Go to Post The card system worked. Well. It was used properly and (except for when Paul yellow carded Andy during his "Thank you" speech) wasn't abused. I applaud the referees. Kudos. - Collin Fultz [more]
Unread 14-04-2016, 14:14
philso philso is offline
FRC #2587
Re: Is CAD essential to all teams?
No. I have watched CAD use go from 0% to essentially 100% in the workplace over the last 30+ years.
Originally Posted by asid61 View Post
More important than CAD and design is good strategy.
The skills needed to design a superior mechanism or to develop a superior strategy are different from the skills needed to make CAD drawings. As Asid and others have said, having the ability to do CAD will enhance your teams ability to develop superior mechanisms and strategies. Being able to use CAD tools is like being able to use a piece of word processing software such as MS WORD. It does not mean that one has the writing skills of Shakespeare or Hemmingway.
I do highly recommend learning CAD purely for figuring out linkages and geometry, however. That's something easier done on a computer than by hand. I would avoid paper simply because it's more hassle for students than CAD in my experience. 973's RAMP has some good videos on it.
An example of this would be to draw a simple profile of your robot and "drive" it under the Low Bar to make sure it really fits.
In addition to using tutorials on YouTube, it would be best to supplement that with some "CAD Mentors", even informal ones. I was asking one of my co-workers for tips on how to do specific things in SolidWorks. He would email me sequences of screen shots and I would pass them back to our CAD team. It saved them hours of time.
Unread 14-04-2016, 14:20
Billfred's Avatar
Billfred Billfred is offline
A few thoughts:
1) I've hung banners with thoughtfully-designed robots done with a measuring tape, angle and box aluminum, and pop rivets. I've had well-CADded and waterjetted robots miss the show. There's no magic bullet here.
2) Knowing your fabrication resources is instrumental to making any CAD work. If you can't buy or lathe a shaft to fit an application, you shouldn't be putting it in the drawing! If your machine shop's tooling has a minimum radius on cuts, make sure your lightening pattern's corners have at least that radius! Start this conversation now, and do some smaller-scale tests before betting the farm.
3) Part of legit-ness is having time to practice driving. Can you turn around a drivetrain that fast, and is it that much better than the kit drivetrain (or the kit drivetrain with some bolt-ons)? Do you have means to keep old robots together and running so the drivers can get some stick time in before this robot is together (and some time against defenders afterward)?
4) Another highly underrated part of legit-ness is just not dying. Did your robot break down this year in a match? What happened there, and how can you fix it on the next robot?
Unread 14-04-2016, 14:31
ASmith1675's Avatar
ASmith1675 ASmith1675 is offline
Mechanical/Electrical/Scouting
AKA: Adam Smith
ASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to behold
CAD is merely a tool. When used in effective combination with prototyping and effective game analysis it can help to raise your capabilities.
Designing a robot completely within a CAD program will allow you to see issues and interferences in 3d space that you may not have accounted for with a design in your head, or even on paper sometimes. The more detailed the CAD model, the less likely you'll run in to these type of issues while building.
To make full use of these advantages requires a slight change in thinking (in my opinion). While simply building things in a computer may not feel like much is getting done, by properly planning out where everything is going to fit, it reduces the time to put everything together. This might mean you don't have ANY parts for your robot for week three (or later sometimes).
The other thing that needs to be taken into account is the manufacturing capabilities of your team. If you don't have access to a mill (manual or CNC) you may have to account for the lower accuracy with which a part can be manufactured. If you have a sheet metal sponsor, you may be able to have parts cut and bent to very high precision. These issues are the ones that are often most difficult to account for. (Can't tell you how many times I've thought of a design that would be difficult/impossible to manufacture given the facilities and resources of the team that I am working with).
CAD is just a part of the equation, though arguably a big one. Being able to effectively analyze the game (to pick the right mechanisms to build), and prototype effectively (to verify your "theory" designs work in the real world), also play a critical role. Can you build an effective robot without CAD? Definitely. I do believe that becoming more proficient with CAD will tend to increase the consistency of robot builds year after year (meaning fewer of the "our robot didn't do what we wanted" years).
The other posters in this thread have provided some excellent resources to get started. Just digging in and messing around with the programs is a great way to learn.
Unread 14-04-2016, 14:35
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
The real answer to your question is: to take your team to the "next level", you need to start working through a proper engineering process.
You can build a robot by assembling the Kit of Parts and then spending the next six weeks trying to improve it. "Ooh, I have an idea!" "Well, that didn't work." "Ooh, I have another idea!"
However, this is not engineering. This is hacking.
