Go to Post Obligatory warning: School comes first. If you have to choose between doing homework and going to a build season meeting, do the homework. - Billfred [more]
  #31   Spotlight this post!
Unread 06-04-2016, 12:13
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Re: Ball bouncing out of the high Goal
It's part of the game, though it is annoying when it happens.
https://youtu.be/qjoAI0x324I?t=46s
https://youtu.be/17JDcQaSIWw?t=26s
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
  #32   Spotlight this post!
Unread 06-04-2016, 12:34
Jim Schaddelee's Avatar
Jim Schaddelee Jim Schaddelee is offline
Team 107 Holland Christian / Metal
None #0107 (Team Robotics)
Jim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud of
I think FIRST should fix the high goal. They fixed the low bar because the field did not meet the intent of the games design. The fabric didn't keep the balls out of the court yard while still allowing robots to pass through. The intent of the chains is to stop the balls after being shot into the high goals. If the balls goes in one opening and out of another this seem to be a field design issue. I think logic dictates the purpose of the chains is to stop the balls. How hard could it be to add a few more chains or at minimum make sure the chains are not twisted before the match.
jim
Team 107 Holland Christian / Metal Flow
2005 Midwest semi finalist
2005 Johnson & Johnson sportsmanship (midwest)
2005 West michigan Champs with 93 and 66
2005 Johnson & Johnson sportsmanship (west michigan)
2005 web site award
  #33   Spotlight this post!
Unread 06-04-2016, 12:58
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
That wasn't the problem. The original fabric literally didn't survive the rigors of the game.
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
  #34   Spotlight this post!
Unread 06-04-2016, 15:16
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
jim
I believe your statement here is incorrect (or just an assumption)
Please show where the GDC has expressly stated that the intent of the chains is to stop the balls after being shot into the high goal.
It is my belief (I have no proof) that the intent was to DAMPEN the shot, and that is what the chains do.
___________________
- Tennyson, Ulysses
  #35   Spotlight this post!
Unread 06-04-2016, 15:40
BoilerMentor BoilerMentor is offline
FRC #1747
BoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond repute
Or is it that teams didn't appropriately design and test to avoid breaking the game rules by damaging a field element? Our team tested with a low bar curtain weighted with nearly twice what the spec was to ensure we wouldn't be accused of damaging the field.
I know a number of teams have been warned about crossing the rock wall, because they're snapping of pins when they do. Shouldn't the same have happened to teams damaging the low bar curtain? I think if anything the assertion that FIRST should change the goal to accommodate the laser-rocket-boulder-launchers is probably a little excessive.
I'd venture 1747 is in the top 10% in terms of boulder energy and we very irregularly miss shots because the ball bounces back out. Let's play the game we got the best we can and understand these are all considerations in the design process.
2006-2008 FIRST Team 1741 Red Alert-Founding Student
2008-2011 FIRST Team 1747 Harrison Boiler Robotics-College Mentor
2012 FIRST Team 4272 Maverick Boiler Robotics-Founding College Mentor
2013-Present FIRST Team 1747 Harrison Boiler Robotics-Engineering Mentor
  #36   Spotlight this post!
Unread 06-04-2016, 16:01
Professional Stat Padder
I just wish these balls would act predictably. But that's not FIRST's problem, that's a physics problem. FIRST even went out of their way this year to try to find a ball with a fairly consistent makeup. The way I see it, the chains are a fairly good solution to this problem that work most of the time, and while balls bouncing out can be annoying, it's just an unfortunate part of the game that can be, much of the time, mitigated.
(2015-Present)
  #37   Spotlight this post!
Unread 06-04-2016, 16:06
Chris is me's Avatar
AKA: Pinecone
I just wish that FIRST would include drawings for the chains in both the full and low cost field diagrams.
Yes, the chains are a part of the game teams have to deal with, but if we're going to use that logic, then the low cost fields need to include them. Chains don't cost a lot!
  #38   Spotlight this post!
Unread 06-04-2016, 16:09
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Which in itself brings up an question I will most likely never know the answer to.
If you have the choice between dampening a shot so it lands in roughly the same place, stopping a shot, or deflecting a shot. Which one is the most cost efficient?
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
#GLITTERFORCEHYPE!
Play is for kids this is serious...
  #39   Spotlight this post!
