Go to Post We'll defenestrate our programmer, and I'll report back our solution if we get anything working. - Nick Seidl [more]
Unread 11-04-2016, 16:12
snotsdelta snotsdelta is offline
FRC #6056
snotsdelta is an unknown quantity at this point
Button Programming
We want to run a motor through a button, preferably the trigger. How would I program this? We are using labview 2015.
Unread 11-04-2016, 16:20
Re: Button Programming
Describe how you want the button to behave.
Example1:
Press and release button to toggle motor between "full on" and "off".
Example2:
When button is held pressed, motor runs. When button is released, motor stops.
etc.
You get the idea.
Unread 11-04-2016, 16:21
Here's an example using two buttons (forward/reverse/off).
Just use a single button if the motor is only forward/off.
http://www.chiefdelphi.com/forums/at...6&d=1454729278
Unread 11-04-2016, 21:36
FRC #6056
Example1:
Example2:
etc.
You get the idea.
We would want example 2. When the trigger is pressed it goes at full power, and when released it stops. Thank you!
Unread 11-04-2016, 21:51
See the link Mark provided in Post#3. If you need further help, ask Mark politely and I'm sure he will help.
Unread 12-04-2016, 10:17
FRC #6056
Sounds good Thank you Ether
Mark I noticed that the example you posted was from the 2014 version of labview. Will it work for the 2015 version?
Unread 12-04-2016, 10:21
Yes it works in both. There was no change in the LabVIEW version upgrade that affected this.
You can save that image to your desktop, then drag it onto an open block diagram, and the code will appear.
Then edit to remove the extra button.
Unread 12-04-2016, 10:48
FRC #6056
Sounds great. Thank you Mark!
