Go to Post I want to use some of that mass-less rod in our robot - saves weight. - ebarker [more]
Unread 13-04-2016, 23:56
BSV BSV is offline
FTC / FRC mentor
AKA: Travis
FRC #2723
BSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud of
[FTC]: Homebrew Power Distribution Module
Hi there,
We have some Anderson Powerpole power distribution blocks (the old version of this: https://powerwerx.com/8-position-pow...ribution-block)
We also have a couple of unused powered USB hubs.
For an offseason demo FTC robot, would it be reasonable to add a 12V-to-5V converter to step down the voltage from a battery (using something like this: http://www.amazon.com/Nextrox-Conver.../dp/B00A71CMDU) to power the hub, and then just connect our ZTE speed to the hub along with any motor controllers?
I don't really want to dump $90 more into a PDM when we can hack something together for much cheaper. What am I missing?
We have several old Hitechnic motor controllers, so are thinking about making some small demo robots using our spare (unused) Core Legacy Modules.
Unread 14-04-2016, 00:24
aklego aklego is offline
FTC #3595 (Schrödinger's Hat)
aklego is just really niceaklego is just really niceaklego is just really niceaklego is just really nice
Re: [FTC]: Homebrew Power Distribution Module
I believe you can power the Legacy module directly from the phone and completely bypass the need for the hub and voltage converter.
let tau = 2pi
Unread 14-04-2016, 10:10
wgardner's Avatar
wgardner wgardner is offline
wgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to behold
We have a JV rookie team that did this for prototyping and scrimmaging this year and it worked great. They connected the USB cable direct from the phone to the Legacy module. They used an Anderson Powerpole distribution block to split the power out from the battery switch to all legacy motor and servo controllers.
CHEER4FTC website and facebook online FTC resources.
Providing support for FTC Teams in the Charlottesville, VA area and beyond.
Unread 14-04-2016, 10:15
BSV BSV is offline
FTC / FRC mentor
AKA: Travis
FRC #2723
With ZTE Speeds now only $20, we can make several demo robots for almost no cost to us. I wonder how long the phone battery will last between charges, though?
Thanks for the advice! We'll try this out soon.
Unread 20-04-2016, 09:51
ftcTeam6389 ftcTeam6389 is offline
FTC #6389
ftcTeam6389 is on a distinguished road
Hi,
We run our Krazy Kubes outreach game with the ZTE speed phones quite a bit, and have found that they last up to 5-6 hours on a single full charge for both the RC and DS.
- The Lazybotts
Unread 21-04-2016, 21:10
BSV BSV is offline
FTC / FRC mentor
AKA: Travis
FRC #2723
Originally Posted by ftcTeam6389 View Post
Hi,
- The Lazybotts
Great, thanks for the info.
When we joined the program last year, all the electronics were a few years old and in really bad shape (there are 3 FTC teams, here). So we purchased all new motor controllers and stuff as we raised enough funds. Then, of course, the new stuff came out, which means we have a pretty good amount of old electronics in good shape. We'll likely replace the ZTE speeds on all the competition 'bots with something else (one of them already has Moto G2s) and use the ZTEs for the outreach bots.
The summer is going to be fun. Lots of stuff to do.
