Go to Post Quality has nothing to do with desire – you can’t wish quality. Quality has nothing to do with time, or money, or the other guy’s attitude. Quality has everything to do with craftsmanship. - Jack Jones [more]
  #31   Spotlight this post!
Unread 15-04-2016, 18:18
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Fire at Michigan State Champs
Originally Posted by FrankJ View Post
Before using your extingisher on an electrical fire, you want to remove the inigtion source. Powdered fire extinguisher are messy. Never my first choice when other options are present.
On the other hand, it's not like it's wise to be choosy beyond making sure the extinguisher is rated for your particular emergency.
"No, no, it's not going to spread that much. Let's wait and see if we can find the CO2 extinguisher..."
  #32   Spotlight this post!
Unread 15-04-2016, 18:33
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
I cannot argue with that.
  #33   Spotlight this post!
Unread 15-04-2016, 20:35
RoboChair's Avatar
AKA: Devin Castellucci
Originally Posted by DareDad View Post
You make a good point. Though the extinguisher that came out eventually did look like the standard CO2 extinguisher packed with the regional fields.
That was definitely a dry chemical extinguisher, the CO2 kind would have dissipated much faster.
11 Years and counting! Over a third of my life has been spent with FRC.
  #34   Spotlight this post!
Unread 15-04-2016, 21:13
GaryVoshol's Avatar
Cogito ergo arbitro
Originally Posted by Jaci View Post
It is possible even if circuits are electrically isolated from the frame before the match. If the outer shielding of the wire (or a solder joint, or wire crimp) becomes damaged, it is very possible for it to contact the robot chassis. With the rigors of Stronghold, this is entirely within the realm of possibility.
From talking with some inspectors, that is the theory. The wire that caught fire went around a corner on a frame piece, and it is suspected that the insulation wore through because of robot movement.
In addition there were some other factors that may or may not have come into play. There may be a suggestion made on additional safety tests in inspection, or a change in wiring rules. I don't want to be more specific in case I am wrong.
(since 2004)
  #35   Spotlight this post!
Unread 15-04-2016, 22:16
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Thinking about this now, I realize that something like this could have happened to us. We had a almost unmeasurable frame short (later discovered to probably caused by a limit switch wire connected to a Talon SRX), which passed inspection because the resistance was higher than the required limit.
Last night and this morning we fried two Talon SRXes, and after a ton of troubleshooting we discovered that our LED ring power cable was being pinched and sometimes connecting positive to the frame. If the resistance was a little lower, I think the same thing could have happened to us. This appeared to be what destroyed the Talons.
  #36   Spotlight this post!
Unread 15-04-2016, 23:56
James Juncker's Avatar
James Juncker James Juncker is offline
Broken Robot Fixer
FRC #2834 (Bionic Black Hawks)
Team Role: Driver
James Juncker will become famous soon enough
First the test only requires the resistance across your frame to be above 3k ohms
Secondly from what I've learned from the team the short was caused by an old unused LED controller that became grounded to the already charged chassis, which led to the heat and fire
Thirdly the battery had been removed (or disconnected unsure) from the robot before being Taken off of the field after seen smoking on the field
And finally it was definitely a dry chemical extinguisher, the residue was swept and vacuumed up immediately following the incident, but multiple fire extinguishers were brought over to aid the fire, the first extinguisher had its safety pin break off when someone attempted to pull it rendering the extinguisher useless increasing the time it took to extinguish the flames.
I would like to congratulate the team however on successfully redoing most of their robot as well as getting their shooting back up and rinning! A great turn around for them after an incident like that. Go team!
2012 - member of 2834
2013 - electrical and mechanical function
2014 - driver, mechanical, and drivetrain
2015 - driver, drivetrain, mechanical knot tying
2016 - captain, mechanical, drivetrain
The FRC season has 3 steps
Eat
Build
Play
It is important to note that sleep is not included in these steps.
  #37   Spotlight this post!
Unread 16-04-2016, 21:30
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Look closely to the right of the robot in the video. A volunteer in a black shirt brought a CO2 extinguisher, and you can see him pull the pin, while another volunteer(white shirt, towards the back of the robot) was holding a dry chemical extinguisher. As others have said, the dry chemical was applied to the fire; you can see the guy in the white shirt aim and discharge his extinguisher.
