Go to Post The events are not just a competition, but a celebration of 6 weeks of hard work. - ChristinaR [more]
Unread 14-04-2016, 13:09
abhishekmalle's Avatar
abhishekmalle abhishekmalle is offline
FRC #5109
abhishekmalle is an unknown quantity at this point
Is CAD essential to all teams?
A little preface:
So my team in the transition phase of trying to reach a level of "legit-ness" for next season. Over the past three years, we have been a group of kids that have turned out a robot each season, but with real struggle and a lack of planning. We usually have an idea of our general design, but almost all of the specifics usually happen somewhere along the way. The point being that we end up working very long days and stressed till the last minute of build season.
Is CAD the next needed step in order for us to become successful?
Our team currently has absolutely no background in CAD. And also no mentors. If we were to decide to use CAD next year, I would have to learn the software from scratch and then teach it to members in the off-season of next year.
The other option for us is to have hardcore designs/drawings on paper. Would that be sufficient?
Unread 14-04-2016, 13:22
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
Re: Is CAD essential to all teams?
It is not required; however, it helps a lot if you can use CAD effectively.
FYI, this is the first year MOE has a CAD model of the robot that was used for a majority of the design.
There are many resources available, but my go-to is YouTube.
Unread 14-04-2016, 13:30
Philip Arola's Avatar
Philip Arola Philip Arola is offline
You can check out any time you like
AKA: KG7VAM
FRC #1510 (Wildcats), FRC #2898 (The Flying Hedgehogs)
Philip Arola is an unknown quantity at this point
You will need some cohesive, specific design if you want a world class robot. When my team has put CAD into the backseat of design, we fail. Now, as you point out, paper is perfectly acceptable. All you need is whatever works for your team, and stick with it. CAD is just extra convenient because you can import common parts. I would ask design or shop teachers if they want to help. Even if they can't help directly, they might be able to have a class with CAD.
Unread 14-04-2016, 13:33
Tcrump47 Tcrump47 is offline
Yeti 3506-CAD Team
FRC #3506
Tcrump47 is an unknown quantity at this point
I would say it is and is not essential. Personally being a certified solidworks user since the beginning of 2014 i would say its the easiest to learn. If you do it well enough you can have the basic design and parts list done and ready to order. It helps a lot with knowing what you are going to build if you have a design for it. Best of Luck
Unread 14-04-2016, 13:36
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
The answer is, no. You can build highly effective robots without CAD. It depends on how you build your robot. When I first started, we used chopsaws and hand tools. We didn't need CAD, just simple hand drawings. Now that we use CNC driven equipment, CAD is a must.
Unread 14-04-2016, 13:37
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
I think it really depends on your budget, both time and money.
In terms of time, working with new designers is CAD takes a lot of time. If you don't start designing early, it will take longer to design than to simply do. If you don't own a mill, why design things accurate to 0.001"?
I do highly recommend learning CAD purely for figuring out linkages and geometry, however. That's something easier done on a computer than by hand. I would avoid paper simply because it's more hassle for students than CAD in my experience. 973's RAMP has some good videos on it.
All that being said, your robots already look incredible! I think for the build quality that you're at right now, CAD could really help you get things more cleaned up, but it's not necessary. More important than CAD and design is good strategy.
If you do go the CAD route, a small mill will help you machine parts that are very accurate, so you can get more utility out of CAD.
JPL69's Avatar
JPL69 JPL69 is offline
FRC #3596 (Rocket Robotics)
JPL69 is an unknown quantity at this point
I agree, it is an added plus if you do use it. We have been using CAD for the last few years that I have been there, and this year we had very little CAD due to student commitments. We noticed the difference and did enough for the critical parts to make sure the design functioned properly. We have some new students that are interested in CAD now, and they are learning now (just because the competition is over, doesn't mean learning is over).
As far as "no experience in CAD", it is never too late to learn. Our team switched from Java to Labview two years ago, none of us knew how Labview worked. The students and I learned together as a team in the off season, and has strengthened our student/mentor ties. If you have dedicated students that want to learn CAD, do not be afraid to start with them and learn together.
Remember that this is all about learning and what they want to learn. Even if you don't use CAD, you will still have a robot either way.
BotDesigner's Avatar
BotDesigner BotDesigner is offline
Design/CAD/Strategy/TeamManagement
AKA: David Gedney
FRC #4418 (Team Impulse)
BotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud of
I do believe it essential that every FRC team should do some CAD. I am design lead on a somewhat low resource team and without CAD I don't know where we would be. CAD allows you to simulate mechanisms and find interference long before you start to build them. It is critical for designing things with low tolerances (think about keeping things within 15in of your frame perimeter or figuring out the necessary dimensions for a scaler).
Also, CAD is nice because you can easily do it outside of the workshop. My team has very limited meeting times,so I do most of my CAD work at home. We then get to spend our meetings manufacturing.
This year, about a week after bag and tag, we decided to modify our robot into a defensive shield thing. Although the robot was in the bag we were able to figure out (using CAD) a way to attach a extendible 70 inch wide 54 inch tall shield to bumper supports already on the robot. It took less than an hour to attach it at competition because we knew exactly every hole that had to be drilled and bolt that needed to be put in. There is know way we could have done that without using CAD.
