Go to Post A wet noodle of a chassis won't matter how much drop you have. - Andrew Schreiber [more]
Unread 11-04-2016, 13:01
Rangel's Avatar
Rangel Rangel is online now
John Rangel
FRC #0842 (Falcon Robotics)
Rangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond repute
Re: Capabilities Needed to be Picked at Champs
If we were to end up captaining an alliance in our division, I'd pick teams in the following order:
1st pick: 254,1241,987,best unblockable outerworks shooter.
2nd pick: Best high goal shooter available. Doesnt matter if they are defendable.
3rd pick: Best low goal robot available that has good drivers.
The reason for the 3rd pick is to play defense and feed balls to shooter bots crazy fast. 1st and 2nd pick is for triple offense focused play with robots that take turns defense mid match when balls are not readily available. The specific teams I listed in the first pick are there to force defense to be played on them making it 2.5 shooters vs 2 in a match. The reason the shooters are chosen first is because the weakest one still needs to be able to bring it to the best in case one of the top two break and needs to sit out a match. Of course all this is subject to change depending on teams in our division and what most robots in the division lean towards.
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
Unread 11-04-2016, 14:27
Tyler_Kaplan's Avatar
Tyler_Kaplan Tyler_Kaplan is offline
FRC #1678 (The Citrus Circuits)
Tyler_Kaplan is a glorious beacon of lightTyler_Kaplan is a glorious beacon of lightTyler_Kaplan is a glorious beacon of lightTyler_Kaplan is a glorious beacon of lightTyler_Kaplan is a glorious beacon of lightTyler_Kaplan is a glorious beacon of light
Different alliance captains are going to want different things. But there are some universal traits that all teams will have to get picked at world champs.
1. They have a consistent crossing auto.
2. They do not break down, or get stuck on defenses.
3. They can cross at least two classes of defenses.
4. They have experience with getting and staying on the batter. Meaning they've done it for most if not all of their matches.
5. And most importantly, they have good drivers. If you're the third or fourth robot on an alliance chances are you're playing defense, which means that your driving ability is what will get you higher on most lists.
If you gave the controls of 254's robot over to someone who didn't have any experience with the robot, chances are it would not perform well at all. What makes a team successful in matches (among other things) is the amount of practice a drive team has.
So if your team is consistent, gets on the batter, has a decent auto, and has good drivers, you should have no problem getting picked.
Again these are just my predictions/opinions...
Any threads/posts made do not necessarily reflect the views of any teams I am affiliated with, only my own.
Unread 11-04-2016, 14:33
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
What about robots with spy box high goal autonomous routines? It would make more sense to pick one of these because it contributes to the hardest thing to get (capture) and still scores 10 points. As opposed to a robot that has a 10 point crossing autonomous, which is less valuable (IMO) because the breach is going to happen anyway.
It isn't shiny enough.
Unread 11-04-2016, 14:40
At the extremely competitive level that champs will be played at, I don't think the top teams will have a problem getting 8 balls into the tower, an extra one won't make/break a match. Crossing a defense will be more reliable, and it's what is more achievable for teams around for those picks.
Again, some alliance captains might disagree with my opinion, but I'd take the robot that crosses, because it's probably going to be a safer bet.
Unread 11-04-2016, 17:33
hutchMN hutchMN is online now
2502 alumnus
FRC #4360
hutchMN has a spectacular aura abouthutchMN has a spectacular aura abouthutchMN has a spectacular aura about
Where do you think a robot that could do 6 high goals (none in auto), cross 2 classes of defenses in auto, and scale (no foot print scale) would get picked?
Unread 11-04-2016, 17:41
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
If the robot in question does so every match then it will likely be picking.
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns Project Lead:
Reveal Video
White Paper
Michael Hill's Avatar
What teams will be looking for will depend on seeding. Higher seeded alliances will value reliability over taking chances. However, I think the best 2nd and 3th picks will be robots that can reliably do both of the Cat B defenses (ideally in autonomous), get on the batter, and potentially hang. The Cat B defenses take the longest time to do. It's almost guaranteed either the alliance captain or the first pick will be low bots. Being able to do the drawbridge is nice, but sally door is also nice. Teams are starting to choose the Sally Door over the Drawbridge because visibility is now being valued more than the ability to stop a breach. Breaches are going to happen no matter what you throw out there.
Unread 11-04-2016, 17:48
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
To this point, the Sally Port is so much easier to "tap" than the drawbridge. 4607 can damage the Sally Port quickly, but the Drawbridge just sucks for everybody.
Reveal Video
White Paper
Unread 11-04-2016, 17:57
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Anywhere from 1st pick to not picked depending on consistency...
Unread 11-04-2016, 18:04
tindleroot tindleroot is offline
Free Scouting Help to All
AKA: Casey LeeVan
FRC #4272 (Maverick Boiler Robotics)
tindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond repute
Originally Posted by Jay O'Donnell View Post
Most divisions won't have anyone who can score a ball in auto by the 2nd or 3rd round (or at least they shouldn't if there are competent scouts).
Yet I've seen a few events where the last picks have scored high autonomously...
I believe that most high seeded alliances at champs will have two powerhouse boulder scorers, and will choose their third robot for defense (the backup might be another scoring bot though). Lower seeds will see a mix of defensive/offensive third robots, but if they choose to play more offense they will have to be able to outgun the two powerhouses while handling defense. My prediction is that most alliances will have a dedicated defense robot, either in the courtyard or the neutral zone.
2012-2013: FTC 4601 (student)
2014-2015: FRC 135 (student) - 5 banners in 2 years!
2016-present: FRC 4272 (mentor)
Thanks to all of our alliance partners!
11, 51, 68, 201, 234, 868, 1108, 1241, 1760, 3147, 3301, 3487, 3865, 4269, 4485, 4580, 5188
Unread 11-04-2016, 18:43
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Another factor that comes into play with regards to the value of a defensive robot is whether the GDC decides to raise the health of the tower. I see it as fairly likely that they bring it up, or else a capture will happen basically every match. If the tower health is raised to the point where 2 strong high goal shooters can't bring it down alone, the value of offensive capabilites in a 3rd robot goes up.
If it's brought up a little bit then a defense robot becomes more valuable since the capture will be preventable. As it stands, a defensive robot, even the best, will have trouble preventing a capture. 3 robots all score during or right after auton and the defense robot now has to prevent 2/3 elite scoring machines from getting 5 boulders into the tower. This is doubtful especially considering how unblockable some teams are.
Reveal Video
White Paper
Unread 11-04-2016, 18:53
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
I don't see them changing it. And I also don't see a capture happening nearly every Quals match. The average ability of teams is much lower than you're anticipating in my opinion. Watching Quals matches from past years at champs shows lots of teams who fail to do much of anything.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 11-04-2016, 19:15
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
I went to Champs when there were 4 fields. I keep forgetting there are 8... we were also a rookie team at the time so every team there seemed like they "had it all". I guess you could say it's been too long
Reveal Video
White Paper
Unread 11-04-2016, 19:40
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
If you don't drive well, you won't get picked. And if you do, your alliance won't get very far. Good driving is important whether you're playing offense or defense, and some offensive robots may need to adapt to a defensive role quickly as eliminations comes around should they find themselves lower ranked than they would like and on an alliance that already has enough firepower in their first two robots.
I strongly recommend teams use the few weeks before champs to polish their driving.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 11-04-2016, 19:49
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
One other factor on crossing in auto: be able to cross something other than the low bar or rough terrain. Of course crossing the DB or SP would be super cool...
