Go to Post My most distinct memory was watching Tom fix our robot's frame... by whacking it with the hammer. - Jaine Perotti [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 13-04-2016, 17:01
hutchMN hutchMN is online now
2502 alumnus
FRC #4360
hutchMN has a spectacular aura abouthutchMN has a spectacular aura abouthutchMN has a spectacular aura about
Can a 8th seed knock off a 1st seed at champs?
Is it reasonable for an 8th seed to knock off a 1st seed at champs this year? If yes, what will be the ideal strategy, and alliance makeup for the 8th seed?
I personally believe it's possible, I believe the ideal strategy will be to pick the best 2 offensive robots available (and a defensive 4th robot), and here is why: 1) The 8th seed will be able to select two decent high goal scorers to join them; the 8th seed should go all offense due to the dominant, unblockable, high goal scorers that will be picked in early part of the first round. Defense will have very little effect on these super-efficient outerworks shooters, devaluing a defensive robot. 2) Defense becomes less of a factor when you introduce a third offensive robot. Most of the best outerworks shooters will be gone by the 8th pick, so the robots on the 8th seed could be susceptible to defense. Splitting the defense 3 separate ways will help some of the easier to defend against shooters get their shots off. 3) Having 3 offensive robots will help you control more of the boulders, and in return, possibly causing boulders to become a semi limited game piece. This could help keep the game a lot closer, leaving the game to be decided by who can scale. 4) You will be able to find a high level defense robot anywhere in the draft at champs. An alliance will be able to pick a very good defensive robot with the 4th pick, but will have a hard time finding an offensive robot with the same pick. I would love to hear what you think the makeup of the 8th seed alliance will be.
Unread 13-04-2016, 17:10
The other Gabe's Avatar
The other Gabe The other Gabe is offline
Too many events, not enough time
AKA: I'm a volunteer now!
no team (2046 Bear Metal Alumn)
The other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud of
Re: Can a 8th seed knock off a 1st seed at champs?
http://www.thebluealliance.com/event/2016pncmp
happened at DCMP, dont see why it couldn't at CMP
Do the best you can with what you are given
FRC 2046 2012-2015
Field Scout lead 2014-2015
Unread 13-04-2016, 17:12
Ginger Power's Avatar
Ginger Power Ginger Power is online now
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
2 vs. 0 and 3 vs. 1
Having 4 robots in a courtyard in your hypothetical 8 seed vs. 1 seed match up doesn't seem like like it would end well for the 8 seed. Letting the top 2 offensive robots on your division drive free of defense doesn't seem like a good idea. The 1 seed would quickly put the tower on an endless loop and steal from the secret passage. There's no way 3 robots on the opposing alliance could keep up with a defensive robot doing its thing. I think most alliances will need a presence in the opposing courtyard to prevent close-looped scoring.
I suppose the 3 offensive robots could cycle back to the secret passage (they'll need to anyways when boulders run out) and prevent a closed loop that way. It's still going to be difficult to out gun 2 undefended robots with 3 lower quality defended robots.
This is also assuming that the top robot on a division will be an unblockable outer works shooter. While this is the likely scenario, considering the breach rate should be close to 100%, crazy things happen.
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns Project Lead:
Reveal Video
White Paper
Unread 13-04-2016, 17:15
Alyssa's Avatar
Alyssa Alyssa is offline
Everything in life should be MFD
AKA: Alyssa Vallese
FRC #0125 (NUTRONS)
Alyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond repute
We did it on Archimedes at Champs 2014. You never know what could happen, regardless of the game. I've definitely been guilty of giving up hope as an 8th seed as well as been a bit too confident as a 1st seed... https://www.youtube.com/watch?v=hxA98sbviyo
"Any sufficiently advanced technology is indistinguishable from magic." -Clarke
2012 - 2016; FRC Team 2485 The W.A.R. Lords (We Are Robot)
2016 - Present; FRC Team 125 NUTRONS
Feel free to PM me via Facebook or email!
If you PM me via Chief I probably won't see it for a while...sorry
Unread 13-04-2016, 17:16
Rangel's Avatar
Rangel Rangel is offline
John Rangel
FRC #0842 (Falcon Robotics)
Rangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond repute
I think any type of strategy could work depending on the robots you are with vs the robots you are against. Overall though, I think its not a good idea to rule out defense altogether. A mix of defense and offense is critical this year thanks to the secret passage ball returns. Whether that's three shooters playing a mix of offense and defense or 2 offense and one dedicated defender, anything can be effective. If you were to put 3 purely offensive robots vs 2 of the best shooters and a defender/feeder, I think it could go either way to be honest. It's going to come down to what works best for your alliance based on the robots that are left followed by solid execution.
