Go to Post I want to help them to get what's made such a difference to me... - Beth Sweet [more]
Unread 12-04-2016, 11:01
microbuns's Avatar
microbuns microbuns is offline
AKA: Sam Maier
FRC #4917
microbuns is an unknown quantity at this point
How fast was your vision processing?
Our season has now finished, and one issue that ended up really hurting us was the amount of lag in our vision system. Out setup was as follows:
  • Axis camera
  • GRIP running as a second process on the RIO
  • GRIP reading from the Axis camera, doing some processing, then publishing to network tables
  • FRC user program pulling from the network tables every scheduler cycle
In the end, this whole process took anywhere from 0.5-1 seconds to actually act on the data. This caused a lot of issues with lining up the shot.
We were never able to track down exactly where in the pipeline we lose so much time. It could be any of the steps above.
How did your vision work, and how fast was it?
Unread 12-04-2016, 11:14
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: How fast was your vision processing?
mjpg-streamer with opencv python plugin running on RoboRIO, 320x200. Published values to NetworkTables.
Didn't measure latency, but it was low enough to not notice it, certainly under 500ms. Around 40% CPU usage when processing enabled.
Unread 12-04-2016, 11:23
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
We use a coprocessor (onboard laptop) that streams target information to the robot every 500ms. We also wait for the next frame to ensure the camera is stable when we react to the target. This means that we could end up waiting 500ms but most of the time it's probably less. We've found this rate seems pretty good for maintaining responsiveness while not bogging down any of the systems.
Could we speed it up? Probably, but we haven't seen a need thus far.
We also steam the target information over an open web socket rather than using Network Tables which probably helps with latency as well.
Unread 12-04-2016, 11:55
fargus111111111's Avatar
fargus111111111 fargus111111111 is offline
AKA: Tim W
FRC #0343 (Metal in Motion)
fargus111111111 is on a distinguished road
We used the Labview example code, so I can't say exactly how it worked, but I do know that we were processing 25-30 fps on the roborio and it resulted in minimal lag. Our automatic aiming could turn the robot at a x value of up to .5 and still catch the target with the robot positioned just beyond the outer works. To make it accurate enough for shooting however we had to slow it down to an x value of .25. Side note, we do run PID to make slow speed control possible.
I didn't break it... this time.
Unread 12-04-2016, 12:09
Landonh12's Avatar
Landonh12 Landonh12 is offline
270 points
AKA: Landon Haugh
FRC #0364 (Team Fusion)
Landonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud of
We have a vision processing solution for champs, and it uses the LabVIEW example.
I took the code and all of the controls/indicators and implemented it into our Dashboard with support for camera stream switching and an option to turn tracking on/off.
We will only be using it for auto. The vision tracking really only processes images for 500ms. We will be using a gyro to get to the batter, then using the camera to capture a few images, process them, and then use the gyro to correct the error. I found that using the camera to track in real time just isn't very viable due to the inconsistency of the image while the robot is moving (it causes the image to blur and the target will not be found).
Works pretty well.
Team Fusion 364 - Driver/Programmer 2012-2015; Controls Mentor 2016-Present
Unread 12-04-2016, 12:33
RyanShoff RyanShoff is offline
FRC #4143 (Mars Wars)
RyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to behold
We used the Nvidia TK1. We used c++ and opencv with cuda gpu support. The actual algorithm was very similar to the samples from GRIP. Everything up to findContours() was pushed to the gpu. It would normally run at the full framerate of the MS lifecam (30fps). It sent a udp packet to the roborio every frame. The latency of the algorithm was less than 2 frames, so 67 ms.
We felt we still couldn't aim fast enough. We actually spent more time working on the robot positioning code than we did on the vision part. At least for us, rotating an FRC bot to within about a half degree of accuracy, is not an easy problem. A turret would have been much easier to aim.
One helpful exercise we did that I think is worth sharing: Figure out what the angular tolerance of a made shot is. We used 0.5 degrees for round numbers. Now, using the gyro, write an algorithm to position robot. We used the smart dashboard to type in numbers. Can you rotate the robot 30 +- .5 degrees? Does it work for 10 +- .5 degrees? Can you rotate the robot 1 degree? Can you rotate it .5 degree? Knowing these and improving them helps a lot.
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 12-04-2016, 12:56
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
For us the issues weren't about vision itself - it was about an erroneously-tuned PID on the shooter tilt/pan that took forever to settle. At the start of the competition, the shooter would be off by +/- a few degrees in pan and +/- a lot of degrees in tilt. Double-check those if you have a few spare hours. Note - we use a turret rather than drive train to adjust left/right aim.
We use Axis -> mjpeg (320x240@15) -> FMS Network -> (D/S Laptop) Open CV -> Network Tables -> FMS Network -> RoboRIO.