Engineering is a disciplined process. There are various definitions, but one I found on Wikipedia lists these steps: research, conceptualization, feasibility assessment, establishing design requirements, preliminary design, detailed design, production planning and tool design, and production.
For FRC, that would look like:
Research/Conceptualization - what is the game? what are all the possible things a robot could do? What are the offensive actions? What are the defensive actions? What are the point values of each? What are the cycle times of each action? What can be done in a 2-minute match? In a 3-robot alliance, how could each robot contribute?
Feasibility Assessment - Of all these things that could be done, what are the easy things? What is harder? Is a harder task worth it? This starts to take into account your team's level of ability and available resources. For example, climbing is a hard task. Maybe it takes 20 seconds. It's worth 10 points. Are there other actions you could do in 20 seconds that could score the same, such as scoring two high goals or damaging the fifth defense?
Design Requirements - Based on all the above, choose what you are going to focus on. Lock this down early to prevent scope creep. For example, we decided early on that our robot would be low bar capable, would shoot low goals, use vision assist for an autonomous low goal mode, be FAST, and be able to handle all the ground obstacles. It was tempting at various stages to try to add a climber, high goal capability. a sally port door opener, etc. But we knew we didn't have the resources to build a Swiss Army Knife on wheels. We kept our focus on the design requirements we agreed on, knowing that if we had time later, we could go back and iterate.
Preliminary design - brainstorming, napkin sketches, prototyping. Now you have a rough idea of exactly what you want to build.
Detailed design - now you nail down exactly how the mechanisms are going to be built, their dimensions, weight, cost, etc.
Where does CAD fit into all this? It helps you with the design stages, and it forces you to actually DO the design stages so you're not tempted to jump right into the shop to start cutting metal without first having a plan. Plus, it is a tool to help you with those design stages so you can play with dimensions and designs without committing to building anything first.
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
Unread 14-04-2016, 14:43
Jash_J's Avatar
Jash_J Jash_J is offline
Lead Strategist
FRC #1241 (THEORY6)
Jash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud ofJash_J has much to be proud of
Originally Posted by Arkive View Post
What would you suggest as a good balance time/resource wise between CAD and prototyping. We usually put a lot of time into prototyping but then we never put it into CAD to make sure it can fit with everything else. That hits our number one problem where our robot looks less streamlined and more cheesecaked than it should.
Typically we only dedicate a week to prototyping. However you can always give or take a couple days from that time period depending on the complexity of the game. If you are able to outline clear constraints and variables during the first day or so of build season, you should be able to complete the prototyping phase in about a week. This allows you to have a good amount of time left over to CAD.
Ideally, because you stated that your team is not familiar with any CAD software, I would suggest conducting workshops over the summer, even indulge yourself in a mock 2 week build season where you prototype and CAD a robot from a previous game over the summer. This will help you familiarize yourself with how tight the process can be and if it is feasible for your team to conduct during build season.
Jash Javeri
FRC Team 1241 - Mentor/Alumnus
2013 World Champions! (1241, 1477, 610)
"Coming together is a beginning. Keeping together is progress. Working together is success." - Henry Ford
"I'm a great believer in luck, and I find the harder I work the more I have of it." - Thomas Jefferson
Unread 14-04-2016, 14:46
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Yes, you need CAD. You will still be stressed to the last minute of build season, but you need CAD.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 14-04-2016, 14:49
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
I'll answer both the title question and the OP's question.
1: Is CAD essential to all teams?
No. Not even close. CAD is a great tool, but you can run a successful FRC team (and build a competitive FRC robot) without CAD.
2: Is CAD the next needed step in order for us to become successful?
Possibly. I think it can be hugely valuable for a team to learn CAD, whether you have mentors in it or not. Be aware that you are in for a slog if you don't have any mentors coming into learning CAD-- when you are learning CAD, you are learning a new language, one that translates your thoughts into shapes on a screen instead of words on a page or audio signals. If you don't have someone who already speaks that language, you are going to figure out a lot of stuff on your own. Like others have mentioned, you're looking at a couple of years to really integrate CAD into your team, especially if not everybody is on board. Don't be afraid to design only parts or subsystems of your robot first-- you don't need to just jump into the deep end.
Best of luck in your future seasons.
Also, ff you choose to learn Creo, feel free to PM me with any questions. While I'm not a professional engineer, I am pretty good at using and teaching Creo for FTC and FRC (by the way, this is a standing offer to just about anyone-- I'm not a complete expert, but designing stuff in Creo is a hobby of mine, so I know a decent bit).
