Re: Right Angle Adapter for VersaPlanetary Gearbox
Is that a 775 proXL?
Does it have 4/3 the power because it's longer? Where can I get mine? /s |
Great idea! Seems like a lot of extra broaching though
Is there a reason not to use a nut driver like this to connect to 1/2 hex shaft? Is there too much slop in these nut drivers? |
Very cool build, I'd never thought of using that Dewalt drive.
I love the detail in the step by step: Quote:
This is so cool! Thanks for sharing!
We actually used a very similar design for our intake.
Kinda blurry, but those vertical wheels are being powered through a similar design. Ours is actually belted through a custom gear box, then belted again! |
Definitely bookmarked for future use. Thanks for sharing Jim!
#7
VEX Pro request - 1/4" hex Versaplanetary output shaft.
Pretty slick Bees, great write up! |
#8
It would have to be steel or titanium otherwise it would fail easily because of the torque. It would be even weaker than the CIM motor output shaft, which fails at 29 N-m.
I hope that VEXpro will come out with their own right angle adaptor with 1/2 hex output with replaces the conventional output stage of the VP as it would greatly enhance the way they can be utilised. Last edited by pilleya : 12-04-2016 at 21:01. |
#9
Another great design from the Bees.
#10
Awesome! I'll have to remember that these right angle adapters exist, nice little product.
Instead of broaching, I wonder if using a socket adapter for a drill (like this) and a 1/2" socket would be more feasible for most teams. |
#11
Should always read all the way to the end. Code:
You can use this same Dewalt adapter in many other robotics applications. These are some of the many things we have done: 1. Use a standard 1/2" socket adapter and a bronze bushing to create a 90 degree drive to 1/2" hex. 2. Broach a 1/4" bore XL timing pulley and provide bearing support on both sides of adapter for a compact belt drive solution. 3. Create a small hex-hex plug to adapt standard VexPro Hex-core Sprockets and Gears. All sorts of other things are also now possible: The 1/4" hex drive is a universal interface in power tool interfaces. Pivot drives, flex shafts and all sorts of other adapters are now available to use once you have a Versaplanetary gearbox which accepts a 1/4" hex drive. Good Luck in all your robotic creations! |
#12
Looks like that's referring more towards the output of the gearbox, but I guess it's all the same kind of interface. I think it would be useful on the Versaplanetary side as well.
You could use McMaster parts 52735a21 and 5543A29 (totaling just under $8) to adapt the Versaplanetary to the DeWalt gearbox with no machining at all. ![]() |
#13
Very cool! We may want to use this at some point in other applications.
