Go to Post Dedicated students inspire parents and mentors, dedicated mentors inspire students. - Akash Rastogi [more]
Unread 11-04-2016, 21:34
Ouroboroz Ouroboroz is offline
AKA: Kevin
FRC #2554 (The Warhawks)
Ouroboroz is an unknown quantity at this point
Legal Encoders
I was looking at encoders for the robot but all I saw were encoders for the SRX or AndyMark PG Gearmotors which my team doesn't use. Are there any other legal encoders that are usable?
Unread 11-04-2016, 21:48
Re: Legal Encoders
Just about any encoder is legal. What specific encoders were you considering?
Unread 11-04-2016, 22:07
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
Re: Legal Encoders
As Ether said, anything that follows rules for power draw is legal. Lots of teams use the USDigital E4T/P 4X encoders. Lots of Andymark products have the holes/shafts cut to hold these encoders, including the Toughboxes and the RAW box. Not terribly expensive either, coming in at $42.00.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 11-04-2016, 22:09
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Legal Encoders
AMT 102 and AMT 103 are great. Look on Digikey for them. They come with a full set of collars for shaft sizes up to 8mm, along with a neat box. VEry cheap, around $25 each.
You can use continuous potentiometers as absolute encoders in some cases. They come as cheap as $15 on Digikey. Regular potentiometers can work but have reduced angle range.
We have used Us Digital encoders, which are not terribly expensive but are still far more expensive and fragile IME than the AMTs.
You can also make your own encoders, but it takes some work. I recommend AMS for the chips if you are interested in going that route.
Unread 11-04-2016, 22:15
Re: Legal Encoders
I was looking at encoders for the robot...
"The robot" is pretty general.
If you would provide more detail about your specific intended application, you might get more targeted advice.
For example, do you want to measure the angle of a slow-moving arm, or the speed of a fast-spinning shooter wheel? You get the idea...
Unread 11-04-2016, 22:18
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Re: Legal Encoders
This thread reminds me... Omar, when are you adding gray code encoder support to the SRX controllers?
Unread 11-04-2016, 22:19
AKA: Kevin
Re: Legal Encoders
Thanks for all the help! I'm mainly trying to figure out the position/angle of a arm. Do you guys know of any good encoders that go with Vex VersaPlanetary Gearboxes or Vex 755pros?. Thanks!
Unread 11-04-2016, 22:22
marshall's Avatar
Re: Legal Encoders
Armabot makes one for the RS775 Pro. It's quite nice:
http://www.armabot.com/encoders.html
Unread 11-04-2016, 22:34
Knufire Knufire is offline
Re: Legal Encoders
Remember that you're trying to measure absolute position here (the exact angle of the arm). Incremental encoders (which are most of what has been mentioned in this thread so far) measure relative postion (how much the angle of the arm has changed since the robot turned on). There are a few different solutions.
If you want to use an incremental encoder, you'll need a second sensor to tell you where "zero" (or any reference point) is. I've found the hall effect sensors from WCP made by 971 work great for this pupose. It's a little circuit board that returns a true/false based on whether there's a magnet in front of it; you attach a magnet to the arm and place the sensor board where it will trigger at a known arm angle. Now you know how much the arm angle has changed from that known position.
An alternative solution is to use an absolute encoder or potentiometer, that will tell you absolute postion. One option for this are the VP Encoder Stage (this is actually the SRX Mag Encoder mounted into a plastic block the same shape as a VP stage). You'll need a Talon SRX to interface with this sensor. If you don't want to use an SRX, one of my personal favorites is the US Digital MA3: http://www.andymark.com/product-p/am-2899.htm.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 11-04-2016, 22:41
AKA: Kevin
Re: Legal Encoders
Thanks so much! That encoder might just be what my team needs.
Unread 14-04-2016, 21:08
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Re: Legal Encoders
http://www.vexrobotics.com/vexpro/al.../217-5046.html
Here is the link for the VersaPlanatary Integrated Encoder. As Knufire said, it is a SRX Mag Encoder from CTRE in a case that goes in your VersaPlanatary setup. It's quite a nice form factor if you can spare the extra length of the gearbox.
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 15-04-2016, 11:32
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Re: Legal Encoders
If using this on the arm, use the encoder stage between your last planetary stage and your output shaft so you get your encoder counts with per shaft revolution rather than needing a ratio of counts to revolutions. For example if the encoder outputs 1024 counts per revolution, you would have 1024 counts per single revolution of the output shaft, if you have a 4:1 reduction stage between your encoder and output shaft, you would have 4096 counts per revolution of the output shaft. In an application of this sort, error in the gearbox is multiplied the through the reductions, so it is advised to use the encoder as close to the output as you can. The encoder is both absolute and quadrature so you won't need a second sensor for homing purposes.
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 15-04-2016, 13:09
parry1126 parry1126 is offline
FRC #1126 (SparX)
parry1126 is an unknown quantity at this point
Re: Legal Encoders
We have been using Grayhill Inc.Encoders for years. $53.93 on Digi-Key
http://www.digikey.com/product-searc...ords=GH3070-ND
Unread 15-04-2016, 16:17
Re: Legal Encoders
Are you recommending against using an absolute sensor for the OP's application?
Unread 15-04-2016, 23:13
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Legal Encoders
On this note, I actually prefer using incremental encoders for absolute rotary applications. I don't have to worry about overflowing/turnover and they are easy to zero out if they slip in a match, which happens even when we set screw our encoder shafts.
Continuous potentiometers are cheaper than encoders, but I can make my own encoders cheaper than even those.
