Go to Post it is easy. you will have to define "easy" in your own terms. - Mike Martus [more]
Unread 12-04-2016, 17:01
techbeast34 techbeast34 is offline
FRC #4048
techbeast34 is an unknown quantity at this point
Using LabVIEW vision with Java code
So our team is trying to use the LabVIEW vision code that our LabVIEW team created, to run alongside our Java code. The problem is, is that when I start the LabVIEW runtime at "/usr/local/natinst/labview/lvrt" on the RoboRIO, this error pops up:
Can't find library liblvrt.so.15.0
Make sure this library is installed in your LD_LIBRARY_PATH
search path, or in /usr/lib
Now we tried adding the environment variable "LD_LIBRARY_PATH" on the roboRIO to point to liblvrt.so.15.0, but that didn't work. After, we copied liblvrt.so.15.0 to /usr/lib from /usr/local/natinst/labview/, our code did not seem to run upon startup without us manually running frcRunRobot.sh. But after running our code, what's strange is that there was an error for "CPUInformation.cpp" at line 405. Has anyone else here tried this at all? If so, did you come across these errors and how did you get across them?
After some more experimentation, it seems like when you copy liblvrt.so.15.0, the script that continuously runs frcRunRobot.sh gets hung somewhere and stops running until the file is deleted. Also adding the environment variable LD_LIBRARY_PATH to .bashrc (in /home/lvuser) and having it point to liblvrt.so.15.0's directory doesn't work.
This thread is also in the Java forum too, I just cross posted it to make sure I got both sides of the discussion.
Unread 12-04-2016, 17:13
aeastet aeastet is offline
Programming Mentor
AKA: Tim Easterling
FRC #6043 (Allegan Tigers Robotics)
aeastet is an unknown quantity at this point
Re: Using LabVIEW vision with Java code
You might have to re-register Vision. We had to do that to ge tit to work.
Unread 14-04-2016, 21:06
Lorenzo334's Avatar
Lorenzo334 Lorenzo334 is offline
Lorenzo Guerra
AKA: Lorenzo
FRC #4063 (TRikzR4kidz)
Rookie Year: 2015
Lorenzo334 is an unknown quantity at this point
Quick question why don't you guys just run full LabVIEW code? What I mean is to just program your robot in LabVIEW or Java altogether.
With thanks,
Lorenzo Guerra
Programmer (Labview)
Team 4063
Unread 14-04-2016, 22:29
Landonh12's Avatar
Landonh12 Landonh12 is offline
270 points
AKA: Landon Haugh
FRC #0364 (Team Fusion)
Landonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud of
Are you saying that you are trying to run both Java and LabVIEW at the same time on your RoboRIO? That doesn't sound good to me...
Could you post code so that it's easier to debug? Are you using the LabVIEW vision example to process images on the RoboRIO?
Why don't you run your vision code in a custom LabVIEW dashboard and then send back values to the Java code (on the RoboRIO) over NetworkTables? That would free up some resources on the RoboRIO and then it would allow you to fine tune your HSV and Score values on the fly.
Team Fusion 364 - Driver/Programmer 2012-2015; Controls Mentor 2016-Present
Unread 15-04-2016, 18:13
JeffB JeffB is offline
FRC #5052 (RoboLobos)
JeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to behold
They haven't been back. But, I suspect they are trying to use NI Vision with the text-based API. It's one of the three installation configurations available.
1) Install LabVIEW for everything.
2) Install NI Vision for work with Java or C++
3) Only install the driver station and handle the rest.
