Go to Post Pit Tools Distraction=bad - Lil' Lavery [more]
Unread 11-04-2016, 14:39
stoddard stoddard is offline
FRC #5712
stoddard is an unknown quantity at this point
Alignment Devices
The rule says that we can not have alignment devices external to the robot, so if we Velcro two 2x4s to the robot would this be legal.
Unread 11-04-2016, 14:41
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Re: Alignment Devices
then the 2x4s have to be part of the robot, pass inspection and stay on the robot
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 11-04-2016, 14:43
Jaci's Avatar
Jaci Jaci is offline
AKA: Jaci R Brunning
FRC #5333 (Can't C# | OpenRIO)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
2x4's as in wood? Velcro wouldn't be a very good mounting system for this, I can guarantee they're going to fall off. As soon as they are attached to the robot they are declared part of the robot and must pass inspection as they are considered an addition.
Jacinta R
Curtin FRC (5333+5663) : Mentor
5333 : Former [Captain | Programmer | Driver], Now Mentor
OpenRIO : Owner
Website | Twitter | Github
jaci.brunning@gmail.com
Unread 11-04-2016, 14:49
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
The rules do not forbid the use of external devices to align the robot. The blue box in G8 is about delay of match schedule. That is, you may not cause a delay in the match schedule through use of external alignment devices. If you can get your alignment device in and out easily and quickly, it's really no different than if you brought a screwdriver or diagonal cutters and tightened a screw or trimmed a zip tie.
In any case, what does this have to do with velcroing 2x4s to the robot? Any reasonably heavy part that is velcroed in place is likely to be in danger of falling off, and while not expressly illegal, is subject to failing inspection.
Unread 11-04-2016, 14:53
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
It's OP's team's attempt at a work around for external lineup devices.
Academic Student (Forever)
Unread 11-04-2016, 15:06
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Tape a few soda straws to appropriate spots on the robot. Look through the straws to see arena landmarks that tell you you are in the right spot and are properly aligned.
Or put grooves/scratches or bumps (screw/rivet heads) into/onto the robot. Align the grooves/bumps with arena landmarks.
Or put paired bits of tape onto the robot. Align the robot so that arena landmarks line up with the gaps between the paired bits of tape.
Don't overlook error sources (like slop in the initial state (tension, etc.) of the drive train belts/chains/gears) (or the nap of the carpet?) (or ...) that come into play as the robot goes into motion (and that are likely to swamp any initial small alignment errors).
Unread 11-04-2016, 15:13
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
I see what you are saying. You use the 2x4's to line up the robot and then velcro them back on. There is definitely a small hole in the rules but seriously does it matter.
What good are these 2x4's going to do you.
Unread 11-04-2016, 15:31
Drive Coach
AKA: Antoine L.
you may as well add a tape mesure to your robot, it would be better, and weigh less
Unread 11-04-2016, 16:43
FRC #5712
At our last event we used the wood to align ourselves with the guardrail so we could shoot low in autonomous. We used them about 3 times before a ref said that we couldn't use them. We had no clue their were any rules in regards to alignment devices and we wanted to look closer into it.
Unread 11-04-2016, 17:12
CalTran's Avatar
MST Rolla Senior
If you're still curious, the rule that would be cited is G8.
Originally Posted by G8
DRIVE TEAMS may not cause significant or repeated delays to the start of a MATCH and/or to the FIELD reset at the conclusion of the MATCH.
Violation: If prior to the MATCH, the offending DRIVE TEAM's ROBOT will be DISABLED. If after the MATCH, YELLOW CARD
DRIVE TEAMS are expected to stage their ROBOTS for a MATCH, and remove it from the FIELD afterwards, safely and swiftly. DRIVE TEAM efforts that are either intentionally or unintentionally delay the start of a MATCH or the FIELD reset are not allowed. Examples include, but are not limited to:
A. Late arrival to the FIELD
B. Failing to exit the FIELD once the TOWER LED strings have turned off (indicating MATCH ready)
C. Installing bumpers, charging pneumatic systems, or any other ROBOT maintenance, once on the FIELD.
D. Use of alignment devices that are external to the ROBOT
E. Failing to remove OPERATING CONSOLES from the PLAYER STATIONS in a timely manner.
Emphasis mine.
Unread 11-04-2016, 19:48
Just a thought:
Your eyeballs ought to be calibrateable. How about marking the proper width on the robot, then using your eyes to measure where the robot is set up?
I have yet to see a ref disallow eyes as an alignment device. Shoes might be a little harder to use, but could be doable. Using the robot, or a section of robot, is a really good option as well.
Unread 11-04-2016, 19:59
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
At Lone Star we used a combination of a boulder plus our hand width to gauge how far away we were from the wall for our low bar autonomous.
Unread 11-04-2016, 20:48
E_puello E_puello is offline
FRC #3161 (Tronic Titans)
E_puello is a jewel in the roughE_puello is a jewel in the roughE_puello is a jewel in the roughE_puello is a jewel in the rough
I wouldnt rule out velcro as an option for holding a 2X4 if you get the industrial strength stuff. in 2013 my team had about 10lbs of steel as a ballast on our robot held on only by velcro. It might sound sketchy but the velcro was enough when we wanted to take the blocks off we had to hold down the robot as the velco was strong enough to lift it.
