Go to Post The Questions is, do we attempt to build a Mr.Fusion, or do we go for the Plutonium from the Libyans? - dag0620 [more]
Unread 04-11-2016, 07:57 PM
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: 2016 Clientside NetworkTables lib
Originally Posted by spat View Post
Do you have your code available on GitHub? If so, I would be glad to help you out.
As a sidenote, the QDriverStation uses a separate library (also done by me ) to handle all the client-to-robot communications, loading different communication protocols and registering joystick input. The library is also written with Qt and can be easily integrated to your project. Basically, you should only make the GUI and wire it to the library.
Links:
I decided to switch to the basics and use a QTcpSocket thanks though.
