Go to Post If there's one thing I've learned, it's that the robot is never truly finished. - Joseph Smith [more]
Unread 15-04-2016, 10:58
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: Fire at Michigan State Champs
My assumption is that the early poking around near the fire was an attempt to find and hit the main breaker, which is usually the first line of defense before they go to the extinguishers. Even when clearly labelled, the smoke can make it really hard to see the breaker. Blowing on the flames, however, was probably not the best plan.
Later, they popped the cover to make it easier to get the fire extinguisher onto the fire.
Unread 15-04-2016, 10:59
Jaci's Avatar
Jaci Jaci is offline
AKA: Jaci R Brunning
FRC #5333 (Can't C# | OpenRIO)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
Originally Posted by orangemoore View Post
What are your concerns with a battery and fire?
It's moreso that a battery rupture could cause massive damage to the internals of the robot and any close components assuming the bellypan of the robot isn't fully enclosed.
It was stated that the fire was caused by a battery short with a live chassis. If a robot is on fire, 9 times out of 10 it will be because of a battery short or electrical fault. When a high amperage electrical circuit shorts, touching the metal chassis of the robot is a good way to become less alive.
Jacinta R
Curtin FRC (5333+5663) : Mentor
5333 : Former [Captain | Programmer | Driver], Now Mentor
OpenRIO : Owner
Website | Twitter | Github
jaci.brunning@gmail.com
Unread 15-04-2016, 11:14
Doug Frisk's Avatar
Doug Frisk Doug Frisk is online now
Keeping Score
AKA: Doug Frisk
Doug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond repute
Originally Posted by Jaci View Post
I hate to be 'that person', but it has to be said.
Why did it take so long to grab a fire extinguisher that should have been ready at the field?
Because someone screwed up. As part of field setup, the fire extinguisher is removed from case 8 and put by the side of the field. I usually put it in front of the FMS at the center of the table or on the end of the table where the FTAs are hanging out.
It's quite apparent that extinguisher was still in case 8. I bet all the FTAs get an email this week.
Jaci's Avatar
Rookie Year: 2015
At this point, hitting the breaker won't solve the problem. The fire is started electrically, which means that something, somewhere has shorted. Not only does this trip the breaker/fuse, but will also discharge the battery if the breaker isn't fast enough to catch it.
Jacinta R
OpenRIO : Owner
Unread 15-04-2016, 11:16
Jaci's Avatar
Rookie Year: 2015
I'm aware that fire extinguishers are standard with the field, but the fact that it was neglected/forgotten by the field setup crew is what worries me.
Jacinta R
OpenRIO : Owner
Unread 15-04-2016, 11:18
Doug Frisk's Avatar
Keeping Score
AKA: Doug Frisk
Originally Posted by Sperkowsky View Post
It seems to me that they were searching for a dry chemical fire extinguisher apposed to a more common co2 fire extinguisher in order to keep parts of the robot salvageable.
The likelihood hood of the fire spreading was very low but, it did slightly concern me when they started to poke around inside of the robot. I was also expecting with that size flame that the bumper fabric would eventually catch on fire. Overall it just seemed foolish to poke around.
The reaction time could have definitely been better and this is a situation that volunteers should be better prepared for but the likelihood is pretty low.
A more accessible fire extinguisher is really all they need.
You have that backwards. A dry chemical extinguisher will coat the robot in dust and crap, CO2 leaves no residue making it easier to salvage bits.
I'd also call dry chemical much more common. C02 extinguishers are not typically found at your big box home store.
I've never actually seen a CO2 unit in a pit at an FRC event. I'm sure some teams have them, but dry chemical is pretty much what everyone has.
Unread 15-04-2016, 11:27
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
You might be badly burned if the frame is hot, but Ohm's law plus physiology says you're extremely unlikely to suffer any injury from the electricity itself. Wikipedia says the resistance of wet skin is about 1 kOhms. So a 12V battery can push, say, 12 mA through you. The chart on that page notes that 12 mA of AC would be noticeable after a few seconds, but not deadly. It's important to note that DC is much less dangerous in this regard than AC. Unless you have wires connected directly to your heart[1], it takes a lot more DC to kill you than AC. If anyone is doubtful, I can hold a demonstration at Champs where I will bravely grab both terminals of a robot battery with either hand an suffer no ill effects.