We used all of our free time this past Saturday to re-tune the shooter PID from scratch and optimize a few processing pathways. It was heartbreaking to miss the tournament, but it had a major silver lining: off the field, the shooter now tracks without noticeable lag to within about +/- 0.2 degrees. I would expect about an additional 100ms delay on the field given the packet round trip times through the FMS.
GitHub
Unread 12-04-2016, 13:08
Jaci's Avatar
Jaci Jaci is offline
AKA: Jaci R Brunning
FRC #5333 (Can't C# | OpenRIO)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
We use a Kinect camera connected directly to our coprocessor, which is then processed by OpenCV, and then sent to the RoboRIO / Driver Station for alignment and viewing. Running on a single thread, the coprocessor is able to update at the Kinect's maximum framerate of 30FPS.
Here's a video of it in action (with a handheld piece of cardboard with retroreflective tape. Coprocessor and RoboRIO are running in this example)
Jacinta R
Curtin FRC (5333+5663) : Mentor
5333 : Former [Captain | Programmer | Driver], Now Mentor
OpenRIO : Owner
Website | Twitter | Github
jaci.brunning@gmail.com
Unread 12-04-2016, 13:09
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Originally Posted by microbuns View Post
  • Axis camera
What resolution were you running the Axis camera at? If you're running at 800x600 (or even 640x480) I could see it causing significant delay. I'm unfamiliar with GRIP but we easily achieve 10FPS using a 424x240 resolution with a USB camera on the RIO in Labview. If you're running a low resolution, then I'd look at network tables as a possible issue and consider replacing it with a UDP stream.
Unread 12-04-2016, 13:12
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
We originally had opencv code running in a separate thread on the roborio. This worked pretty well, however there was noticeable lag. So between competitions we switched to a raspberry pi 3 running opencv code and network tables. This was way faster especially with the new pis 64bit capability and 1.2 ghz processor. We had less than 100 ms. So the only thing slowing hs down was the robot code. It worked pretty well, however our algorithm wasn't ideal because we didnt have any sort of PID loop. We just kept checking if we were in a pixel tolerance. Right now I am working in calculating angles to rotate to to shoot.
Unread 12-04-2016, 14:16
KJaget's Avatar
KJaget KJaget is offline
Zebravision Labs
FRC #0900
Rookie Year: 2015
KJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud of
Stereolabs Zed camera -> Jetson TX1 for goal recognition (low 20FPS capture thread speed @ 720P, 50+ FPS in the goal detection thread) -> ZeroMQ message per processed frame with angle and distance to Labview code on RoboRio -> Rotate turret, spin shooter wheels up to speed -> Ball in goal
There were a few frames of lag in the Zed camera, so we waited ~250msec or so after the robot and turret stopped before latching in data on the LabView side. Even so, the shooter wheels spinning up were usually the slowest part. The whole process took maybe 2 seconds from stopping the robot until the shot happened.
Unread 12-04-2016, 15:37
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Our configuration is a USB Camera plugged into a Beaglebone processor running OpenCV, sending X-offset and target validity data through ethernet packets around ~50Hz. The image capture is at 30fps and image processing takes a fraction of the frame capture time. So, we see the results just as quickly as the camera can stream it, effectively 33 ms
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 12-04-2016, 15:59
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
We are using the example code, on the roborio, we process images in about a second each. Due to the image processing lag, we convert the image data, to degrees of rotation on the Navx, and position bot with Navx data. We shoot when the next image confirms the image is within tolerances. On Average it will take us about 5 seconds from turning on vision to goal, if we are about 25 degrees off of center. All in labview on the bot, we don't even send image back to the driver station.
This is the first year we are using vision on the bot, next year we will probably play with vision processor in the off season, but we had enough of a learning curve, to get where we are at.
The sooner we get behind schedule, the more time we have to catch up.
Unread 12-04-2016, 16:06
Harshizzle's Avatar
Harshizzle Harshizzle is online now
AKA: Harshal Singh
FRC #4828 (RoboEagles)
Harshizzle is on a distinguished road
3 months so far (and it's still looking for its first competition field contour)
Think Big.
Unread 12-04-2016, 20:06
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
My team created and used tower tracker. Unfortunately due to our robots constraints we were not able to use it effectively but will try our hardest at competition.
Since tower tracker runs on the desktop it gets the axis camera feed which is maybe 200ms off. Then can process the frames real time so maybe another 30ms and sends it to network tables which is another 100ms off, and the robot to react which is real time by the time its ready for the vision. Robots can use snapshots of what they need to effectively use vision processing. When lining up you only need 1 frame to do the angle calculations. Then use a gyro to turn 20 degrees or whatever it is and then find out the distance. Multiple iterations help all of it of course. TL;DR 400ms max delay snapshotted gives us good enough target tracking.
Engineering Inspiration - 3019
Tower Tracker author (2016)
  • 1 regional finalist
  • 1 regional winner
  • 3 innovation in control awards