Originally Posted by James Juncker View Post
...the first extinguisher had its safety pin break off when someone attempted to pull it rendering the extinguisher useless increasing the time it took to extinguish the flames.
This is probably why the dry chemical was used instead of CO2. After seeing the pin break, he decided it would be better to put it out with the powder than to let it burn to search for another CO2, if there was one. (Good idea.)
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Last edited by ctt956 : 16-04-2016 at 21:32. Reason: Post ID number in second quote
  #38   Spotlight this post!
Unread 16-04-2016, 21:47
Team Role: Student
Rookie Year: 2016
Originally Posted by Jon Stratis View Post
The overall reaction there seemed a bit less prepared than this one for Lake Superior a few years ago https://m.youtube.com/watch?v=YOd3mF1tvwk
Fast forward to the last 25 seconds, you can see immediate action behind the robot, and a fire extinguisher was out and ready on the field rather quickly!
There was also an "Injury Risk" sign next to the field. That exercise ball seemed to be an effective fire blanket!
  #39   Spotlight this post!
Unread 16-04-2016, 22:59
Team Role: Student
Rookie Year: 2016
I just found another video on YouTube from the field, recorded by YouTube user zenith828: https://m.youtube.com/watch?v=6QyrZZ3zIX4
  #40   Spotlight this post!
Unread 17-04-2016, 02:29
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Originally Posted by rsisk View Post
If there was a short with the frame, does this mean the frame isolation test during inspection was not done?
Or would this happen even if the frame isolation test passed?
I was the initial inspector on this robot. We did the isolated frame check and it passed with no issue. Wiring looked pretty clean actually.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
  #41   Spotlight this post!
Unread 17-04-2016, 08:13
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
wo faults obviously can still happen, but it's half as likely to happen as having one fault.
Is this true? If the likelihood of one fault occuring is 1/100, then the like likelihood of two at the same time is 1/10000.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
  #42   Spotlight this post!
Unread 17-04-2016, 09:23
Analog's Avatar
Analog Analog is offline
AKA: Bob Most
FRC #2619 (The Charge)
Analog will become famous soon enoughAnalog will become famous soon enough
Prank on team that caught fire
See pic
"WANTED - Schroedinger's cat. Dead and alive." 五行
  #43   Spotlight this post!
Unread 17-04-2016, 13:23
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: Prank on team that caught fire
Originally Posted by Analog View Post
See pic
Best Pit Prank ever!
  #44   Spotlight this post!
Unread 17-04-2016, 18:36
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
As Mike said, the team had passed initial frame isolation check. They "dropped coms" earlier in the day, and after a few minutes, I went personally to check on them.
They said they had already found the issue, a loose Anderson connection on the battery as well as cleaned up the VRM input which had a possible whisker.
I verified those and was about to leave, but asked the team if this was the first time. They replied they had other drops at other events. I did a frame isolation check and found the positive side grounded to the frame. The team had LEDs, and it was one of the first items I asked about. The team told me they were disconnected*.
We then dug through the various areas and found a different item that would clear the frame isolation. Once cleared, I returned to the field. couple hours later, the fire occurred. I do not have first hand details of how the fire was handled as I was covering the other field, and a large group of people were gathered around, and I thought it was some robot with a typical sensor wire or PWM that had been pinched and smoked.
After the fire was out, the issue was diagnosed as a power cable that had previously fed the LEDs. It had a barrel connector that was disconnected earlier.
We suspect that the positive side frame grounding was intermittent and the barrel connector likely was exposed negative. This lead to the power cable catching fire when both sides grounded to the frame. It was relatively thin wire, so a short caused it to catch fire relatively quickly.
The team did an amazing job of keeping a positive attitude. They had a student lead the rebuild, and she did an amazing job of keeping students on task. One of the new Michigan LRIs working the event stayed with them to ensure it was rebuilt properly. After initial teardown, we inspected the remaining components and had the team not only change out most of the electronics, but most of the pneumatics as well. We were quite fortunate no one was injured, and the team only missed 1 match.
I know a report was sent in about the fire incident, and I plan to talk some more with other LRIs about possible ways of improving and/or mitigating future incidents.
*I missed asking the team exactly how they "disconnected" the LEDs. I did not see the barrel connector, and assumed the disconnection was done properly. I will be adding a more thorough line of questioning when "something is disconnected".
