ethernet cable type
Considering we constantly have issues with tether cables going "bad" i was thinking of ordering a custom tether cable. I have some questions about it.
Should it be a "straight through" or "cross over" cable? Is there a disadvantage to using a "stranded" vs "solid" cable? Thinking the solid cables are the primary reason for the cables going "bad". Should it be CAT5, CAT5E or CAT6? Thanks |
Re: ethernet cable type
For the distances and speed, you'll be fine with any Cat5 cable or better (5e, 6, 6a) etc. Make sure they have some strain relief at the connectors to alleviate the twisting/pulling where the cable goes into the connector.
You should be getting stranded cable, not solid. Solid is generally used in buildings to go from wiring closet to the jacks in offices/cubes/walls. It's more unwieldy than the stranded too. If you're going to make your own cables, make sure you get the right connectors for the type of cable you're buying. Finally, almost all equipment can auto-sense if it needs to be a crossover cable or not (MDI or MDI-X). I would probably NOT buy crossover cables. You can always put in a small DLink/Linksys/Netgear switch between your devices and then you won't have to worry about the crossover cable. |
If you're using it for devices like router and switch, pc and switch, so on use straight It don't see any disadvantages between standard vs solid cables, the only really difference is the type of connector used. For the type of cable depends on what types of speeds you want. A CAT-5 cable will most likely only get 10-100 Mbps as a CAT-6 can reach up to 10 Gbps. So in general get a cable that fits your needs to it. Looking at speed and use |
I have a 500ft spool of cat 5e cable and can make you a nice cable. Just give me a size and send me some money to ship it.
Sent from my LG-H810 using Tapatalk |
This is probably the most important item. I'm not generally a fan of the plastic boots on the ends of the cables, but if they help provide some modicum of strain relief I would use them here as well.
Last edited by bdaroz : 15-04-2016 at 15:01. Reason: blastic / plastic... typing is hard. |
You want straight through cables. Rarely have I ever needed a crossover cable.
You want stranded cable. Solid cable is good when the wire NEVER moves. Stranded is good for wire that has to flex. With flexing, the solid cable will break (internally) a lot sooner. Solid wire is one thick piece of wire. Stranded is lots of thin wire wound together. Solid has less "resistance", but because of its thickness, it breaks easily if it is flexed too much. Thin wire has a lot more "give", and can survive a lot of flexing. Also, if one strand breaks, the other intact strands can spread the load across the gap. Not so with a solid wire. Last edited by rich2202 : 15-04-2016 at 14:38. |
#7
The consensus here is right, you want stranded non-crossover. Most important with the driver laptop is to make sure the plugs themselves have solid clips and good strain relief. That's the primary point of failure in my/my team's experience.
#8
Agreed. Stranded cable, any CAT5/5e/6 designation is fine (we're not pushing huge amounts of data down these cables).
Strain relief, and those plastic "hoods", are good. We keep breaking the little tabs off our (non-hooded) cables. It's easy to do when the cables snag on things, or when tethered at a practice field and you don't quite give it enough slack. I own an RJ45 crimping tool so I think we'll just cut the broken ends off the cables and make new ones. This could be a worthy investment if you find yourself replacing cables a lot. Finally, I like to buy from Monoprice.com. Great prices. |
#9
Thank you all very much
Have any of your ordered from http://www.showmecables.com/custom-cable.aspx ?? |
#10
Some teams remove the clip on both ends of the tether on purpose, to save the more expensive equipment it's attached to.
#12
Why order something custom when standard long Ethernet cables are so inexpensive? E.g. you can buy a 100 foot Cat5e Ethernet cable from Amazon for $12.99 with free Prime shipping. It's inexpensive enough that you can buy a couple extras for what a custom cable probably costs.
#14
Our Sponsor School, replaced their entire school network with CAT6, so we got about 50kg of CAT5/5E ethernet cables. We donated the long ones to teams at the Australia Regional who did not have any cables. We also removed the inner wire cores from some, while they are too fragile for use in some applications, they are good for making jumpers on circuit boards among a few other uses. We had no problems with using a long solid core ethernet cable as a tether, but I would have a spare or two on hand. Last edited by pilleya : 16-04-2016 at 00:22. |
#15
Disposable cables are OK, but I'd rather have something that works and not worry about it.
I buy all my cables from http://www.showmecables.com They have stranded cable that is pretty robust. Have them put the extra long ends on them (extra strain relief). The cable comes in a number of colors, so you may find one that matches your team colors. You'll need to talk to their sales department, since the online order is for solid conductor patch cables. Last edited by Foster : 16-04-2016 at 17:53. |
