Go to Post I'm a zit. - Andy Baker [more]
  #76   Spotlight this post!
Unread 10-03-2016, 16:10
Trying to Help Trying to Help is offline
FRC #1729 (Monadnock 4-H Robotics)
Trying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud of
Re: Team Update 15 (2016)
Originally Posted by orangemoore View Post
Here is a picture of the new flaps.
http://www.chiefdelphi.com/forums/sh...d.php?t=145530
Thanks!
  #77   Spotlight this post!
Unread 10-03-2016, 16:24
Best Available Data
FRC #1778 (Chill Out!)
Originally Posted by CalTran View Post
There's a story here...
The 2009 field essentially turned robots into enormous Van der Graaf generators as the plastic wheels spun out on the floor. Then, the robots would occasionally make metal-to-metal contact with the alliance station walls -- ZAP! -- and the field (or robots) would crash.
That was a loooong weekend.
  #78   Spotlight this post!
Unread 16-04-2016, 17:32
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
When this update came out there was much lamenting on how teams would be hurt by this change.
Now that the dust has settled and all the pre-Championship events are done, whats the final analysis?
In all the matches that I watched the flaps seemed to stop the rolling boulders.
I didn't see any robots get hung up on the flaps (some interesting bounces off the supports around them).
For your team was the change a big deal or just big drama?
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
  #79   Spotlight this post!
Unread 16-04-2016, 17:33
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Balls are getting stuck in the flaps which can cause issues.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
  #80   Spotlight this post!
Unread 16-04-2016, 19:32
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
.. was the change a big deal or just big drama?
It depends. For us, it didn't make much difference, as we had enough clearance under the bar to make the low bar crossing in either direction in one smooth move, and the plastic is stiff enough not to fit into the small gaps we present to the ceiling unless you change direction.
I saw a few teams which were a lot closer to not fitting that had to stop and reset midway across, and occasionally they would get a flap caught somewhere that would probably not have happened with the solid fabric and bar. This increased their crossing time. I didn't see any total tortugas as a result of this, but I expect that there have been some, or would have been without robot mods.
  #81   Spotlight this post!
Unread 16-04-2016, 21:48
Dezion's Avatar
Dezion Dezion is offline
Coach | Strategy Co-Lead | Raawr!
FRC #4935 (T-Rex)
Rookie Year: 2015
Dezion is an unknown quantity at this point
Our robot was intentionally designed to avoid getting caught/catching on the original low bar design. We even included a step in our autonomous code to raise the the flap, so there would be no chance of it getting stuck in our robot. With the new flaps, this step of our autonomous code was useless. The new fabric itself presented no issues and our robot never got caught on it or damaged it. From my experience, I have never seen a robot get caught completely in the low bar due to the new fabric (that's not to say robots haven't got caught in the low bar due to other reasons).
The biggest issue that I noticed with the new low bar fabric was boulders getting stuck in the defense. This would mean that if we wanted to cross the low bar when a boulder was stuck in it, we would have rid the boulder from our robot first, causing us to spend a bit more time crossing the defense(or we could incur a foul). As well, occasionally, these boulders could interfere with our rhino treads as we crossed the defense.
  #82   Spotlight this post!
Unread 16-04-2016, 23:37
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
We're not 100% certain it was the cause, but it's possible that the car wash flaps unplugged our absolute encoder on our shooter arm in a match, which would have been protected with the single-piece weighted bar flap.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
  #83   Spotlight this post!
Unread 17-04-2016, 09:18
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is online now
45 Alumni
AKA: Peyton Yeung
Balls getting stuck in the flaps at the Indiana District Championships definitely messed up our alliance a few times. You can't drive though it with a ball (without getting a penalty) and it often jams up robots going from the courtyard to the neutral zone if the ball is stuck there.
461 Westside Boiler Invasion
45 Technokats
