consistency in whatever you do
Other things (like an effective intake, ability to scale) are all bonuses, but those five requirements seem like the most important things alliance captains will be looking for at Championship.
2015-??: FRC 1648, G3 Robotics
2016 Carver Division, Columbus District Chairman's Award, Albany District Finalists
Georgia Tech, Class of 2019; Emcee, Ref, and 2016 Technology Enrichment Presenter
2011-15: FRC 540, TALON 540 Godwin Robotics
Proud Alumnus and Supporter
2015 Newton Division, Virginia Regional Finalist Alliance Captain
2014 Curie Division, Virginia Regional Engineering Inspiration
2013 Curie Division, Virginia Regional Engineering Inspiration
Unread 11-04-2016, 12:33
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
More than anything else, captains are going to want teams that get to the batter at the end of every match. This means avoiding teams that break down, get stuck on defenses, suffer frequent radio or roboRio reboots, or who simply roll off the batter or get stuck on the batter dividers too frequently.
There will be multiple avenues to distinguish yourself from other competitors. However, if you fail at challenging consistently, most captains will cross you off their lists right away.
Unread 11-04-2016, 12:36
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
I meant scoring a boulder autonomously. I think I'm overestimating the number of teams with this ability.
Reveal Video
White Paper
Unread 11-04-2016, 12:40
Division by Pirates
You definitely are. Keep in mind the divisions divide talent. If you look at some of the teams picked late last year at champs, there are some that can't do much of anything after can burglars, and some who can do a lot more than expected. This is due to division strength and scouts doing their jobs. So will someone who can score an auto be around that late? Depends on if there is a strong division where someone slips through.
Another thing to keep in mind is many of the ball scorers use the low bar, which can make a team not very useful if there auto conflicts with someone else's.
Unread 11-04-2016, 12:43
Drive Coach
AKA: Antoine L.
i predict the winning alliance on Einstein will be composed of:
captain : 2 ball auto/ low bar capable high goal cycler
1st pick : 1 ball auto/ scaler, scores high goals while breaching
2nd pick : crosses in auto, or scores as a spy, can score low (maybe high) and play good defense
3rd pick: good defender, can cross in auto
2 robots in the alliance will be able to scale, maybe one with some cheesecake
Of course i'd love to be wrong
Unread 11-04-2016, 12:46
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
From watching the webcasts, I'd argue that the most important thing for a 3rd or 4th robot is having a competent, capable drive team, and performing reliably and consistently. Any robot/team that is picked in the later rounds will probably have to adapt their usual game plan to fit their alliance (as will every robot). A skilled drive team will be able to quickly learn the alliance's strategy, consistently execute that strategy, and change it on the fly, mid-match, when something inevitably doesn't go according to plan. The converse of this is also true. This is no different than any other year in this regard, and though having extraordinarily capable robots is a wonderful thing, the only way to get the most from your machine is to have skillful students at the helm that, along with a smart coach, can work with any alliance to achieve success on the field. The high seeding teams (almost always, and especially at championships), will already have this trait in their drive teams, but selecting teams that also have fantastic drivers is critical to any alliance's success.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 11-04-2016, 12:47
pmangels17's Avatar
AKA: Paul Mangels
Addendum: this will be especially important on this year's seemingly crowded field.
