Go to Post There will always be a point in your FIRST experience when you realize you can get away with something that is against the rules. It is at that point when you have a choice to make about your own personal ethics, and what sort of example you will set for your students. - ToddF [more]
Unread 11-04-2016, 20:14
Louisiana Jones's Avatar
Louisiana Jones Louisiana Jones is offline
Jason Jones
AKA: Jason Jones
FRC #1806 (S.W.A.T.)
Louisiana Jones will become famous soon enoughLouisiana Jones will become famous soon enough
pinning being called consistently?
After watching numerous events I've noticed that pinning doesn't seem to be called consistently. One thing I've noticed is that at some regional events pinning seems to be called even when robots don't seem to be pinned. In the following video I noticed that pinning was called immediately when 2907 makes contact with 1540. I've now seen this happen at multiple events and I'm wondering how this will be called at worlds? I'm not sure I agree that this should be called pinning as 1540 clearly wasn't prevented from moving in any way. What does everyone else think?
https://youtu.be/DdYG77EmItc?t=1m52s
Unread 11-04-2016, 20:16
Re: pinning being called consistently?
Blocking someone on the batter such that they cannot get off is considered pinning, regardless of whether or not they can move.
I'm not sure I'd agree with how early the count started, but it sure got the point across.
Unread 11-04-2016, 20:33
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Pin count starts immediately.
Unread 11-04-2016, 20:38
maxnz's Avatar
maxnz maxnz is offline
AKA: Max Narvaez
FRC #2855 (BEASTBot)
Team Role: Student
Rookie Year: 2016
maxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of light
In QF3-1 at 10K Lakes, team 2855 was (somewhat*) pinned in the corner in the opponent's secret passage. Now I can't say for sure that it lasted long enough to be a foul, but they still got the foul on us for being in their secret passage and them touching us. I'm not complaining or anything, because I'm fairly certain that it was legal, but it is just another example of how being in the opponent's secret passage can be risky.
*I say somewhat because we would have encountered a G21 violation if we had tried to leave the corner
As a senior that will be leaving the team, I have to teach others how to:
1. Know the manual extremely well
2. Wire the robot
3. Organize the shop
4. Help people find parts when they need them
5. Find parts to order and give the detailed list to the coach in charge of buying the parts
6. Keep track of team updates, Q & A responses and FIRST blog posts
7. Be active on CD
8. Plan and execute drive team strategy
And more that won't fit on this list...
Unread 11-04-2016, 20:40
Immediately on being pinned. WHETHER the team was, in fact, pinned, is rather debatable. Obviously, in that particular ref's judgement, they were.
Unread 11-04-2016, 20:42
Jason Jones
AKA: Jason Jones
Do you really consider 1540 to be blocked on the batter?
This is the excerpt from the game manual that you may be referring to
There is no FIRST Robotics Competition specific definition of pin, so a
general definition applies; “to prevent or stop something from moving.”
As a result, contact is not required for pinning to occur. For example, a
ROBOT parked right behind an opponent that is on the BATTER could
be considered pinning because the dividers on the BATTER and the
parked ROBOT prevent the opponent from moving.
Unread 11-04-2016, 20:51
That is the section. Now, you may want to read the following exchange (from shortly after that post):
I won't be making any comment as to whether or not that particular ref's judgement was or was not correct.
Unread 11-04-2016, 21:07
AaronSchmitz's Avatar
AaronSchmitz AaronSchmitz is offline
Mentor & Volunteer
AKA: Grumpy Mentor
FRC #0949
AaronSchmitz is an unknown quantity at this point
Determining this is of course much easier when you can look into the future 2.5 seconds and see 1540 pull away relatively unimpeded.
Source: am that particular ref
Unread 11-04-2016, 21:12
Yep. However, as a ref myself, I saw a number of situations like that that had me very close to signalling the start of a pin count, but within 1 second the situation was not a pin. This is a fluid game.
Unread 11-04-2016, 21:21
Jason Jones
AKA: Jason Jones
Great to hear it from the source, and yeah hindsight makes it easy to see. I guess what I'm wondering is how refs at different events were told to call pinning? Maybe you can provide some insight Aaron. I'd like to know how it will be called at champs as it can significantly change the way teams play defense, and how we plan on doing so. Will T-bones be called pinning? How do both robot's movement play into the call?
