#16
Re: Right Angle Adapter for VersaPlanetary Gearbox
Should always read all the way to the end. Code:
You can use this same Dewalt adapter in many other robotics applications. These are some of the many things we have done: 1. Use a standard 1/2" socket adapter and a bronze bushing to create a 90 degree drive to 1/2" hex. 2. Broach a 1/4" bore XL timing pulley and provide bearing support on both sides of adapter for a compact belt drive solution. 3. Create a small hex-hex plug to adapt standard VexPro Hex-core Sprockets and Gears. All sorts of other things are also now possible: The 1/4" hex drive is a universal interface in power tool interfaces. Pivot drives, flex shafts and all sorts of other adapters are now available to use once you have a Versaplanetary gearbox which accepts a 1/4" hex drive. Good Luck in all your robotic creations! |
#17
Very cool! We may want to use this at some point in other applications.
Looks like that's referring more towards the output of the gearbox, but I guess it's all the same kind of interface. I think it would be useful on the Versaplanetary side as well.
You could use McMaster parts 52735a21 and 5543A29 (totaling just under $8) to adapt the Versaplanetary to the DeWalt gearbox with no machining at all. ![]() |
#19
