Go to Post Don't you hate it when you can't find the droids you're looking for? - Jared Russell [more]
Unread 17-04-2016, 09:33
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
pic: Stripped VexPro gear
Unread 17-04-2016, 13:35
Maxwell777's Avatar
Maxwell777 Maxwell777 is offline
Is allowed to touch stuff now
AKA: Jackson Gray
FRC #0842 (Falcon Robotics)
Maxwell777 has a spectacular aura aboutMaxwell777 has a spectacular aura aboutMaxwell777 has a spectacular aura about
Re: pic: Stripped VexPro gear
On the plus side, now you have a brand new dual sector gear.
But why?
Unread 17-04-2016, 15:44
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
I'm curious about the circumstances that caused this; I'm having a hard time visualizing how getting stuck in the low bar could cause this kind of damage to a gearbox. Any more details you can share?
Unread 17-04-2016, 15:55
frcguy's Avatar
Unregistered Unuser
Sure. During auto the robot would go through the low bar, and then attempt to back over it. If our alignment was off, when backing up, the robot went in at a slight angle and was pushing against one of the side supports for the bar. The motors proceeded to run while the robot was pushing against the support for a good 5-7 seconds, causing the gears to grind. This happened once or twice until we dialed in our positioning. For context, this gear is part of the third stage on the 2 CIM ball shifter. It actually drives the output shaft.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 17-04-2016, 19:53
Mechvet Mechvet is offline
Certified Public Menace
FRC #0114
Mechvet is a jewel in the roughMechvet is a jewel in the roughMechvet is a jewel in the rough
We blew every tooth off of two of the VexPro 14tooth 3/8 hex gears.
Turns out aluminum gears just aren't quite rated to the level of impact we were subjecting them to.
Unread 17-04-2016, 20:00
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
For the 14T I would personally only use the steel in anything that takes moderate to high load and the aluminum one for low load. Or just use the steel one all the time since the weight difference is minor.
R.C.
MadTown Robotics Team 1323
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
1771 had this exact thing happen to them at the PCH DCMP.
Actually, the gear stripped, we replaced it, and it stripped again. So we replaced it, again.
The robot still managed to drive, the driver barely noticed any difference in performance.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 17-04-2016, 20:12
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
It only really takes one tooth to break or chip to cause all the teeth to be stripped off the gear, as I believe that the shrapnel causes the next tooth to be clogged and break.
Aluminium gears are usually fine, especially 7075 ones. But if you can, it can be good practise to use 4140 for the smallest gears (isn't a huge weight increase for small gears)
With gears that small there is only a small amount of tooth contact, meaning that the forces aren't spread out over a huge area. Something we found with the impacts of stronghold is that it can cause cantilevered gearboxes( CIM's are heavy and have a lot of inertia) to move up and down, which can mean that in gearbox 3rd stages the amount of tooth to tooth contact can be decreased. Also teams are putting much more torque on them than usual, for example if a team normally uses a shifting gearbox with a 11fps low gear on a year with an open field and 4inch or 3.25inch wheels, and then they change to 8inch wheels and a 6fps low gear, then the final stage is experiencing almost 4 times the torque.
Depending on how you are using it, a 4140 Steel gear http://www.andymark.com/product-p/am-2354.htm might be better for your purpose
Facebook
Unread 17-04-2016, 20:15
Not quite...
What usually happens is that if one tooth breaks off, the next tooth takes more force than it would ordinarily (fewer points of the same force being applied = more stress as well), plus a chance of shock loading. Then that one takes off... repeat until you're out of gear teeth.
Unread 17-04-2016, 20:22
billhcheese's Avatar
billhcheese billhcheese is offline
AKA: Bill Huang
FRC #2415 (The Wiredcats)
billhcheese is a glorious beacon of lightbillhcheese is a glorious beacon of lightbillhcheese is a glorious beacon of lightbillhcheese is a glorious beacon of lightbillhcheese is a glorious beacon of light
We learned that the hard way lol, went kaput in elims during finals our first district event, we now use steel 14t on our drivertrain lol.
Unread 17-04-2016, 20:27
pilleya's Avatar
Elec+Mech
Not quite...
When only a small number of teeth are removed, there is normally a lot of damage to the other teeth. But this damage doesn't seem that it could be all caused by the normal meshing of the other gear. In this case is it the shrapnel that is the cause of this?
Facebook
Unread 17-04-2016, 20:29
In that case, yes, it would be any remaining bits. You'll also want to check the mating gear(s) for damage, as damage to metal tends to transfer to any metal of similar softness that it hits... I wouldn't be surprised if there was some "hard whacks" causing damage as well.
Unread 17-04-2016, 23:19
FRC #0114
Absolutely. Our fix was to go grab some 3/8 AM hex gears and face them down to the required width. No issues after we switched out the aluminum gears.
<snip>
This is the differing factor.
However, two years in a row of COTS gearboxes failing us has prompted the decision to return to custom boxes. They're heavier (and a touch more expensive), but they never broke.
Unread 18-04-2016, 00:10
Landonh12's Avatar
Landonh12 Landonh12 is offline
270 points
AKA: Landon Haugh
FRC #0364 (Team Fusion)
Landonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud of
We had the same thing happen to us on our scaling mechanism. I believe we were using the 60 tooth 1/2 hex bore gear from VexPro. We have a CIM Motor that has 3 stages of AndyMark GEM Planetaries on it, along with a 1:3 gear ratio coming out of it.. totaling up to around 900 ft/lbs of torque. At Bayou, we went out in the quarter finals because we had 4 teeth shear on that gear. We couldn't scale because the robot sagged and got caught in that section of the gear that had stripped.
We ordered a steel gear from McMasterCarr and welded in a 1/2 inch socket. It worked throughout Rocket City flawlessly.
Team Fusion 364 - Driver/Programmer 2012-2015; Controls Mentor 2016-Present
Unread 18-04-2016, 00:18
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
That would certainly do the trick. Makes me glad we traction-limited the low-gear on our drive system.
That said though, of the 100+ VEX aluminum gears we've used on our competition robots over the past 3 years, the only time I've had issues with chipping teeth was on the choo-choo mechanism on our 2014 shooter (which, too be fair, was poorly designed, and over tensioned) so don't let them scare anyone away for most normal uses.
