Go to Post Scout team, assemble! (preliminarily) - PayneTrain [more]
Unread 29-03-2016, 21:56
indieFan indieFan is offline
RoboDox and LVHS - Missing you!
FRC #5941
indieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond repute
Re: Usign a 2-1/2 bore, 24" stroke pneumatic cylinder.
My team is using a 2" cylinder with a 24" stroke to hang our robot, but we're having problems retracting and lifting.
We were using a single air tank at the first competition we went to. It was found that gently nudging the robot at the start of retraction seemed to get it going.
We then added two more air tanks and checked the gauges immediately after we extended to see if that was the issue. The high gauge read about 50psi, if I remember correctly, the low was 50psi for a split second and then back to 60psi. We did not have the chance to test actually hanging with this set up.
We took our robot to a practice field, but our controller was not working correctly. To test our pneumatics, we tried to manually trigger the solenoid. This did not produce the results we were hoping for; however, it is unclear if this was due to the manual triggering or a pneumatics issue.
Our robot weighs 77lbs with battery (and I believe bumpers).
My questions:
1. How much time does a pneumatic of this size take to refill?
2. Will the 2nd and 3rd air tanks mitigate the time in question 1?
3. Is there anything else that can be thought of in relation to pneumatics that might need troubleshooting?
Thanks for any help,
indieFan
Unread 29-03-2016, 22:13
DanielPlotas DanielPlotas is offline
FRC #1984 (Raider Revolution Robotics)
DanielPlotas will become famous soon enoughDanielPlotas will become famous soon enough
If you use constant force springs in line with your cylinder, you can use a smaller diameter cylinder. There's a voucher for six free springs from Vulcan in the KOP.
Sleep? What is that? A rare Pokemon?
Unread 18-04-2016, 09:16
CloakAndDagger CloakAndDagger is offline
FRC #0074 (CHAOS)
Rookie Year: 2015
CloakAndDagger is on a distinguished road
We use two 1 3/4" BIMBA cylinders, and hang by the rods. We haven't had any pneumatic problems yet
We have 5 air tanks also, and run it off of two solenoids and two regulators. The solenoids each lead to both cylinders, and are slaved together. We do this because the internal diameter of one solenoid it too small to facilitate rapid airflow
Unread 18-04-2016, 09:43
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
This constant-force spring thing seems like a good idea, but it means that it takes more pressure (equals force) to extend your rod initially. Which means it uses lots of your stored air reaching up for the bar.
I wonder if it would be better to actually put a pressure regulator between the extension-end of the air cylinder and the air solenoid valve and just extend at say 5-psi? If you can still reach up very fast but not actually pressurize the extending side of the air system to a very high number, you'll save all of that stored pressure in your tanks for the lifting-retracting stage.
We built a robot-lifting cylinder in our prototyping at the start of build--used a 2" dia--which should've been able to lift 176 lbs, but with a 120lb robot, battery, bumpers and the added friction of dragging the bumper up the wall, it didn't move very well at 60 psi and was very slow after the air in the storage tanks was used up.
I hope you can make it work. good luck.
Also note,
I know these equations are easy, but if you need a quick-reference for how much force each bimba-sized cylinder makes at 60 psi for pushing and pulling, I've created this easy chart.
https://docs.google.com/spreadsheets...it?usp=sharing
Unread 18-04-2016, 10:27
pfreivald's Avatar
AKA: Patrick Freivald
Unless you add in the additional pressure regulator, you're extending at 120 psi anyway...so add ~75 lbs (or however much) of constant force springs, extend at full pressure to extend them, then let them help you on the way down. The pneumatics will be smaller, so you'll be saving air on the up and down strokes (which might obviate the need for the additional regulator to bring down the extension pressure.)
Some math (maybe some graphs with an eye toward that 150-lb requirement) should help you determine an optimal* amount of spring vs. bore.
*optimal, of course, depending on which resources you're trying to preserve.
As another idea, consider constant force springs that are already extended along the body of the cylinder, but don't lock in to the rod until it's fully extended--so you don't have to push against them at all, but they'll help you pull it back. Might require some cams, spring-pins, or whatnot.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 18-04-2016, 10:48
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Your stored air pressure is a max of 120 PSI. Most pressure switches are shutting off at around 115 indicated. Your working air pressure shouldn't ever be above 60 psi.
