Go to Post Winning a match is not something a robot does, winning is a team effort that requires the cooperation of dozens of individuals. - Andrew Schreiber [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 12-03-2016, 21:48
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Progressively longer to initialize Python
So we just came back from an event and I noticed as time went on, the starting of robot code took an increasing amount of time, starting from about 4 seconds at unbag to 15 seconds at bag. It didn't seem to be user code because I have prints at the start and the end of robotInit and it was printing the start message a second or two before the robot code led turns green. I was wondering if anyone else noticed this or has a reasonable explanation for the lag.
Also, kinda related, but halfway through the competition the first deploy stopped working. We had to cancel the first deploy while it was looking for the RIO and restart deploy to get it to work (sometimes multiple times). It wasn't connection or anything because I made sure the drive station showed Robot code led green before deploying but it was no help..
Unread 12-03-2016, 22:32
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: Progressively longer to initialize Python
Did not have this problem today. Do you have gyros, camera, navx (though, we have a NavX and it works great).
I think it's mdns related. I had issues with this yesterday on my mac, and basically each time that pyfrc executes a command (I think there's... 4 of them?), it redoes the mdns lookup, so each command is slloooooooow. I ended up just telling it to ssh to the self-assigned IP that the roborio gives itself, and then it was back to normal speed.
Unread 13-03-2016, 12:56
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
We have a gyro and an IP camera but we've had both since day 1
probably. After this event I absolutely hate mDNS. Switching to static IP at unbag time
Unread 13-03-2016, 22:51
virtuald's Avatar
RobotPy Guy
Still have issues today? I would be interested in finding out more about it. No issues here.
Unread 14-03-2016, 22:09
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Heh, I'm afraid that the team will no longer be using Python after last weekend's competition (not my decision). Hopefully (not hopefully?) another team has this same issue and will be able to shed some light on it.
Unread 17-04-2016, 12:43
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
So we switched back to Python and this time it didnt seem to get progressively longer, but it just seemed to take a generally long time. When we were using Java there was maybe 1-2 seconds between the robot code LED turning on and off and with Python there is a good 10 seconds. Any thought?
Unread 17-04-2016, 13:18
virtuald's Avatar
RobotPy Guy
My expectation is about 5-10 seconds. I haven't looked too deeply into this, but I believe it's because there's a lot of wpilib .py files that all have to be loaded, regardless of whether you use them or not. Loading the HAL ctypes wrappers is a lot of annoying overhead too.
Just did this experiment:
# time python3 -c 'import wpilib'
real	0m4.450s
user	0m3.410s
sys	0m0.430s
# time python3 -c 'import hal'
real	0m2.413s
user	0m1.250s
sys	0m0.210s
I would love to see this time go down, but I suspect it would take a lot of work to do so (one idea: cythonize everything). Pull requests welcome!
Unread 17-04-2016, 13:40
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Is it possible to preload these libraries outside of user code? It wouldn't help rio boot up time at all but it would minimize time between deploys
Unread 17-04-2016, 13:45
virtuald's Avatar
RobotPy Guy
Python does support the reload() builtin, so in theory one could auto-reload code on demand. pyfrc's deploy even has an --inplace option that doesn't delete the existing code, so that the yeti framework can do this sort of thing. Would require some deep magic integration somewhere to make it more general.
Most of the time, the real answer is use ntproperty so that you have easy to use tunables, instead of redeploying code.
Unread 17-04-2016, 13:50
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
I'm never relying on nettables for anything again after Kettering..
If the pyfrc libraries were compiled before being uploaded to the RIO (if they aren't already), would that make it significantly faster?
Unread 17-04-2016, 13:56
virtuald's Avatar
RobotPy Guy
As long as it connects (which we fixed by switching to static IPs), neither of my teams have had NetworkTables issues on the field that weren't of their own doing.
Go look at /usr/local/lib/python3.5/site-packages/wpilib/__pycache__
Unread 18-04-2016, 09:46
vScourge's Avatar
vScourge vScourge is offline
Videogame Developer
AKA: Adam Pletcher
FRC #4096 (Ctrl-Z)
vScourge is on a distinguished road
Bytecode-compiled .pyc files are primarily to reduce file size, and only help where disk I/O is the bottleneck. If that's the case here then it may help but I wouldn't expect the difference to be dramatic.
Anecdotally, our robotpy deploy times dropped by at least a couple seconds once we switched our RoboRio to static IP and used that IP (not the hostname) to deploy. I would also second Dustin's advice on using tunables when practical, and just avoid redeploying for every tweak.
Although coming from using LabView in previous years our team still finds the robotpy deploy times to be a vast improvement.
