Re: pic: Stripped VexPro gear
That said though, of the 100+ VEX aluminum gears we've used on our competition robots over the past 3 years, the only time I've had issues with chipping teeth was on the choo-choo mechanism on our 2014 shooter (which, too be fair, was poorly designed, and over tensioned) so don't let them scare anyone away for most normal uses. Last edited by cbale2000 : 18-04-2016 at 00:21. |
We broke one at our district championship event. The interesting and slightly concerning thing is that it wasn't at a particularly high load, just a sustained, consistent torque load due to a misaligned limit switch. The gear that failed is driven by a PG27 with a 16t steel gear on the output shaft and is only driven at partial power.
Unfortunately there isn't a steel option like these: http://www.vexrobotics.com/vexpro/mo...ore-gears.html We only use a portion of the gear's circumference to actuate our intake, so rotating the gear is an option we'll likely pursue at champs if we have the down time. |
Does the PG27 have a 9015 or a RS775-125, as there is a massive difference in torque and power output.
RS775. It broke on the "down" actuation though, which is much lower applied power systematically. My guess is it's actually more related to shock load of the intake coming up against the hard stop that sets the height. It didn't affect our performance this time, so it isn't nearly as big of a deal.