  #45   Spotlight this post!
Unread 17-04-2016, 22:37
JimBryson JimBryson is offline
FRC #3656 (Dreadbots)
Rookie Year: 1011
JimBryson is an unknown quantity at this point
As lead engineering mentor for 3656, Dexter Dreadbots, I can confirm events are as Mike and Ike say above. I appreciate both of their help in inspecting and troubleshooting our robot.
Our failure analysis indicates that we had two shorts to our frame (usually you can assume that multiple failures won't happen at the same time--but as Ike says, there was foreshadowing, but we didn't catch the root cause). There was a 12V connection and a ground connection, both to the frame, leading to heating of narrow gauge wires and melting of the PVC insulation, and eventually to fire.
The ground connection was a no-longer used barrel connector wired on fine-gauge dual-extruded wire connected to a 20A breaker on the PDP (not so smart in hind-sight). The old wiring had not been removed, and the exposed barrel connector with GND external was in the robot, likely tucked away by a well-meaning team member. Excess length of wire was bundled together with a zip tie between the RoboRio and PDP. More on that later.
The disconnected LED power that Ike wonders about was our new wiring. The LEDs had been rewired (to another 20A breaker), but with powerpole connectors and GXL or TXL 20awg wire. These were unplugged while troubleshooting the ground fault. Checking wiring it seemed that pushing on the PCM bracket could make the ground fault come and go. A student rewired it, looking for "whiskers". The problem went away without a "smoking gun", and we assumed it was fixed. The unused barrel connector wires passed through the same area, so moving wires likely moved the barrel connector.
The 12v source was the battery anderson connector to the main breaker lug. The main breaker was mounted close (~1/4") to a vertical frame element. It is likely that with repeated battery installation and removals and a high impact game, that the lug may has spun slightly and have allowed current to the frame, by splitting the electrical tape or maybe the taping wasn't perfect. Difficult to tell after the fire. We could not recreate the 12v to the frame that Ike had seen, probably because we had unplugged the battery and moved the lug slightly while looking for the ground issue. Strain relief and more flexible wire for battery hookup would both be helpful with this, as well as additional clearance and better insulation.
I was confused how both could be happening at the same time, and assumed we were not understanding what Ike was saying. But we could not recreate the faults, and we were called to que.
During the match (see MIDC qual 36 video https://youtu.be/TfYDX4_zND8) our robot let out the smoke about 73s into the match. The driver hit the e-stop at 77s, and the FTA turned off the main breaker about 103s in. The robot appears to stop smoking. After the match was completed and the robot was on the cart around 250s after the match started (not on the same video) the video shot by Byting Bulldogs shows the active flames. Our drive coach had noticed that the RSL was back on about this time. This may be due to the 12v from the frame backfeeding into the PDP after all the insulation was burned off the paired wires.
It is likely that the short reoccurred after putting the robot on the cart, or that the heat had been slowly building. At some point the heat was enough to melt through a pneumatic line, adding oxygen to the "smoldering" insulation and allowing it to build to a full fire. Most of the fuel for the fire was from the PVC insulation on the LED wiring (coiled up for maximum heating and fuel potential) and pneumatic tubing. The RoboRio contributed some as well. Our standard for wiring is to use GXL or TXL wire, and the insulation on those wires scorched slightly, but it did not burn or melt.
Our students were great at repairing the robot. Many teams offered help and parts. We had students who could and did do the work, and had most of the parts ourselves. As a mentor, I was very proud to hand out tools, get spare parts and help clean up, but not to do the rebuilding. We moved the robot and tools outdoors to several tables because we would not all fit in the pit, and to allow the dispersion of the dry chemical residue. We decided to replace all the electronics and wire (not motor controllers though) and had to replace several plastic components and one pneumatic cylinder that may have been damaged.
It may look like a lot of time passed before the extinguisher was discharged, but heat damage was not extensive. We now have an extinguisher on our cart, and I am looking into procuring a CO2 one for less collateral damage. We have moved (and further insulated) the main breaker and are looking into designing and 3d printing an insulator box that would offer strain relief as well.
After 4 hours of rebuild we were on the practice field with a fully-functional bot having missed only one match, and are now on our way to St Loius!