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
Unread 13-04-2016, 17:24
BenHildy's Avatar
BenHildy BenHildy is offline
Eyes in the Sky
AKA: Ben Hildebrandt
FRC #2169 (KING TeC)
Team Role: Tactician
BenHildy is on a distinguished road
Personally, I believe this could happen. It nearly occurred at North Star, which I attended, and has happened before. This year, the strategy needed will be a very specific one. The upsets that have occurred this year so far have usually been either a couple low goal (or efficient high goal) cyclers whose main focus is to capture the tower, or a "diamond in the rough" team that has evaded selection from the other teams and creates a very competitive robot alliance. I will be focusing on the former. A couple climbers are always helpful to that strategy too.
A defense robot can be either extremely effective or almost useless based off of the opponents. For example, many high goal cyclers that would be in that #1 alliance can easily shoot over a 4' 6" robot. However, a powerful nudge at the right moment can ensure a team never makes a shot. Most high-level teams will continue trying to make that high shot rather than going low goal, and the time it takes one good high goal shooter to make a shot against formidable defense could provide one very efficient low goal cycler to make two or three shots. A choking strategy can always work too, as many teams did in 2010 and 2012 where a team simply takes balls across the defenses while they work towards the breach and another simply takes them and scores them without the hassle of crossing defenses. These are the two strategies that I've seen work most effectively against top-tier high goal shooters. Anyways, that's just my two cents' worth.
Unread 13-04-2016, 17:30
alephzer0's Avatar
alephzer0 alephzer0 is offline
Technical Generalist
AKA: Nathan Simon
FRC #1257 (Parallel Universe)
alephzer0 has much to be proud ofalephzer0 has much to be proud ofalephzer0 has much to be proud ofalephzer0 has much to be proud ofalephzer0 has much to be proud ofalephzer0 has much to be proud ofalephzer0 has much to be proud ofalephzer0 has much to be proud ofalephzer0 has much to be proud ofalephzer0 has much to be proud of
I bet this isn't the only example of an 8 seed that not only won its division, but also on Einstein.
Nathan Simon
FRC Team 1257: Parallel Universe
2016: Mt. Olive district champs with 5624 and 1676, Bridgewater-Raritan finalists with 25, 3340, and 555, MAR DCMP winners with 225 and 341.
2015: North Brunswick District Finalists with 11 and 193.
2014: Clifton District Champs with 1626 and 869, 2nd seed alliance captain at MAR regional champs.
There are 10 types of people in the world: those who can read binary, and those who can't.
Unread 13-04-2016, 17:48
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is online now
FRC #4536 (MinuteBots)
The likelihood correlates well with how many quals matches we get.
Unread 13-04-2016, 17:53
the_godfaubel's Avatar
the_godfaubel the_godfaubel is offline
College Mentor
AKA: Aaron Faubel
FRC #1208 (Metool Brigade)
the_godfaubel is a splendid one to beholdthe_godfaubel is a splendid one to beholdthe_godfaubel is a splendid one to beholdthe_godfaubel is a splendid one to beholdthe_godfaubel is a splendid one to beholdthe_godfaubel is a splendid one to behold
I'm going to go out on a limb and say it will happen (#BoldPredictions). Everyone will presumably take the best available shooter in the first, thus leaving the defensive bots for the 2nd and/or 3rd round of selections. If 8 takes the best available shooter, they also get first dibs on the defensive bots. They get the best defensive bot there is and one that can probably climb, reliably cross 1 or 2 classes of defenses in autonomous, and potentially score in auto. Assuming the 8th alliance captain is a somewhat reliable shooter, that's a pretty dangerous alliance. If it's the right alliance, I could see 180-210 points being scored, which is more than enough to beat a #1 alliance.
Plus, declined alliances happen and might lead to a really good team being the 8th alliance captain.