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 14-04-2016, 14:54
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Not essential..can help
We uses CAD mainly to figure out overall bot dimensions for what we wanted to do and bumper placement in first week or so. It was something "to do" until the parts came in.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 14-04-2016, 15:18
waterbott's Avatar
waterbott waterbott is offline
FRC #1683 (Techno Titans)
Team Role: CAD
waterbott is an unknown quantity at this point
Hey Johns Creek! Its nice to see you guys on Chief Delphi. PM me, I might be able to help you guys out with getting started with CAD.
For us, CAD serves as both a tool and a supplement to design; however, it is important to remember that the quality of design through CAD can only be as good as the users. Our team has been successful without CAD before; however, the quality of design depended highly on having a solid understanding of the mechanics behind the design. In many ways CAD serves a a crutch as it helps us visualize some design problems before they are built; however, without a solid understanding of mechanics, CAD can only help so much.
For our team, we started recently started the process of designing with CAD first before building it. We've had a mixture of successes and failures from this approach. For example, one thing we noticed is that because many of the members dedicated to CAD had little background working in fabrication and assembly, we weren't "designing for manufacturability", meaning that we created designs that were either too complicated to fabricate or difficult to assemble. The convenience of CAD made us overlook some of these problems. One of the successes we had with CAD is that it let us lay out the design before it was built and archive an analyze and changes we make. It proved to be an invaluable tool for visualization as well as easing the fabrication process.
Conclusion to this rambling? Having a successful robot primarily predicates on having a foundational understanding of what you are building, CAD serves as a tool that can only be as good as the person who wields it.
Unread 14-04-2016, 15:22
Professional Stat Padder
I'll join the chorus here and say it's not essential, but useful.
I'll also add that my use of CAD in FRC has helped me immensely in college. It's a phenomenal tool for solving tight packaging problems (which this year definitely had).
(2015-Present)
Unread 14-04-2016, 15:31
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
If there is anything to take away from this thread, this statement is it. Understand how to set requirements and design to those requirements.
That's good engineering.
Unread 14-04-2016, 16:14
messer5740's Avatar
messer5740 messer5740 is offline
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
Is someone willing to direct me to tutorial videos on CAD or to send me an email about how I can incorporate CAD into next year's design?
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
Unread 14-04-2016, 16:37
indieFan indieFan is offline
RoboDox and LVHS - Missing you!
FRC #5941
indieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond repute
CAD is a great tool provided the people using it understand that just because something may be designed in CAD doesn't mean it may be manufactured.
My example for students is always: You can draw a solid steel sphere with a hollow core, but how are you going to make it with no seams? As far as I know, you can't.
The other example is that a student drew a wheel knowing we had access to a CNC machine. What the student didn't know/understand was that it was a 3-axis machine and couldn't do the angled portion of the wheel that he was expecting to be done.
Unread 14-04-2016, 16:46
protoserge's Avatar
Out of curiousity, would you mind posting the wheel drawing in a new thread or upload an image? It might not be impossible on a 3 axis machine and would generate some good discussion.
Unread 14-04-2016, 16:50
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
CAD is a tool, like pencil and paper. We use it extensively, but we have experience in doing so.
As others have said, work on your process. To me, more important than CAD are, in this order:
1) A solid understanding of your means with which to build, and how to use them effectively
2) A solid game strategy
3) A solid, decisive list of tasks you want your robot to achieve (this comes from working out your gameplay strategy, and does not have to be everything in the game!)
4) Building effective, rapid prototypes of the mechanisms you want to build for the robot (good enough to take final measurements from, to draw up/build real robot assemblies from)
5) Get some of the basics down, and don't reinvent them every year (for example, work out a good drive train, stick with it a few years, so you can focus elsewhere. Then try more complex stuff when you have more experience)
6) Keeping things simple
Once you have that down, you can more easily start to introduce CAD as a tool to help with the design of assemblies and the robot. If you can build working prototypes, you can build better final assemblies, whether you use CAD to help with that or not. If you plan these around readily available components like versa frame and gussets, you can still build well, without CAD.
For example, here is our second prototype of our shooter this year, both built in 1.5 weeks, along with all the others. The first was very, very rough, made from plywood. After some sketches and working out geometry and measurements on paper/whiteboards, we built this which was a much closer-to-final working model. From this, when we had it working just right, we measured it up, then drew up that as a sketch in CAD, to use in final modeling of parts.
Obviously if you have a sponsor cutting parts for you, CAD will be essential. But to me, that comes in time. My list of 'things that come before CAD' is kinda like getting your house in order first.
This also doesn't mean don't learn it - it takes time. Start now. But that doesn't mean it's the solution to every problem. If you are too slow using CAD for build season but are relying on it, you may not have a robot at all..
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