Unread 18-04-2016, 13:10
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
That's by design; see rule R17 C. Unless I'm misunderstanding your post you need to take a good look at R90.
Mentor http://www.teamtitanium.org/
Unread 18-04-2016, 16:32
hrench's Avatar
AKA: Bob Hrenchir
Unless you add in the additional pressure regulator, you're extending at 120 psi anyway...so add ~75 lbs...
I'm sure as FrankJ mentioned, you mean that the cylinder is operating at running pressure, 60 psi (or less depending on your robot), not 120 or 75, but I say that the pressure inside the cylinder while the piston is moving is definitely Not that high.
What I mean is that the piston will begin moving immediately when the pressure on the pushing-side of it has exceeded the resistance-- friction loads, weight and if you have them, springs. The piston will continue to move at very low pressure staying just ahead of the friction and load until the time that the piston reaches then end of travel. Only then does any real pressure build up inside the cylinder on the 'up' side of the piston.
So if you have a pressure regulator between the valve and the piston, you'll be able to limit the pressure on the 'up' side of the piston to conserve air. Lots of it actually. You'll still need all of the pressure you can muster to lift the robot, so you can't put the regulator before the valve or anyplace that would limit the 'down' pressure.
So if you don't have springs to overcome, you'd be able to extend the lifting hook under very low pressure, like 5 psi (a 2.5" dia has 4.9 sq inches, at 5 psi is close to 25 lbs force)
As another idea, consider constant force springs that are already extended along the body of the cylinder, but don't lock in to the rod until it's fully extended-.
Yes, this is a very interesting idea too. Though I would rate it as 'difficult'. Of course there are teams that completely lifted the robot with springs that were already storing energy too (I saw 1619) So in this iteration, if you used an air cylinder, it would only need to get the hook up to the bar. Could be tiny.
Unread 18-04-2016, 16:45
pfreivald's Avatar
Yeah, yeah, yeah. Fingers before brain and all that.
60 psi working, not 120.
Team 1551
I write books, too!
Unread 18-04-2016, 16:49
FRC #0074 (CHAOS)
Rookie Year: 2015
Not seeing a subsection of any type within r17, so not sure about that one
In regards to r90, I'm not sure that a solenoid actually qualifies as a valve, because (As I understand it) a valve contains or limits pressure, whereas a solenoid simply directs it one direction or another, without limiting it in any way.
Based on that, we are basically just connecting two pneumatic tubes together.
I'll check on that with our mentors in our meeting tonight though- I am but a humble programmer, so it is very likely that I'm incorrect on that.
Unread 18-04-2016, 17:04
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I'm sure that was supposed to be R77C:
The only pneumatic system items permitted on 2016 FIRST Robotics Competition ROBOTS include
the items listed below.
  • C. Solenoid valves with a maximum 1/8 in. NPT, BSPP, or BSPT port diameter
Yes, a solenoid valve is a valve. Valve outputs on an FRC robot may pass to the input of another component (or components), or vent to atmosphere.
Unread 18-04-2016, 17:07
hrench's Avatar
AKA: Bob Hrenchir
... I'm not sure that a solenoid actually qualifies as a valve, because (As I understand it) a valve contains or limits pressure, whereas a solenoid simply directs it one direction or another, without limiting it in any way.
I've been cringing at this terminology/usage all year.
A 'solenoid' is a controlled magnetic field. We use a solenoid to move a piece of iron magnetically that operates an air valve.
I sometimes refer to them as 'solenoid air valves' just so the people that call them 'solenoids' will understand, but yes, they are definitely air valves.
And if you have two plumbed together on your robot to operate two cylinders, I encourage you to separate them before your next inspection.
kstl99's Avatar
kstl99 kstl99 is offline
AKA: Kevin
FRC #1922 (Oz-Ram)
kstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond repute
Send a message via AIM to kstl99
They are solenoid valves.
In 2010 when you had to kick a soccer ball we (1922) used 4 solenoids all plumbed to one cylinder and had one of the strongest kickers around, strong enough that Dean Kamen was examining it at GSR. The next year was the first year that was not allowed. We kinda think we caused this rule.
Unread 18-04-2016, 22:03
FRC #0074 (CHAOS)
Rookie Year: 2015
Alright, things were cleared up for me at our meeting: They each route to separate cylinders, completely my bad on that one.