Mind you there's plenty of other dangers from the battery, but they're all the fire, explosion, direct-short causing a welding arc sort.
TL;DR: The robot battery (and your car battery[2]) aren't going to electrocute you unless you stab a positive and negative wire from them into your heart. In which case you have plenty of other problems besides.
[1]I have before. It was weird.
[2]Had a dead battery once in college and got a jump from a doctor. He gave me the same electrocution warning. And he should know, because he's a doctor. I didn't argue because I wanted to get home.
Unread 15-04-2016, 11:39
rsisk's Avatar
rsisk rsisk is online now
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
If there was a short with the frame, does this mean the frame isolation test during inspection was not done?
Or would this happen even if the frame isolation test passed?
The views expressed are mine and should not be construed to represent the views of anyone else.
Jaci's Avatar
Rookie Year: 2015
That is a fair point, I should have thought a bit further before posting that last line. Looking back, I should have known a bit better[1]. Even so, I still stand that touching an electrically charged chassis is far from a good idea, even if it's just for peace-of-mind.
[1]I do a lot of work with electrical systems. Also got shocked by a 240 ~3-6A wall socket (for the second time) a few years ago, less than a fun experience.
Jacinta R
OpenRIO : Owner
Unread 15-04-2016, 11:42
Jaci's Avatar
Rookie Year: 2015
It is possible even if circuits are electrically isolated from the frame before the match. If the outer shielding of the wire (or a solder joint, or wire crimp) becomes damaged, it is very possible for it to contact the robot chassis. With the rigors of Stronghold, this is entirely within the realm of possibility.
Jacinta R
OpenRIO : Owner
Unread 15-04-2016, 11:47
Karibou Karibou is online now
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Unless it changed this season, Michigan does not use the standard road case system that the rest of the country uses. There is no case 8, just a toolbox and a tote or two with the non-tool items that are usually in case 8 (paper towel glass cleaner, etc). I'm actually not sure where the fire extinguisher is stored with Michigan fields.
Disclaimer: I didn't do any events in Michigan this year, so it may have changed.
Or maybe it happened after inspection? Wire coming loose during a match?
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 15-04-2016, 11:55
Doug Frisk's Avatar
Keeping Score
AKA: Doug Frisk
You make a good point. Though the extinguisher that came out eventually did look like the standard CO2 extinguisher packed with the regional fields.
Unread 15-04-2016, 12:02
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
There's a lot of variables that can go into this, we can't say for certain if it was or was not done. It's possible it was done, but after the fact the insulation wore through. It's possible the frame short was intermittent, and only occurred when a wire was pinched in a mechanism a specific way. Or the team was doing a hasty repair and pinched a wire, or drilled through the insulation of a wire, or disconnected a motor and had the leads just dangling... There are any number of ways for the frame to short out either before or after a frame isolation test is done. And most of the time the frame isolation test is not performed during reinspection.
The reason we do the frame isolation test is to ensure that it takes two faults to cause a problem, not just one. Two faults obviously can still happen, but it's half as likely to happen as having one fault.
2016: Lake Superior WFFA
Unread 15-04-2016, 16:50
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
Unless it changed this season, Michigan does not use the standard road case system that the rest of the country uses...
This is correct. (Though I am far from an authority on the topic, I've helped with a handful of event setup and teardowns.)
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
Unread 15-04-2016, 18:10
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Even so, I still stand that touching an electrically charged chassis is far from a good idea, even if it's just for peace-of-mind...
You are aware your car has an electrically charged chassis? In the States we bond one leg of of our power to ground. Touching a charged chassis really isn't an issue. You don't want to use your body to complete the electrical circuit though.
Before using your extingisher on an electrical fire, you want to remove the inigtion source. Powdered fire extinguisher are messy. Never my first choice when other options are present.
