Go to Post Seating is limited. Be sure to apply deodorant and brush your teeth. - Wayne TenBrink [more]
Unread 15-04-2016, 10:26
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
ethernet cable type
Considering we constantly have issues with tether cables going "bad" i was thinking of ordering a custom tether cable. I have some questions about it.
Should it be a "straight through" or "cross over" cable?
Is there a disadvantage to using a "stranded" vs "solid" cable? Thinking the solid cables are the primary reason for the cables going "bad".
Should it be CAT5, CAT5E or CAT6?
Thanks
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 15-04-2016, 10:43
epylko epylko is offline
Mentor!
AKA: Eric Pylko
FRC #3181 (Pittsford Panthers)
Rookie Year: 1970
epylko is an unknown quantity at this point
Re: ethernet cable type
For the distances and speed, you'll be fine with any Cat5 cable or better (5e, 6, 6a) etc. Make sure they have some strain relief at the connectors to alleviate the twisting/pulling where the cable goes into the connector.
You should be getting stranded cable, not solid. Solid is generally used in buildings to go from wiring closet to the jacks in offices/cubes/walls. It's more unwieldy than the stranded too. If you're going to make your own cables, make sure you get the right connectors for the type of cable you're buying.
Finally, almost all equipment can auto-sense if it needs to be a crossover cable or not (MDI or MDI-X). I would probably NOT buy crossover cables. You can always put in a small DLink/Linksys/Netgear switch between your devices and then you won't have to worry about the crossover cable.
Unread 15-04-2016, 10:52
The0range's Avatar
The0range The0range is offline
AKA: Nikolos Antonio
FRC #1706 (Ratchet Rockers Robotics)
Rookie Year: 2015
The0range is an unknown quantity at this point
Thanks
If you're using the cable for router and router, router and pc, etc. use cross over
If you're using it for devices like router and switch, pc and switch, so on use straight
It don't see any disadvantages between standard vs solid cables, the only really difference is the type of connector used.
For the type of cable depends on what types of speeds you want. A CAT-5 cable will most likely only get 10-100 Mbps as a CAT-6 can reach up to 10 Gbps.
So in general get a cable that fits your needs to it. Looking at speed and use
Unread 15-04-2016, 10:56
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
I have a 500ft spool of cat 5e cable and can make you a nice cable. Just give me a size and send me some money to ship it.
Sent from my LG-H810 using Tapatalk
Unread 15-04-2016, 10:57
bdaroz's Avatar
bdaroz bdaroz is offline
Programming Mentor
AKA: Brian Rozmierski
FRC #5881 (TVHS Dragons)
Rookie Year: 2016
bdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud of
This is probably the most important item. I'm not generally a fan of the plastic boots on the ends of the cables, but if they help provide some modicum of strain relief I would use them here as well.
Last edited by bdaroz : 15-04-2016 at 15:01. Reason: blastic / plastic... typing is hard.
Unread 15-04-2016, 14:31
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
You want straight through cables. Rarely have I ever needed a crossover cable.
You want stranded cable. Solid cable is good when the wire NEVER moves. Stranded is good for wire that has to flex. With flexing, the solid cable will break (internally) a lot sooner.
Solid wire is one thick piece of wire. Stranded is lots of thin wire wound together. Solid has less "resistance", but because of its thickness, it breaks easily if it is flexed too much. Thin wire has a lot more "give", and can survive a lot of flexing. Also, if one strand breaks, the other intact strands can spread the load across the gap. Not so with a solid wire.
Unread 15-04-2016, 14:52
Philip Arola's Avatar
Philip Arola Philip Arola is offline
You can check out any time you like
AKA: KG7VAM
FRC #2898 (The Flying Hedgehogs), FRC #1510 (Wildcats)
Philip Arola is an unknown quantity at this point
The consensus here is right, you want stranded non-crossover. Most important with the driver laptop is to make sure the plugs themselves have solid clips and good strain relief. That's the primary point of failure in my/my team's experience.
Unread 15-04-2016, 15:12
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Agreed. Stranded cable, any CAT5/5e/6 designation is fine (we're not pushing huge amounts of data down these cables).
Strain relief, and those plastic "hoods", are good. We keep breaking the little tabs off our (non-hooded) cables. It's easy to do when the cables snag on things, or when tethered at a practice field and you don't quite give it enough slack.
I own an RJ45 crimping tool so I think we'll just cut the broken ends off the cables and make new ones. This could be a worthy investment if you find yourself replacing cables a lot.
Finally, I like to buy from Monoprice.com. Great prices.
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
Unread 15-04-2016, 15:15
Bruceb's Avatar
Thank you all very much
Have any of your ordered from http://www.showmecables.com/custom-cable.aspx
Unread 15-04-2016, 16:32
AKA: KG7VAM
Never heard of them before. Generally if build quality is of paramount importance then I buy in person to gauge quality myself.
Unread 15-04-2016, 17:58
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Some teams remove the clip on both ends of the tether on purpose, to save the more expensive equipment it's attached to.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 15-04-2016, 20:47
fergus180's Avatar
fergus180 fergus180 is online now
AKA: Fergus Hudson
FRC #4613 (Barker Redbacks)
Rookie Year: 2015
fergus180 is an unknown quantity at this point
be careful with the difference between solid and stranded, solid wires are usually used inside walls as they do not need to bend as much, if they are bent back and forth the copper will metal fatigue and break but the stranded wires have much more flexibility and don't break as easily and are there for used between the wall and the application. the reason different connectors are used for solid or stranded is because the wires need to make good contact with the pins, so for stranded the crimp that makes contact with the wire is a little different than the solid wire crimp.
Unread 16-04-2016, 00:06
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Why order something custom when standard long Ethernet cables are so inexpensive? E.g. you can buy a 100 foot Cat5e Ethernet cable from Amazon for $12.99 with free Prime shipping. It's inexpensive enough that you can buy a couple extras for what a custom cable probably costs.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 16-04-2016, 00:19
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
This is probably the best option, it is not a critical application. If you find that the tether no longer works, you can just change it out for another.
Our Sponsor School, replaced their entire school network with CAT6, so we got about 50kg of CAT5/5E ethernet cables. We donated the long ones to teams at the Australia Regional who did not have any cables. We also removed the inner wire cores from some, while they are too fragile for use in some applications, they are good for making jumpers on circuit boards among a few other uses.
We had no problems with using a long solid core ethernet cable as a tether, but I would have a spare or two on hand.
Unread 16-04-2016, 17:50
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Disposable cables are OK, but I'd rather have something that works and not worry about it.
I buy all my cables from http://www.showmecables.com They have stranded cable that is pretty robust. Have them put the extra long ends on them (extra strain relief). The cable comes in a number of colors, so you may find one that matches your team colors.
You'll need to talk to their sales department, since the online order is for solid conductor patch cables.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
