Go to Post #TeamFrank - Libby K [more]
  #46   Spotlight this post!
Unread 12-04-2016, 16:14
Road Rash's Avatar
Road Rash Road Rash is offline
School of Hard Knocks
AKA: David Voss
FRC #5586 (Bond Brigade)
Rookie Year: 2016
Road Rash is on a distinguished road
Re: Compressed air for rapidly cooling *circuit breakers*?
Originally Posted by Ryan_Todd View Post
[SNIP]
My mind is blown.
I'm just worried about an ice-pack in a first aid kit.
"It is better to remain silent and be thought a fool than to open one's mouth and remove all doubt."
  #47   Spotlight this post!
Unread 12-04-2016, 16:15
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Compressed air for rapidly cooling motors?
Originally Posted by techhelpbb View Post
I really thought this topic was going to about pneumatic vortex coolers.
I just found out about those a couple years ago. So cool.
  #48   Spotlight this post!
Unread 12-04-2016, 19:02
Aren_Hill's Avatar
Build Nifty Things
And we've got one, tis quite nifty.
-Aren
A guy who likes robots.
  #49   Spotlight this post!
Unread 12-04-2016, 19:14
Ken Best's Avatar
Ken Best Ken Best is offline
FRC #0011 (MORT)
Ken Best is a splendid one to beholdKen Best is a splendid one to beholdKen Best is a splendid one to beholdKen Best is a splendid one to beholdKen Best is a splendid one to beholdKen Best is a splendid one to beholdKen Best is a splendid one to behold
A few years ago, our team used a high output squirrel cage fan to cool the robot between matches, especially in the finals,,we not sure if it helped but there wasn't a problem. Where we know it did help was with the circuit breakers as the drive team knew that the cooler breakers eliminated lag. It also helped that we replaced all of the drive train breakers going into the finals. We were runner up finalists, so it didn't hurt.,, It's the little things that break you, stay after them.
2012- 3142, MAR Engineering Inspiration Award, St Louis
2013- Team Lionhart 1302, Mt. Olive Gracious Professionalism Award
2014- Team Lionhart 1302, MAR Clifton event Finalist
2015- MORT 11,
2015- Robot Inspector
2016- MORT11
2016- RI
  #50   Spotlight this post!
Unread 12-04-2016, 21:23
Could you please explain what lag you are referring to?
  #51   Spotlight this post!
Unread 12-04-2016, 21:47
Ken Best's Avatar
FRC #0011 (MORT)
They said they could notice the breakers tripping when they pushed someone, or similar, after they changed the snap action breakers, it was less noticeable. Consistently tripping breakers or running at close to their limit will weaken the bi metal strip.. allowing them to trip at less than the rated load.
2015- MORT 11,
2016- MORT11
2016- RI
  #52   Spotlight this post!
Unread 13-04-2016, 07:39
Ryan,
Thanks for the exercise. The main breaker resistance is actually much less than your guess by a factor of 100 though. A new breaker that has never tripped (resulting in some pitting of the contacts) will have a series resistance in the .0005 range (verified at Motorola labs a few years back). The battery is capable of 600 amps at full charge albeit at reduced terminal voltage due to the internal resistance of the battery. I was unclear if you included heat dissipation in the wiring connected to the breaker. I believe that is a sufficient source of heat loss as it increases the surface area exposed to ambient air making the return to ambient for the breaker even less than calculated. It is great to know my hunches are backed up with math. Cool!
  #53   Spotlight this post!
Unread 13-04-2016, 10:38
Ryan_Todd's Avatar
Ryan_Todd Ryan_Todd is offline
ye of little faith
Ryan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond repute
--snip--
Excellent, I knew that someone on here would have an actual number for this! I'll probably update my math sometime later when I get a chance.
As for dissipation through the wires, my numbers are based on published data from the manufacturer. I expect that it is safe to assume that the manufacturer's test rig included appropriate-gauge wires, and therefore that their data therefore includes heat dissipation through said wires, but it would indeed be preferable to know more about how they gathered that data.
The ideal thing would be to gather some data firsthand using a test rig that is specifically designed to replicate the conditions found on an FRC robot (match the wire gauge, crimp and terminal styles, wire length, and air circulation)... For now, however, I'm content in the knowledge that my current level of precision is good enough to get a working idea of what's actually going on inside the breaker.
  #54   Spotlight this post!
Unread 13-04-2016, 22:48
Just another hunch, but I would guess they might use some really big wire to reduce the resistive losses at high current. I have not broken the breaker base to see what the size of the conductors is between terminals and internals.
