You're so Vexy.
Unread 12-04-2016, 18:47
Type's Avatar
Type Type is online now
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
TIG Welder at Worlds
We noticed some welds starting to crack after out last competition. We are thinking of quick fixes to get by through state, but if we continue to world's, is there any teams that are bringing a TIG welder for aluminum that we could use? It wouldn't take long, just about 6 short welds.
3452- Lead Builder/ Pit Boss
*My posts do not reflect the opinion of my team*
Unread 12-04-2016, 18:58
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: TIG Welder at Worlds
I would have serious safety concerns about operating any kind of welder in a team's pit. The on site machine shop may be able to do some welding for you, though.
2016: Lake Superior WFFA
pilleya's Avatar
pilleya pilleya is offline
Head Cheesecake Chef
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
The machine shop run by NASA at champs is really good, they have TIG welding equipment among a lot of other things. They won't let you do the welding yourself, but you can just show the guys what you want done and they do it. The welds we got by them last year, were really really good, they TIG welded a piece of broken 10mmx20mm thin wall Aluminium tube back together for us for our can burglar had no more problems with it.
I'm sure they'll be able to help you with whatever you need welding.
Unread 12-04-2016, 19:08
TikiTech's Avatar
TikiTech TikiTech is online now
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
We had to have some welding done on our aluminum frame a few years back at the championships. They have all the equipment and knowledge to fix you right up.
Warning. Welding while you still have electronics installed can be catastrophic to them. The machine shop folks will warn you of this and in addition will not be held responsible if said electronics are damaged..
If you are able to, remove what electronics you can. We were not able to remove our electronics board due to time constraints, had to rush to the field as it was after the fix. Luckily we keep a majority of our electronics on Lexan sheets and we didn't have any damage.
Just be aware it certainly could.
Good luck at Champs!
Aloha!
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 12-04-2016, 19:13
Type's Avatar
Rookie Year: 2016
Thank you all! If we found a welder to use, it wouldn't be used in the pits, we would try to take the part outside.
Unread 12-04-2016, 19:18
pilleya's Avatar
The trouble is that at Champs there aren't exactly a lot of outside areas which would be suitable for welding in. Because of the amount of people inside and outside the venue, I don't think it would be at all possible to do this. The venue staff would definitely say no to this. Nobody wants kids who may not have been exposed to the dangers of welding to get Arc Eye (I have had Arc Eye, it is not fun).
But the machine shop can do this, and yes as TikiTech said, be careful with your electronics
Unread 12-04-2016, 19:41
daliberator's Avatar
daliberator daliberator is offline
Ace Machinist
AKA: Henry O'Callaghan
FRC #4536 (MinuteBots)
daliberator will become famous soon enoughdaliberator will become famous soon enough
Originally Posted by FIRST 2016 Admin Manual
Please adhere to the following safety rules regarding Pit safety and tool use:
■ Tools that throw sparks are prohibited.
Examples: Electric welders, bench grinders and angle grinders.
According to the admin manual, the only TIG welding you could do would be in the machine shop. Luckily, they only ban electric and torch welding, so you can still safely cold weld your chassis back together
4536 Team Captain
www.minutebots.org
Unread 12-04-2016, 20:45
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Since you cannot fabricate outside the pits the machine shop is the only option.
Unread 12-04-2016, 20:50
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I'm not sure why you'd want to use anyone other than the NASA shop. They have the right equipment and experience to get the job done for you quickly and with high quality.
2001-2004: Team 100
2006-Present: Team 254
Unread 12-04-2016, 21:18
Kyler Hagler's Avatar
Kyler Hagler Kyler Hagler is offline
Jack of all trades
Kyler Hagler has a spectacular aura aboutKyler Hagler has a spectacular aura aboutKyler Hagler has a spectacular aura about
Aloha!
In the past we have been in a crunch we wrapped all of our electronics in aluminum foil... Not sure if it did much but it definitely didn't mess our electronics up!
Kyler Hagler - 3310 Alumni/Mentor
Black Hawk Robotics Team 3310
2012 Dallas West Regional Winner
2013 Dallas Regional Winner
2014 Colorado Regional Winner
2015 Hub City Regional Winner
2016 Arkansas Regional Winner
2016 Hub City Regional Winner
Http://Team3310.com
Unread 12-04-2016, 23:24
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Ignoring T17, how would you find enough power for an arc welder outside?
Unread 12-04-2016, 23:28
pilleya's Avatar
It's isn't too uncommon to find power sockets in outside areas, in Sydney anyway. Long extension cable?
Unread 12-04-2016, 23:34
cgmv123's Avatar
AKA: Max Vrany
Welders need more than a standard NEMA 5-15 receptacle.
Unread 12-04-2016, 23:39
pilleya's Avatar
ARC/MIG/TIG welders run just fine off the standard household powerpoint (240v@10amp) in Australia. Maybe there wouldn't be able to get enough current to do larger jobs, but I've never had any problems with ARC Welding at home again(240v)
What's the standard max current output for US powerpoints?
Unread 12-04-2016, 23:43
cgmv123's Avatar
AKA: Max Vrany
110~120 VAC @ 15 A.
