Go to Post I think there is much to be learned from working in teams, and team projects, but even more when you go out on your own some time for something you are truly passionate about. - paul_v [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 16-04-2016, 16:46
Re: Quick OPR Question
There are at least three ways you could deal with this...
Eugene Fang and I have been PM'ing about this. He came up with a clever and very effective method. See his discussion here.
Unread 17-04-2016, 09:45
Ed Law's Avatar
Ed Law Ed Law is offline
no team (formerly with 2834)
Ed Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond repute
The method looks good but I am not sure if it is necessary. Here is my position on how to use OPR. Current event OPR should not be used until you have at least 4 or 5 matches depending on number of teams. Before that, I use max OPR from prior events. So in a way, it is similar to what Eugene Fang did. The match "prediction" using OPR is just a check. Since you are at the event, you should always use scouted data instead of OPR.
The work Eugene Fang did was great in showing how long it takes to converge.
Please don't call me Mr. Ed, I am not a talking horse.
Unread 17-04-2016, 10:06
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Are the xOPR and ixOPR calculations only possible if every attending team has competed at least once? If so, that severely limits the usefulness of this effort, because this criterion is not met for a large majority of events.
Unread 17-04-2016, 10:45
Obviously xOPR and ixOPR are possible without this constraint, since Eugene posted convergence graphs for Palmetto. What is the "other source for OPR initialization" that is used for cases like this?
Unread 17-04-2016, 11:12
I don't know what Eugene used.
I haven't done any numerical experiments yet to confirm this, but if there is no prior OPR value for a given team at an event, I think you can just pick a reasonable number to seed the calculation, and let the 2x iteration take care of things from there.
Unread 17-04-2016, 11:24
Here is the basis/motivation for the ixOPR algorithm. Note how many matches must be played before the OPR stabilizes.
ID:	20617  Click image for larger version
ID:	20618  Click image for larger version
ID:	20619  Click image for larger version
ID:	20620  Click image for larger version
Unread 17-04-2016, 11:28
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
What Ether said shares my view on the initialization.
In the graphs, I used 0 as the initialization, which I knew was a bad idea at the time. I've been trying out using the average match score for the event (up to the currently played match) as the initialization for teams without past events with better* results.
* There's a lot of "fuzzy math" going on here and I know OPR is a pretty poor metric for estimating a team's performance, whether there are few matches played or many matches played. I'm just curious to see how accurate one can expect match predictions to be using no other source of scouting data.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
[IMG] code is Off
