Go to Post You should qualify the same way you eliminate if you ask me. - sircedric4 [more]
Unread 15-04-2016, 05:53
MooreteP's Avatar
MooreteP MooreteP is offline
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
Fire at Michigan State Champs
Was looking for a thread on this yesterday:
Surprised it wasn't here yet, so I am linking to the Reddit post.
Unread 15-04-2016, 06:29
jaunvie jaunvie is offline
FRC #5090
jaunvie is an unknown quantity at this point
Re: Fire at Michigan State Champs
Yes, this made quite the impression. I was afraid the team was going to be bombarded wroth safety captains all trying to be the first to put it out. Fire extinguisher on the cart isn't a bad idea. We're redesigning ours this year I think it's would be a good addition.
Unread 15-04-2016, 07:37
Cory Walters Cory Walters is offline
FRC #2767
Cory Walters is on a distinguished road
The team was able to rebuild the robot yesterday after the fire. They ran multiple practice match's and would appear that it functioning again. Everyone around was cheering them on! A great moment.
Unread 15-04-2016, 07:51
The report I have is that the team rebuilt in four hours and ran in a practice match. The pictures I have seen show some burned wiring near the PDP. Good luck guys!
Unread 15-04-2016, 08:33
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
An interesting comment in the original link by a poster saying, essentially, "all the safety captains and meticulously memorized safety code rules, useless when something actually happens".
I can attest to that feeling. A number of years ago my car engine caught fire while it was parked at a camp. (The running theory is that a rodent chewed through enough wiring to cause a short). There was a good few moments of "uhhhh what's happening?" followed by, in that moment, not having a clue what to do.
That moment led to writing down a specific procedure "in case of fire", that is printed and posted in every building. It is unambiguous. Step 1, this person do this. Step 2, everyone else do that.
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
Unread 15-04-2016, 08:56
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
There was a robot fire at the Greater KC event too.
Not as much flame, but smoked-up the place pretty good. Had to wait a while to start the next match until the smoke cleared.
I understand that the robot was up and running again later.
Heard third-hand that two motor wires were routed through a drilled hole with battery wires nearby. Motor wires wore through and shorted, lighting a bunch of insulation on fire.
https://youtu.be/K2gLfBm0s8s?t=100
Yes, I think it sounds like a great idea to actually have a plan for who will do what actions during a fire.
Unread 15-04-2016, 09:16
Mark Holschuh's Avatar
Mark Holschuh Mark Holschuh is offline
FRC #2194 (Fondy Fire)
Mark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud of
Does anyone know what was the specific heat source that started the fire, and what the combustible material was that sustained the fire?
"The true sign of intelligence is not knowledge but imagination."
-- Albert Einstein,
"The ultimate test of man's conscience may be his willingness to sacrifice something today for future generations whose words of thanks will not be heard."
- - William Proxmire
Unread 15-04-2016, 09:26
Drivencrazy's Avatar
Drivencrazy Drivencrazy is offline
AKA: Clint Ott
FRC #1011
Drivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant future
/u/sourec commented on the reddit post detailing the fire and showing some more pictures.
An expensive, unfortunate incident.
Unread 15-04-2016, 09:42
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
It's like CPR training. Step 1, notice there's a problem and decide to do something. Step 2, tell someone to call 911. Step 3, make sure they heard and understood that. Step 4, actually start CPR.
Preventative safety is great, since it's a lot easier to not have to deal with injuries in the first place, but it seems like training and planning for what to do in an actual emergency is slightly lacking.
Unread 15-04-2016, 09:44
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
We had a similar incident at the Long Island regional in 2009 with Team 263. That was the result of the catastrophic failure of a Victor speed controller, sustained by bumper material. The facility manager wouldn't let the robot back into the building unless they determined it was fixed and wouldn't happen again.
Unread 15-04-2016, 10:22
Jaci's Avatar
Jaci Jaci is offline
AKA: Jaci R Brunning
FRC #5333 (Can't C# | OpenRIO)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
I hate to be 'that person', but it has to be said.
Why did it take so long to grab a fire extinguisher that should have been ready at the field?
Why is there a group of volunteers all standing around a robot with a roaring fire and a live battery inside it?
Why are there volunteers sticking their hands inside and/or near the robot, let alone fanning the fire?
It seems to me like this reflects a lack of training for what to do in this situation. I would expect volunteers to be properly inducted about what to do in the event of an emergency such as this one. We've got 6 highly dangerous machines on the field and dozens more behind the curtain, all with massive batteries and electrical currents running through them, but it seems that no one knows what to do in the (quite likely) event that something goes wrong.
We're always saying that "Safety comes first", but it's events like this that make me question "are we really living up to that?"
Jacinta R
Curtin FRC (5333+5663) : Mentor
5333 : Former [Captain | Programmer | Driver], Now Mentor
OpenRIO : Owner
Website | Twitter | Github
jaci.brunning@gmail.com
Unread 15-04-2016, 10:40
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Training for an emergency and being in one feel completely different.
I don't believe you can fault volunteers who aren't exactly sure what to do when they go to maybe 3-4 events a year. If they were trained for an emergency like this the chances of this happening has to be close to 1 in 100 events. So it isn't like this is something that happens so often that they would know how to react if it did.
I do agree there should be a fire estinguisher at the field to be easily found. And that perhaps maybe they shouldn't have been standing so close to a fire.
What are your concerns with a battery and fire?
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 15-04-2016, 10:43
indieFan indieFan is offline
RoboDox and LVHS - Missing you!
FRC #5941
indieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond repute
Volunteer training has not included "fire safety," as long as I've been a volunteer. Perhaps a solution could be to ask local firefighters if they would be willing to volunteer for the event.
Unread 15-04-2016, 10:45
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
It seems to me that they were searching for a dry chemical fire extinguisher apposed to a more common co2 fire extinguisher in order to keep parts of the robot salvageable.
The likelihood hood of the fire spreading was very low but, it did slightly concern me when they started to poke around inside of the robot. I was also expecting with that size flame that the bumper fabric would eventually catch on fire. Overall it just seemed foolish to poke around.
The reaction time could have definitely been better and this is a situation that volunteers should be better prepared for but the likelihood is pretty low.
A more accessible fire extinguisher is really all they need.
Unread 15-04-2016, 10:48
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
The overall reaction there seemed a bit less prepared than this one for Lake Superior a few years ago https://m.youtube.com/watch?v=YOd3mF1tvwk
Fast forward to the last 25 seconds, you can see immediate action behind the robot, and a fire extinguisher was out and ready on the field rather quickly!
2016: Lake Superior WFFA
