Go to Post We should create string networks at Nats. Just have miles of string running between the Georgia Dome and the GWCC. :D - Ctrl Alt Delete [more]
Unread 17-04-2016, 16:06
Ryan-Greenblatt Ryan-Greenblatt is offline
A foolish programmer
FRC #0900 (Zebracorns)
Rookie Year: 2015
Ryan-Greenblatt has a spectacular aura aboutRyan-Greenblatt has a spectacular aura about
Re: Issues with Motion Profile Generator
The issue is that the motion profile results in a final position of 1.7956 instead of the target final position of 4. Look at the attached images, the position line in the spreadsheet and the vi both don't end up at 4. I'm assuming that if this motion profile was used on a motor the motor would end up turning just 1.7956 units instead of 4, because the position line is effectively just calculated by integrating the velocity line and the position and velocity arrays are the only pieces of data used to control the motor, but I haven't tested it.