Unread 11-04-2016, 22:13
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
For example, a
Look this is pretty settled by this point. Was that pinning, maybe. But the bottom line is that robot had 4 seconds and then it had to let the robot on the batter alone.
This rule is why we felt comfortable being a batter shooter, because we knew that you could only mess with us for 4 seconds, and then we get to shoot. Or we get 5 points anyway in foul points.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 11-04-2016, 23:21
Mentor & Volunteer
AKA: Grumpy Mentor
FRC #0949
All statements below are purely my own and should not be construed as representing the views of USFIRST, Washington FIRST Robotics, Pacific Northwest FIRST, Oregon FIRST Robotics, FRC Team 949, or any other entity...
If that happens it's easy to wave off with no foul as I do here. If you don't start the count until say 3 seconds in (assuming you're going to give the offending robot 5 seconds to get away), it's not fair to the pinned robot since they're now pinned for up to 8 seconds. In this particular case 2907 had also been pinning aggressively (but legally) throughout the event, so I felt very confident starting a count right away.
Again, it's fair to say this call is questionable. If it were a fellow ref, I wouldn't call it wrong either if they started a pin count or didn't. If 2907 were 2' back and to the left so that 1540 can't back away I'd say pinning is definitely the right call and the count should start immediately, but it's so hard to determine field-side -- especially in the heat of the moment.
At PNW DCMP we had an incredibly strong ref crew with an average of ~3 preceding Stronghold events each as ref or head ref so we were probably more capable/confident being strict with fouls than most ref crews. I can't comment on what direction will be given to referees at CMP. I can speculate that defense will be very aggressive at CMP and that since excessive pinning really breaks offense G22 will be strictly enforced.
With regards to T-boning I can't give a general answer, but if the T-boned robot is in contact with some other object and it's motion is stopped or significantly impeded, do you feel this meets the blue box for G22?
With respect to movement, refs aren't psychic. If a robot is simultaneously in contact with an opposing robot and some other object and is not moving, there's a good chance we're going to assume it's not moving because it's pinned. In a batter type scenario, if the pinned robot starts moving within 5 seconds it's most likely going to qualify as "chasing" (see G22) which should cause the pin to be waved off. As a final reminder, pinning continues until the offending robot backs off by 6' for 3 seconds, so once a pin is started any movement by the offending robot within 6' is usually irrelevant.
Unread 11-04-2016, 23:48
Yep, I agree with you on that. I trust your judgement on that--you were there, I'm not. And I would agree that the pinning robot was playing smart, legal defense--they backed off as soon as they saw the tomahawk.
I did see a ref at an event I was at start to call pinning on a T-bone in open space... With the "victim" moving. Just started, though. Great chance for a zebra discussion...
Unread 12-04-2016, 05:57
If your robot is blocked in the batter, that is a pin. Regardless of whether there is contact. No different than if the robot is blocked into a corner. The purpose of the PIN Foul is to allow robots have the potential to move freely.
"WHETHER the team was, in fact, pinned, " is easily resolved during the PIN count period. By the time you get to "2", it is usually pretty obvious if it is a PIN or not. If not, then the PIN count is waived off, no foul, and the robots are free to continue.
PIN does NOT require intention. The mere fact that the Robot is blocked in (and it is easy to block in a robot in a 3-sided closed area like the Batter) creates the PIN.
Unread 12-04-2016, 06:10
IMHO, the issue is where the other robot can go. If the robot can only go forward into a guard rail, and backwards into a defending robot, then that is a pin. If the robot can only move into a "trapped' area (corner), then that is also a PIN.
Here is an interesting case:
1) Robot is scoring a low goal in the goal on the side of the Secret Passage.
2) Defending Robot is sitting 6" away in the Courtyard - between the Castle and the Secret passage.
When Scoring Robot exits the Batter, it is pretty much stuck. If it backs up further to go around the defending robot, it will be in the Secret Passage, and exposed to a foul.
