Go to Post IMO the main idea behind FIRST is for the mentors and students to work together to produce a machine that the students could never have produced on their own. - Tim Sharp [more]
Unread 17-04-2016, 10:46
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
PID Loop Controller with a Servo
Is it possible to use a servo as the output for for a PIDLoop? I am looking into some test vision tracking. The camera will be mounted to a servo and I wanted the camera to track the center of the target and move with it.
Unread 17-04-2016, 11:35
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: PID Loop Controller with a Servo
Great question!
I have not done this myself but I assume you would either need to add\subtract microseconds, or degrees, to your servo position signal in proportion to the error, and get your error from target position in the image.
I know 254 has a continuous rotation servo controlling the elevation of their shooter hood this year. I don't know if they use PID or not.
Unread 17-04-2016, 12:02
Building off billbo911 post:
I was thinking about it and I have a theory. Grip reports back the distance to the center of the target; x and y. Let's say the distance x was 50. If you did some testing to figure out how much the x error changes for each degree of rotation the servo makes then you could make a ratio. So basically you convert the error into degrees of change and then add it or subtract it to the current angle.
The only problem would be the ratio would change based on the distance from the target. That throws some difficulty in the theory.
Unread 17-04-2016, 12:12
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
Depending on the servo and controller (I might be completely wrong, I've only tested this on the arduino) you might run into an error where you receive no real feedback from the servo. Some arduino libraries will only report the last value you've sent to the servo, which makes testing for values useless. It might be worth your time to test this hypothesis out with the hardware you plan on using to make sure it truly reports its absolute location and not what the software thinks.
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 17-04-2016, 12:34
I am getting a test bed built to do some testing with it. The current servo angle you could store as a separate variable and use that to update the new location. Then replace the variable with the new location
Unread 17-04-2016, 12:53
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Forgive me for not knowing, but how do you get feedback from a hobby servo? Don't they already have PID built in too?
Unread 17-04-2016, 13:08
I think they do. The more I think about this the more I'm thinking of not using a PID loop and using the distance to the target as a ratio of the angle. The only problem is that the distance away from the target will change that ratio. For instance if you are two feet away changing the angle by one degree will be different if you are five feet away
Unread 17-04-2016, 13:20
billbo911's Avatar
Angle to center of target is independent of distance.
You will need to make less adjustment the further away you are but the error reported will be less as well.
What you may run into is a lack of resolution to adjust the servo accurately. That's why I mentioned using microseconds instead of degrees. ie. (~ 1000 vs. ~180)
Unread 17-04-2016, 15:00
Yes resolution would fix that but how would you do that? Also if it's a 180 servo how would you account for it being greater then 180 degrees
Unread 17-04-2016, 15:47
billbo911's Avatar
That would likely dictate that you would need to not direct mount to the servo. You would probably have to build a specific interface with gearing to account for the extra degrees of motion.
Unread 17-04-2016, 15:52
What I meant is how would you control the servo in code using microseconds?
Unread 17-04-2016, 17:03
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Servos are written a signal that is 1000-2000 uS high, then 20ms low. The number of uS you write is directly proportional to the angle; 1000uS is 0*, 1500uS is 90*, and 2000uS is 180*. There is some error but for relative angle movement (turn 5* to the left) it should be fine.
Unread 17-04-2016, 17:48
Sounds good but how do you control that in Java based programming
Unread 17-04-2016, 17:54
Is the camera indeed mounted to the servo? Or is the camera mounted to a turret which is to be actuated by the servo?
Unread 17-04-2016, 17:55
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
There might be a way to access it in the Servo classes for the RIO, but I'm not familiar enough with it to say for sure.
You could also manipulate timers directly and make your own class for interfacing with them.
Or you could send data to an Arduino, which has built-in Servo libraries, at the cost of lag time.