Engineering drawings can be useful but you CAD in general is much easier and simpler to use when it comes to mechanisms. My advice is to find a CAD software and learn to use it. Try designing some robots this offseason and post them here. You will get great feedback.
Unread 14-04-2016, 13:42
Jash_J's Avatar
Jash_J Jash_J is offline
Lead Strategist
FRC #1241 (THEORY6)
Jash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud of
Saying CAD is essential in order to reach "the next level" is quite vague. There are many things that can be done in order to successfully have a 6 week build season but it starts from the ground up. Having the skills to CAD itself can help significantly, however it does not mean you will be successful. A good example of that is our team's robot in 2015. The entire robot was designed using CAD; however we failed to prototype effectively which ultimately lead us to believe that we could do more than we could.
If I could suggest one key aspect to build season that most teams should be capable of doing, it would be prototyping. Prototyping not only allows you to determine which mechanism would be best to solve that year’s game problem, but it also allows you to refine the idea until you have the best iteration of it. If then, you would like to CAD the prototypes and integrate them into one large robot that would be ideal, as you would find any integration problems before you reach your build phase. However, please realize that if you begin to CAD without any preliminary model to base your designs off of, it will be extremely tough to have a successful build season as there may be problems that occur once you have built the CAD model of your robot.
Jash Javeri
FRC Team 1241 - Mentor/Alumnus
2013 World Champions! (1241, 1477, 610)
"Coming together is a beginning. Keeping together is progress. Working together is success." - Henry Ford
"I'm a great believer in luck, and I find the harder I work the more I have of it." - Thomas Jefferson
Unread 14-04-2016, 13:50
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
No, it is not. 624 took a break from CAD in 2009 before returning to it in 2016. If you don't have any experience, it'll take time (maybe 2 years, one for you to get trained in a software of your choice and then another offseason to train others and develop an organization process - there are lots of resources to help with this, specifically 973 and 1114 have some good things to look at on their YouTube channels) to build up a system of using CAD effectively, so in the short term it will probably be better for you to stick with paper and pencil drawings with extensive dimensions. But eventually, as your team grows, your systems become more complex, and your resources expand - CAD will become a very useful tool for you to unlock a lot of potential.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 14-04-2016, 13:56
Mechvet Mechvet is offline
Certified Public Menace
FRC #0114
Mechvet is a jewel in the roughMechvet is a jewel in the roughMechvet is a jewel in the rough
Let's take a wider look at the question.
CAN you make a competitive, impressive robot without CAD, and still inspire students to pursue a career in STEM? Yes.
However, I firmly believe in not only inspiring the path into STEM, but also sending students armed with as many useful tools as possible. If you were to try to take a product to any reasonable production team on a napkin sketch, or even a simple paper sketch, you wouldn't get very far (excluding companies with drafters/modelers on hand for precisely this).
Arkive's Avatar
Arkive Arkive is offline
Kevin says "RTFM"
AKA: Alex Resnick
FRC #5109 (Gladiator Robotics)
Arkive is a glorious beacon of lightArkive is a glorious beacon of lightArkive is a glorious beacon of lightArkive is a glorious beacon of lightArkive is a glorious beacon of light
What would you suggest as a good balance time/resource wise between CAD and prototyping. We usually put a lot of time into prototyping but then we never put it into CAD to make sure it can fit with everything else. That hits our number one problem where our robot looks less streamlined and more cheesecaked than it should.
Unread 14-04-2016, 13:59
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Not necessary but highly useful. One tool that I will be using next year to help teach our freshmen cad is 1114's solidworks tutorials.
I binge watched them all one night and found that they would be extremely useful in teaching new students CAD from the ground up.
Unread 14-04-2016, 14:00
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
CAD is definitely a useful tool, and through FIRST you can access the industry standard programs with a ton of packages available for no cost to you or your team. Learning CAD can be a daunting task, but the best way to go about it is to download the program, watch some tutorials (973 RAMP has good videos, so does the SolidWorks website), and do a lot of CAD. You can only get good at the program by using it a lot. If you want to learn CAD, my best advice to you is to just design a bunch of stuff, and once you have a better idea of how productive you and your team are with CAD, you can make a more informed decision on whether or not to use it during the build season.
EDIT: I personally believe that, if you use CAD productively and efficiently, with sensible designs, it is a fantastic resource, and for teams that want to "take it to the next level," CAD is not an absolute necessity, but it is definitely encouraged.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 14-04-2016, 14:09
jamesmcip jamesmcip is offline
It's fine, don't worry about it
AKA: James Cipolletti
FRC #4908 (Dragons)
Team Role: CAD
jamesmcip is a glorious beacon of lightjamesmcip is a glorious beacon of lightjamesmcip is a glorious beacon of lightjamesmcip is a glorious beacon of lightjamesmcip is a glorious beacon of lightjamesmcip is a glorious beacon of light
It definitely helps any team out, as it can save lots of valuable build time to have a step by step plan with all dimensions laid out, especially if there are a lot of intricate mechanisms in place that must be accurate.
However, one mistake a lot of teams make (ours included) is using CAD instead of actual prototyping, which can create a lot of headaches after the parts are actually manufactured.
Also, in regards to actually learning the software, everything about it is surprisingly intuitive and you will be surprised what you can make. I recommend designing simple assemblies at first and practicing all constraints to learn how they work, then tackle something like designing a previous year's robot to practice for the actual build season.
