Problem with NavX to turn around.
Hi,
This year, our shooter direction is opposite of our front of our robot. I decided that we should use the NavX we just got to semi-accurately turn ourselves around. We don't have any encoders on our motors so I just made a simple function that would have the motors turn until it hit a 10 degree range in which case it would stop. The problem is that it doesn't always work. It works 9/10 times but that one time it just spins endlessly in a circle and never stops. This, of course, is not something you want to happen. I am asking if there is a better way to go about programming this so it ALWAYS works? Here is the current function: Code:
#if button pressed, start
if self.turn_button.get():
self.turn_state=0
yaw=self.navx.getYaw()
#Our NavX is not completely centered on the robot so
#that is why it isn't 180 degrees for turning around
if yaw > 0:
self.desired=self.navx.getYaw()-227
else:
self.desired=self.navx.getYaw()+133
current=self.navx.getYaw()
if self.turn_state==0:
self.turn_state=1
elif self.turn_state==1:
if current < (self.desired+10) and current > self.desired:
self.turn_state=2
else:
self.drive2.set(.7)
self.drive1.set(.5)
Re: Problem with NavX to turn around.
Take a look at the "Rotate to Angle" examples. Online description of these is here. You can find an example java project that implements this after you run the navX-MXP setup program. The sample for "Rotate to Angle" is installed at: C:\Users\<your_username>\navx-mxp\java\examples\RotateToAngle This example shows how to implement this, using Mecanum drive. Some PID Tuning is required, so you'll want to read up on how to use PID (there are lots of links to good info here on ChiefDelphi). You should be able to implement something that works reasonably well by only using a P coefficient, though to get it to work well w/your specific drive system you may need to do additional tuning of the I and D coefficients. |
So the online description is not the full code? If not, do you have a Github page or something because we use Python and don't have the necessary software to install nax-mxp example. |
But for rotate-to-angle, your feedback that drives the PID controller is the Yaw angle from the navX-MXP. Anyways, the RotateToAngle Java example code is available on GitHub at: https://github.com/kauailabs/navxmxp...team2465/robot My understanding is that the java and python are very similar, so this should be a good starting point for you. There are some comments in the example code that discuss tuning the PID a bit. PID is a _very_ useful thing to learn and get used to for programming control systems like those used in FIRST and in the real world, so I encourage you to spend the time to learn it. Focus first on understanding how the P (proportional) coefficient works. Then, once you understand that and the concept of undershoot and overshoot well, begin working on the I (integral) coefficient. Finally, if you find this is not good enough for your needs, begin looking at the D (derivative) coefficient. A final bit of advice when tuning PID coefficients is to only change one coefficient at a time. The different coefficients "mix" together in ways that aren't always intuitive, so go slowly and take careful notes as you tune them. |
#7
Lucky you, the single NavX MXP example that I ported a few weeks ago was the rotate to angle sample. It even works if you run it in the simulator:
https://github.com/robotpy/robotpy-w...otate_to_angle |
#8
Thanks! |
#9
We have found that a simple piece wise function is accurate enough to use for rotating to angles. We have a tolerance of two degrees. It works very well. We call this little set of functions Tigerdrive.
Here is a link: it is probably more simple to implement. https://github.com/team2053tigertron...src/TigerDrive |
#10
Thanks tho! |
#11
We are using a well tuned PID loop on the angle returned by the navX in order to turn accurately. An issue that we ran into, which I think might explain what you described (your code working only 9/10 times), is that at certain absolute angles, if you simply add or subtract 180 (or in your case the slightly altered values), then you might get a value which is outside the range of the navX. We use the navX getFusedHeading() method as opposed to the getYaw() method, so I'm not sure how the values returned by these two methods differ. But essentially, since the navX returns values modulo 360 (for the getFusedHeading() method), if you want any value you calculate to be within the range 0-360, you can perform some mathematical modulo function on it. For instance, ((desired angle + 360) % 360) will map any angle greater than -360 to an angle between 0 and 360. On the other hand, (((desired angle + 540) % 360) - 180) will map any angle greater than -360 to an angle between -180 and 180 if you would prefer that. You can work out what would be best for you, but I hope this might help explain your issue.
In regards to PID, I would highly suggest, like most everyone else replying here, that you look into it. It is fairly simple and can drastically increase the accuracy, speed, and smoothness of your turning. EDIT: I actually looked at the reference, and found that getYaw() returns values between -180 and 180. Notice that if it is greater than 0, you subtract 227. This would suggest that you could possibly be trying to turn to the angle -226, which the getYaw() method will never return. Instead you might want to take the angle and map it to -180 to 180 using a function like the second one I described. This way, -226 will be turned into +134, which is a value which will work with what the navX returns. Last edited by DanielHa : 15-04-2016 at 19:29. |
#12
In theory, PID is great. In practice, not so much.
In this exercise, you are trying to turn a robot to a set angle. PID will increase the speed until you get there, and then oscillate back and forth trying to hit the mark. The easier way to do it is to turn at a controlled speed until you get there. In the original code, I'm guessing that the robot is rotating too fast, and overshoots the error range (self.desired to self.desired+10) that one time in 10. The solution is to turn slower, check the angle more frequently, wider error range. Maybe when you get close, you slow down the turn. |
#13
I would argue that PID is much more elegant in practice than in theory
#14
We use the Analog Devices supplied gyro without encoders with a PI controller for an algorithm to turn the robot to a set absolut degree. With a PI controller you can easily get within a half of a degree or better.
#15
I've added a navx_rotate_to_angle_arcade example to the set of samples. If you look at the diff, there's basically two changes that I made:
Hope that helps! |
