Go to Post By the looks, 1114 has already figured out both #1 and #2. They're still behind 71, who is just about done with their robot for the 2012 season, is getting driver practice for 2011, and is working on their robot designs for the 2013 water game. You're still way behind. - EricH [more]
Unread 04-14-2016, 04:59 PM
Stahl-4121 Stahl-4121 is offline
FRC #4121
Stahl-4121 is an unknown quantity at this point
Driver Station/Operator Console Power
We are planning on using a camera pole at worlds. While we are aware of the rules regarding the pole itself, I was wondering about how teams use external monitors. From previous years, I was under the impression that you can only use the AC port for the laptop charger.
Are you able to power a monitor using the AC port on the driver station?
If not, how do teams use external monitors with the high camera?
Unread 04-14-2016, 05:08 PM
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Re: Driver Station/Operator Console Power
I have seen quite a few teams with a power strip on their driver station this year.
If that is technically not allowed you could probably power everything off their built in batteries aside from the monitor. Camera has its own battery, laptop has its own battery, ect. You could put a large battery/small generator on your driver station but that seems excessive.
Unread 04-14-2016, 05:14 PM
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
No, you couldn't put a small generator on your driver station. But you could have a small inverter ( I think you mean this).
I'll need to verify with the manual, but I think that it is fine to bring your own powerstrip
Facebook
Unread 04-14-2016, 05:36 PM
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 will become famous soon enoughscca229 will become famous soon enough
The power receptacle on the player station shelf has a 3amp breaker on it. You can plug whatever you want in it, but tripping that breaker is NOT a field fault if it happens.
Nate
Unread 04-14-2016, 05:49 PM
Jpatterson1710's Avatar
Jpatterson1710 Jpatterson1710 is offline
AKA: Josh Patterson
FRC #1710 (Ravonics Revolution)
Jpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura about
Exactly right. I had teams at each regional that I staffed this year doing exactly that. You get only the power supplied from the 3amp breaker, and you can do whatever you want with that. You may not plug any cords into power supplies below or around the driver station. As stated above, if the breaker is tripped on the dedicated power at the driver station, that will not be in any way considered a field fault, and therefore the match would not be replayed for that reason, and the results in no way would be modified.
2012-2014 Mechanical Team FRC 1710
2014-2015 Chief Operations Officer FRC 1710
2016-Present FTAA
Unread 04-14-2016, 06:25 PM
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
If you're worried about tripping the breaker. We got one of these a couple weeks ago. Seems to work.
That being said, we just use the 3A plug with our set up and it works fine.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 04-14-2016, 06:32 PM
Philip Arola's Avatar
Philip Arola Philip Arola is offline
You can check out any time you like
AKA: KG7VAM
FRC #1510 (Wildcats), FRC #2898 (The Flying Hedgehogs)
Philip Arola is an unknown quantity at this point
USB monitors are a possibility. They're fairly costly, and poor quality, but they are powered off of the USB port alone.
However, like others have pointed out, be mindful of the 3 amp limit.
Unread 04-15-2016, 12:46 AM
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
This. If there is some rule we all missed about the driver station power, it's not being enforced anywhere I'm aware of.
IMO, the biggest thing to be mindful of is how many amps you're pulling, so while some teams have managed to use large flat-screen TVs for their driver stations, there are certainly plenty of more practical (and reliable) solutions out there (though the idea is certainly appealing). Our team used a 10" car backup camera screen with HDMI input, we set it up as a 2nd monitor for our laptop and ran our camera via USB off of that. The screen had a minimal impact on power so we were confident we wouldn't be popping breakers (it also came with a nice mounting solution that allowed us to stick it on our existing driver station).
Unread 04-15-2016, 10:02 AM
AKA: Nate
FRC #0060
This is the only passage in the Game Manual that mentions the outlet, in the Arena section:
One 120VAC NEMA 5-15R power outlet. It is located on the right side of each PLAYER STATION
shelf. The outlet is protected by a 3-Amp circuit breaker and can be used to power the
OPERATOR CONSOLE. DRIVE TEAMS are responsible for monitoring their power consumption
as a tripped breaker in the outlet does not constitute an ARENA fault.
It is yours to do with what you will, but it is also your responsibility to know that what you are plugging in will not cause it to pop.
Nate
Unread 04-15-2016, 10:44 AM
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
A 3 amp breaker seems very small, but don't let it scare you. You get ~360 watts, we can say 300 watts safely. My MacBook Pro has an 85 watt charger and that seems reasonable as an average for a driver station laptop. Now you have 215 watts to work with. The Dell LED monitor that I own consumes somewhere around 20 watts. Now you have 195 left. Slightly less than 1.5 amps used out of the 3 you're given so it's likely a safe bet. You can always set up a prototype rig and determine your wattage by measuring the current you use with an ammeter.
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 04-16-2016, 12:35 AM
pilleya's Avatar
Elec+Mech
If the 3 amp breaker is an issue for you, maybe you could come to the Australia Regional next year?
You could draw more than twice the power because Australia uses 240v
Facebook
Unread 04-16-2016, 01:40 AM
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
We ran with a power strip integrated into our driver station and hand no issues powering our 24" dell monitor and DS laptop.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 04-16-2016, 03:04 AM
Jaci's Avatar
Jaci Jaci is offline
AKA: Jaci R Brunning
FRC #5333 (Can't C# | OpenRIO)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
Lucky for us, the awesome FTA gave us Australian Power Boards behind the DS going into the mains. Perfect considering the DS ports were american
Jacinta R
Curtin FRC (5333+5663) : Mentor
5333 : Former [Captain | Programmer | Driver], Now Mentor
OpenRIO : Owner
Website | Twitter | Github
jaci.brunning@gmail.com