Unread 06-04-2016, 16:38
AlexanderTheOK AlexanderTheOK is offline
Guy
AlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really nice
The fundamental issue here is that the real field acts differently from what teams may have prototyped with. I imagine if you look back on games with simpler and cheaper field elements you will see less of this. This game specifically is much harder to make an adequate test environment for.
The difference between the fabric and this issue however is the frequency with which it happened. Evidently teams COULD have tested more rigorously, but FIRST could have also foreseen the issue through their own testing?
When an issue like this happens with high frequency, I feel the conclusion should be that FIRST itself did not account for this, and should have either communicated to teams better regarding prototyping for the low bar, or designed it in such a way that teams don't see issues on the field that they wouldn't see while practicing (ie. damage to the low bar due to extended use.)
When it happens with lower frequency (like the rejection issue) it can be reasoned that other teams DID foresee this issue, leading me to believe that FIRST did a better job of dealing with the issue before kickoff. This obviously doesn't mean they did a perfect job, but it seems right on the line of reasonable here.
So the core question regarding balls bouncing out is: Did FIRST communicate the requirements regarding scoring and the interaction of the balls with the goal adequately.
As this is a subjective metric, (and different individuals may have different definitions of "adequately") I don't believe we can say this question has an answer unless there is near unanimous agreement among the community. (as there was with the fabric)
Last edited by AlexanderTheOK : 06-04-2016 at 16:38. Reason: incorrect punctuation
  #40   Spotlight this post!
Unread 06-04-2016, 16:56
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Which is why I posted the way I did.
By dampening rather than stopping the shot, it effectively limits the energy (speed) in the shot.
JMHO
___________________
- Tennyson, Ulysses
  #41   Spotlight this post!
Unread 06-04-2016, 17:09
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
It would have been interesting if FIRST had lined the inside of the high goal with memory foam like 2010.
461 Westside Boiler Invasion
45 Technokats
  #42   Spotlight this post!
Unread 06-04-2016, 17:28
I agree with you , call it Stopping ( probably a bad choice of words) or " dampen " many shots are going through one side and out the other. At West Michigan we put the boulder in the tower 10 times in one match , three times the chains did not dampen the shots. 30% failure rate is poor design. I think the chains are getting tangled at times because they need to be longer. The point is if the GDC wanted us to finesse the boulders into the tower why have chains at all. Saying that,I feel it up to the teams to adapt. Check before the match to see if the chains are twisted, change the angle of your shot or take a little power out of the shooter.
2005 web site award
  #43   Spotlight this post!
Unread 17-04-2016, 12:35
mac mac is offline
AKA: Thomas (just give me a crabcake)McCubbin
FRC #0686 (Bovine Intervention/Jagbots)
mac is a jewel in the roughmac is a jewel in the roughmac is a jewel in the roughmac is a jewel in the rough
My Jagbots 4638 had a shot at Chesapeake Champs. Went in left side then out the right side. High goal. That should be ten points not zero points. Right guys? Amen
  #44   Spotlight this post!
Unread 17-04-2016, 13:21
tindleroot tindleroot is offline
Free Scouting Help to All
AKA: Casey LeeVan
FRC #4272 (Maverick Boiler Robotics)
tindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond repute
If a basketball rolls around the rim and jumps back out, does that count? Of course not.
The boulder has to stay in the goal to count for points, and exit through the corral.
2012-2013: FTC 4601 (student)
2014-2015: FRC 135 (student) - 5 banners in 2 years!
2016-present: FRC 4272 (mentor)
Thanks to all of our alliance partners!
11, 51, 68, 201, 234, 868, 1108, 1241, 1760, 3147, 3301, 3487, 3865, 4269, 4485, 4580, 5188
  #45   Spotlight this post!
Unread 17-04-2016, 17:47
lkg9999 lkg9999 is offline
FRC #4761 (Robockets)
lkg9999 is an unknown quantity at this point
Send a message via MSN to lkg9999
The issue with the tower chains was dramatically highlighted during yesterday's semi-finals at New England champs. A high-goal shot resulted in one of the boulders getting hung up in the chains, and a subsequent shot knocked the wedged boulder back out of the tower. In this case, the refs called a field error, stopped the match and worked on the chains before restarting the match.
This was right after high drama where a boulder had not been accurately counted during a previous match, transferring the win to the other alliance. The now-losing alliance was able to effectively contest that the uncounted boulder was a field error and the match should be replayed.
Who needs daytime soaps when one can watch FRC matches?
