Go to Post The robotics, strategics, and technology make up the higher wavelengths, the adrenaline of competition the midband, and the low frequencies that pull at the heart, well that's the people. - John Wanninger [more]
Unread 17-04-2016, 20:15
EricH EricH is online now
Re: pic: Stripped VexPro gear
Originally Posted by pilleya View Post
It only really takes one tooth to break or chip to cause all the teeth to be stripped off the gear, as I believe that the shrapnel causes the next tooth to be clogged and break.
Not quite...
What usually happens is that if one tooth breaks off, the next tooth takes more force than it would ordinarily (fewer points of the same force being applied = more stress as well), plus a chance of shock loading. Then that one takes off... repeat until you're out of gear teeth.
Unread 17-04-2016, 20:27
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Not quite...
When only a small number of teeth are removed, there is normally a lot of damage to the other teeth. But this damage doesn't seem that it could be all caused by the normal meshing of the other gear. In this case is it the shrapnel that is the cause of this?
Facebook
Unread 17-04-2016, 20:29
In that case, yes, it would be any remaining bits. You'll also want to check the mating gear(s) for damage, as damage to metal tends to transfer to any metal of similar softness that it hits... I wouldn't be surprised if there was some "hard whacks" causing damage as well.
Unread 17-04-2016, 23:19
Mechvet Mechvet is offline
Certified Public Menace
FRC #0114
Mechvet is a jewel in the roughMechvet is a jewel in the roughMechvet is a jewel in the rough
Originally Posted by R.C. View Post
For the 14T I would personally only use the steel in anything that takes moderate to high load and the aluminum one for low load. Or just use the steel one all the time since the weight difference is minor.
Absolutely. Our fix was to go grab some 3/8 AM hex gears and face them down to the required width. No issues after we switched out the aluminum gears.
<snip>
Also teams are putting much more torque on them than usual, for example if a team normally uses a shifting gearbox with a 11fps low gear on a year with an open field and 4inch or 3.25inch wheels, and then they change to 8inch wheels and a 6fps low gear, then the final stage is experiencing almost 4 times the torque.
This is the differing factor.
However, two years in a row of COTS gearboxes failing us has prompted the decision to return to custom boxes. They're heavier (and a touch more expensive), but they never broke.
Unread 18-04-2016, 00:10
Landonh12's Avatar
Landonh12 Landonh12 is offline
270 points
AKA: Landon Haugh
FRC #0364 (Team Fusion)
Landonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud of
We had the same thing happen to us on our scaling mechanism. I believe we were using the 60 tooth 1/2 hex bore gear from VexPro. We have a CIM Motor that has 3 stages of AndyMark GEM Planetaries on it, along with a 1:3 gear ratio coming out of it.. totaling up to around 900 ft/lbs of torque. At Bayou, we went out in the quarter finals because we had 4 teeth shear on that gear. We couldn't scale because the robot sagged and got caught in that section of the gear that had stripped.
We ordered a steel gear from McMasterCarr and welded in a 1/2 inch socket. It worked throughout Rocket City flawlessly.
Team Fusion 364 - Driver/Programmer 2012-2015; Controls Mentor 2016-Present