Student: 2011-2014
Mentor: 2014-Present
Driver: 2014
Pit Crew: 2013-2014
2013 St. Louis Regional Winners w/3284 and 2408
2016 Iowa Regional Winners w/5172 and 525
Unread 13-04-2016, 18:01
Rangel's Avatar
John Rangel
The opposite could definitely hold true as well though. Some divisions may be really deep or alliances scout completely incorrectly and 1st alliance ends up getting a solid shooter as their second pick. The two best shooters(probably unblockable) in the division plus one of the best shooters as a third robot. Not to mention they would all be solid drivers and I'm not sure there is any stopping that kind of alliance no matter how good the defense may be. Alliances like these have happened plenty of times and went all the way before as well.
2014-? Mentor
Unread 13-04-2016, 18:56
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
Note: I'm going to try to write this without tooting my team's horn
We were the 8th seed alliance at PNW DCMPs, and we beat the 1st seed alliance (like The other Gabe said in the 2nd post in this thread). We did it with very brutal defense. The other alliance had a good high goal shooter, a fast low goal shooter, and their own defense bot. Our team decided to be the defense bot and our driver is very good (in my opinion).
I think it could happen at Champs, but only if there is an amazing defense bot, and if that alliance can score faster than the other alliance (even while under defense).
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
Unread 13-04-2016, 19:22
Professional Stat Padder
Can it happen? Absolutely. 1 seeds have been knocked out in quarters a whole bunch of times at champs.
Your breakdown? I don't necessarily agree with. A number of different robots can seed first, including very defensible machines. Additionally, their first overall selection may not be an unblockable shooter as well.
Take 254, for example. I'd bet my money that they'll be on one of the top 3 alliances in their division at worst. They're very difficult to keep from scoring a ton of boulders, but if left to their own devices, with no defense, they've proven they can score 17 boulders in teleop on their own (this was a practice match, but it encapsulates a lot of what I'm trying to convey).
When playing against a machine like 254's, you almost have to defend them, or you almost certainly lose.
That being said, everyone likes an upset (except those being upset), and I'd love to see some scrappy 8 seed prove me wrong (or right), and take down the powerhouses.
(2015-Present)
Unread 13-04-2016, 20:09
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
Why a No 8 might knock of a No 1 this year? There's been a surprising number of rookies getting to No 1 in competitions this year. The ranking rewards working with your alliance members to get some level of RPs, and that's pulled teams into alliance captains that would not have made it in previous years based solely on win records. So a No 1 may not be the best bot for the elimination rounds but was set up well to qualify high. Gotta get to the ball before ya can dance...
Unread 13-04-2016, 20:17
Charles Boehm's Avatar
Charles Boehm Charles Boehm is offline
Build Team Lead, Weapons Officer
AKA: Charles
Charles Boehm is a jewel in the roughCharles Boehm is a jewel in the roughCharles Boehm is a jewel in the rough
I remember that quite vividly It is definitely possible. (Well done by the way )
Achievements since I joined
2016 Minnesota North Star Regional - Winners (Thanks 3130 and 3042) -Industrial Safety Award - Gracious Proffesionalism Award
2014 Minnesota State Champions - Rank #1 (Thanks 2052 and 4778)
2014 Archimedes Division - Quarter finalists (Thanks to 399 and 2056)
2014 North Star Semifinalists (Thanks 967 and 4607) - Creativity Award - Safety Award
2014 Northern Lights Winners (Thanks 359 and 2502) - Excellence in Engineering - Safety Award
2013 Minne-Mini Winners (Thanks 2169, 3883, and 4239)
2013 MRI Winners (Thanks 2052, 3130, and 3313)
2013 MN State Fair Winners
2013 IRI Participant
2013 Minnesota State Championship - Winners (Thanks 2052 and 4607)
2013 Galileo Division - Finalists (Thanks 2169 and 3284)
2013 North Star Regional - Winners (Thanks 967 and 4607) - Team Spirit Award
2013 Northern Lights Regional - Quarterfinalists (Thanks 3130 and 1675!) - Entrepreneurship Award
Unread 13-04-2016, 22:01
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Shoot, if you go back further, the 2007 winners started as the #8 alliance on their field.
Not common, but possible. Look at it this way: If your #8 alliance beat the #1 fair and square and through "winning" (as opposed to the #1 alliance "losing"), then what does that say about your alliance? You've proven yourself, and at that point I wouldn't be that surprised if you made it all the way. Sometimes teams get underanked and if the field is sufficiently deep then you'll always end up with two good bots for #8 to pick, simply because there were 7 others who were also good and happened to get picked earlier.
