Go to Post I'll wait for someone else to do it, then disagree with whatever they say. :p - Jcarbon [more]
Unread 13-04-2016, 12:46
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Re: Right Angle Adapter for VersaPlanetary Gearbox
Originally Posted by s_forbes View Post
Awesome! I'll have to remember that these right angle adapters exist, nice little product.
Instead of broaching, I wonder if using a socket adapter for a drill (like this) and a 1/2" socket would be more feasible for most teams.
Should always read all the way to the end.
You can use this same Dewalt adapter in many other robotics applications.
These are some of the many things we have done:
1. Use a standard 1/2" socket adapter and a bronze bushing to create a 90 degree drive to 1/2" hex.
2. Broach a 1/4" bore XL timing pulley and provide bearing support on both sides of adapter for a compact belt drive solution.
3. Create a small hex-hex plug to adapt standard VexPro Hex-core Sprockets and Gears.
All sorts of other things are also now possible:
The 1/4" hex drive is a universal interface in power tool interfaces. Pivot drives, flex shafts and all sorts of other adapters are now available to use once you have a Versaplanetary gearbox which accepts a 1/4" hex drive.
Good Luck in all your robotic creations!
The sooner we get behind schedule, the more time we have to catch up.
Unread 13-04-2016, 13:48
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Very cool! We may want to use this at some point in other applications.
Definitely might be a good option.
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 13-04-2016, 14:33
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Looks like that's referring more towards the output of the gearbox, but I guess it's all the same kind of interface. I think it would be useful on the Versaplanetary side as well.
You could use McMaster parts 52735a21 and 5543A29 (totaling just under $8) to adapt the Versaplanetary to the DeWalt gearbox with no machining at all.
Unread 13-04-2016, 16:40
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Or just a single piece nut driver
