Go to Post It is one thing to be a great designer, it is another thing to be able to explain what you did, how things work, and why things happen. - Andy Baker [more]
Unread 11-04-2016, 13:39
nrgy_blast nrgy_blast is offline
nrgy_blast is on a distinguished road
Re: Talon SR vs Talon SRX vs New Victor vs Spark
The SR is more efficient than the SRX (by a marginal amount), as was documented by CTR. If you're OK with running PWM, there is absolutely no reason to switch to the SRX. That said, the SRX does have some advanced features that could be useful, if you aren't handling PID and other controls in your models (though figuring out PID controls on a motor probably isn't any more effective than just using LabVIEW to do it).
In summary, there isn't anything to 'upgrade' to from where you are.
Unread 11-04-2016, 14:00
tr6scott's Avatar
tr6scott tr6scott is online now
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
I would suggest you pick up 4 SRX controllers and a couple of the encoder and analog break out boards and work with the SRX PID over the off season.
The control provided with running the pid on the controller, is just fantastic, but there is some learning curve, and it is good to get that behind you.
You don't have use them for every motor, but when you want/need accurate control on positioning arms, or velocity on the shooter wheels, it is worth the extra dollars.
We have 4 of them on this years bot, 2 shooter wheels, shooter angle, and "wonder arm" angle. We actively switch between position mode and normal vbuss modes for coast down cool down events. We still use the Victor SR, for driveline, ball harvester, climber, climber deployment, as we like the form factor, and we actually have them mounted on top of each other, as the bot continually seemed to grow motors when mechanical team was making improvements.
The sooner we get behind schedule, the more time we have to catch up.
