Go to Post Dr. Doom becomes Dr. Awesome! - Nick Lawrence [more]
Unread 04-13-2016, 12:58 AM
bdaroz's Avatar
bdaroz bdaroz is offline
Programming Mentor
AKA: Brian Rozmierski
FRC #5881 (TVHS Dragons)
Rookie Year: 2016
bdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud of
Re: Wiring in general help
Originally Posted by juju_beans View Post
Do you happen to have the files for the 3D printed PWM thing?
One of our students printed us a few this year -- I believe he got them off GrabCAD, but I don't have the links. (It may have been sourced from a CD thread, I'm not sure.)
Unread 04-13-2016, 02:17 AM
hectorcastillo's Avatar
hectorcastillo hectorcastillo is offline
Former Driver and Team Captain
FRC #3481 (Bronc Botz)
hectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to all
Here you go:
https://grabcad.com/library/roborio-...tention-clip-1
365 The Decontaminators (FLL) 2011 - 2012
3481 The Bronc Botz (FRC) 2012 - Present
6221 Panther Bots Alpha (FTC) 2012 - 2016
As a FIRST Alum, it's nice to be able to eat dinner again. That is, until I get off the meal plan and have to start feeding myself.
Unread 04-13-2016, 09:09 PM
juju_beans's Avatar
juju_beans juju_beans is offline
FRC #3647 (Millennium Falcons)
Rookie Year: 2016
juju_beans is an unknown quantity at this point
Originally Posted by hectorcastillo View Post
Thank you so much!
Unread 04-13-2016, 09:47 PM
Alyssa's Avatar
Alyssa Alyssa is offline
Everything in life should be MFD
AKA: Alyssa Vallese
FRC #0125 (NUTRONS)
Alyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond repute
https://www.facebook.com/FRCTeam2485...type=3&theater
Our system focuses on being able to "read ones work." Even if something is routed underneath the panel for cleanliness, the wires are all color coded and if someone that didn't wire the panel isn't able to at least read where the wires go to, then it needs to be redone. We also have the luxury of being able to build two bots, so more experienced students wire the first panel and rookies gain experience by having ownership of wiring the entire second panel themselves.
Zipties are king.
"Any sufficiently advanced technology is indistinguishable from magic." -Clarke
2012 - 2016; FRC Team 2485 The W.A.R. Lords (We Are Robot)
2016 - Present; FRC Team 125 NUTRONS
Feel free to PM me via Facebook or email!
If you PM me via Chief I probably won't see it for a while...sorry
Unread 04-13-2016, 09:51 PM
Alyssa's Avatar
AKA: Alyssa Vallese
FRC #0125 (NUTRONS)
If you have any other questions feel free to PM me, I was Electrical Lead for 2 years on my team before I was VP of Build, and cleanliness is one of my huge things.
Unread 04-13-2016, 10:35 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by Mark McLeod View Post
Make every status light easily visible from some distance away from the robot!
YES, YES, YES! Hidden status lights are the surest clues to poor wiring design. Hidden wires are about a half step behind - make your wires are easily visible and traceable.
Unread 04-14-2016, 05:49 PM
davidaly46's Avatar
davidaly46 davidaly46 is offline
Electrical Engineering - UT Dallas
AKA: David Aly
FRC #0148 (Robowranglers)
davidaly46 is a splendid one to beholddavidaly46 is a splendid one to beholddavidaly46 is a splendid one to beholddavidaly46 is a splendid one to beholddavidaly46 is a splendid one to beholddavidaly46 is a splendid one to beholddavidaly46 is a splendid one to behold
148 design philosophy always centers on function, but form is not too far behind. From my years on pit crew and build team, here are some handy things i would recommend:
- NEVER make a wiring decision that could compromise the function of the system just to make it look a little better.
- Label.....label...label..label. LABEL!
- Use your time spent prototyping to get a feel for how your electrical system will come together, prototyping helps in more ways than just mechanical.
- Building a flexible system should be a high priority. Making extremely long runs through mechanical systems that have the potential to be replaced often, or even worse are designed to be removable, will make changes to the robot even harder. Liberal but efficient use of push and ring terminals will make these situations almost a breeze (if such a thing exists in FRC).
- Having a dedicated electrical team, or "sparkies" as they are referred to on 148, can be HUGELY beneficial. One or two mentors and a handful of students focusing on electrical/pneumatic systems will do wonders for your build and competition season.
- Have a dedicated section of your pit or workshop for housing electrical components and tools. This will help streamline your design and maintenance of the electrical systems.
- Using diagrams early in the build process, in my experience, tends to become rather useless. Electrical and pneumatic systems need to be dynamic in nature in order for mechanical systems, which determine much of your robot's performance, to be enhanced or changed at a moments notice. A better use of a diagram, or EE CAD file, would be to have one in your pit in order for students to become familiarized with the electrical system as the competition season progresses or for older robots whose systems wont change and just need to be maintained.
- Always carry zip-ties of a some form/shape/size in your pit as they are infinitely useful, and we have blown through hundreds at a single event. Luckily they are extremely inexpensive.
These are just a few of the big points i would tell a team looking to improve their electrical systems. I hope you think they are useful!
Unread 05-29-2016, 08:24 PM
Phred7's Avatar
Phred7 Phred7 is offline
Team President
AKA: Walker Ward
FRC #2906 (Sentinel Prime)
Team Role: Electrical
Phred7 is an unknown quantity at this point
Here are some various links to 3D printable parts for your RoboRIO;
http://www.thingiverse.com/thing:1380606
http://www.yeggi.com/q/roborio/?s=tt
http://www.yeggi.com/q/frc+robotics/2/
http://www.aipos3d.com/printable-3d-...by=field_views
I for one printed the first link but any should work.
Spanaway Lake High School
-FTC 5328 (14-18)
-FRC 2906 (15-18)
-2015-17 Team President
