Go to Post If the world was like ChiefDelphi, people would be more eager to help out, offer advice and encourage each other to better things... not a bad world, that. - MissInformation [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
  #31   Spotlight this post!
Unread 18-04-2016, 10:16
Re: Is FRC giving high CG robots a free pass on defense?
Marc,
So we are all on the same page here, can you tell us exactly what rule for which the red card was given to your team?
  #32   Spotlight this post!
Unread 18-04-2016, 10:32
tig567899's Avatar
tig567899 tig567899 is offline
FRC #6070 (Gryphon Machine)
Rookie Year: 2016
tig567899 is an unknown quantity at this point
Being one of the drive coaches for a defensive robot, I think the OP is somewhat justified. In the regional we went to, thank goodness we didn't deal with tipsy robots, but I can imagine the case where playing normal defense results in a tip.
Just like a lot of people on Chief Delphi have said, just because you have a robot that tends to fall over doesn't mean I suddenly have to avoid you. Similarily, just because your robot has the tendency to collapse upon contact doesn't mean it's my responsibility to not touch you.
  #33   Spotlight this post!
Unread 18-04-2016, 10:50
Lij2015's Avatar
Lij2015 Lij2015 is offline
I like turtles
AKA: Elijah Steele
FRC #2363 (Triple Helix)
Lij2015 has a spectacular aura aboutLij2015 has a spectacular aura about
Send a message via MSN to Lij2015
As someone who not only has driver experience playing defense but has actually flipped a few robots that were playing defense on me in a quite aggressive manner, I find it crazy I never got a red card called on me based on the rules this year. I have straight up run into defensive bots twice to my recent knowledge at full speed (once in 2013 and once in 2014) and caused them to tip because they were in my way.
I do think that this game is penalizing playing defense on High CG robots, however when the point potential that an alliance loses because of a tipped robot is SO high (30 points as mentioned before) I honestly don't know what else can be done.
If I were reffing however based on this video alone, I absolutely wouldn't have given that a red. Maybe a yellow, but that's a pretty weak nudge on your part.
Alumni turned volunteer!
2016 Chesapeake District volunteer, Scorekeeper/Game announcer.
Team 2363 Proud Alumni, Programmer/Driver 2013, 2014, 2015(Captain)
2016 Northern Virginia Winners (1418 and 2421)
2016 Hampton Roads Finalists(1885 and 5954)
2015 Chesapeake Regional Winners(1690 and 4050)
2015 Virginia Regional Winners(384 and 1610)
2014 Chesapeake Regional Winners(1629 and 623)
2013 Virginia Regional Finalists (3015 and 2053)
  #34   Spotlight this post!
Unread 18-04-2016, 11:30
maxnz's Avatar
maxnz maxnz is offline
Can't wait for next season!
AKA: Max Narvaez
FRC #2855 (BEASTBot)
Team Role: Student
Rookie Year: 2016
maxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of light
Here are a couple of ideas:
1. A robot that tips another robot is given a card that is in between a yellow and a red card. An orange card, maybe. That card disqualifies the team for their next match, but not for the rest of quals or elims. (Yes, this doesn't cover matches at the end of quals and elims, that would need to be clarified)
2. The offending robot is disabled, making it so that the alliance that the robot is a part of cannot get a capture either, negating the effect of the opposing alliance only having two mobile robots and thus losing the potential 30 pts from a capture.
As a senior that will be leaving the team, I have to teach others how to:
1. Know the manual extremely well
2. Wire the robot
3. Organize the shop
4. Help people find parts when they need them
5. Find parts to order and give the detailed list to the coach in charge of buying the parts
6. Keep track of team updates, Q & A responses and FIRST blog posts
7. Be active on CD
8. Plan and execute drive team strategy
And more that won't fit on this list...
  #35   Spotlight this post!
Unread 18-04-2016, 11:32
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Originally Posted by BrennanB View Post
Then suggest a viable refinement?
Clearly this is a very delicate road to navigate, but perhaps there is a "fair" solution. What if instead of a red card, the ref e-stops the offending robot (possibly plus a yellow card). This way the 30pnt swing is negated and a clear message is sent that this is not gracious behavior.
I do think even this penalty needs to be reserved for clear intended tipping. High CG robots are clearly a bad team decision for this game and the team needs to own that. If contact is bumper to bumper, I would assume the intent was to block, not to tip - a "prolonged push" is a gray topic.
  #36   Spotlight this post!
Unread 18-04-2016, 11:40
EmileH's Avatar
EmileH EmileH is offline
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (PVC Pirates) & FF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Disqualification, by the Game Manual rules, means that the team scores 0 RP in that match (or if in elims, the entire alliance gets 0 points and automatically loses). It does not affect other matches outside of the yellow card that is also given to that team/alliance.
2016-present: High School Student, FRC 1058 PVC Pirates
2016: RiverRage 20 Champions, Battle of the Bay 3 Champions
2013-2015: Middle School Student, FRC 3467 Windham Windup
  #37   Spotlight this post!
Unread 18-04-2016, 11:49
Dezion's Avatar
Dezion Dezion is offline
Coach | Strategy Co-Lead | Raawr!
FRC #4935 (T-Rex)
Rookie Year: 2015
Dezion is an unknown quantity at this point
Originally Posted by gp2013 View Post
I think you are oversimplifying. FIRST specifically addresses strategies aimed at damaging a robot. Nothing in the rule book indicates what should happen when two robots engaged in offensive/defensive interactions result in one robot accidentally tipping. What do you do when a defensive robot drives up onto another robots bumpers behind a sally door or drawbridge and ends up tipped?
I completely agree. The rule book also does not address what happens if you accidentally flip a teammate with a high CG over (which I have seen occur). I would hope no team attempted to intentionally flip over another robot, but it is not something that can be completed avoided.
Yes, being tipped almost prevents your alliance from winning (especially in eliminations). However, is it not a strategic decision to play defense? Shouldn't a team understand that they have the potential of losing a match by being tipped because they played defense?
I'm not stating that the rule is perfect how it is either. I'm stating the game manual, which should be used to consider strategic options, such as defense.
  #38   Spotlight this post!
Unread 18-04-2016, 11:57
maxnz's Avatar
AKA: Max Narvaez
Team Role: Student
Rookie Year: 2016
In my example, disqualified would have a slightly different meaning. There may be a better word for it. The example would have the robot unable to play in their next match (the specific FRC definition says that disqualified is a status, not specifically saying when they are dq'd, other than implying that it is for the current match). In elims, it would probably be changed to something similar to the robot being bypassed, thus not hurting the whole alliance as harshly.
I personally think that the second idea probably would work better.
2. Wire the robot
7. Be active on CD
  #39   Spotlight this post!
Unread 18-04-2016, 12:14
interpretTHIS interpretTHIS is offline
interpretTHIS will become famous soon enoughinterpretTHIS will become famous soon enough
It bothers me that nobody has posted or attempted to dissect the actual rule:
Originally Posted by G24
Strategies aimed at the destruction or inhibition of ROBOTS via attachment, damage, tipping,
entanglements, or deliberately putting a BOULDER on an opponent’s ROBOT are not allowed.
Violation: FOUL and YELLOW CARD. If harm or incapacitation occurs as a result of the strategy,
RED CARD
In this particular case, the actions of one robot led to another robot being tipped. The head referee determined that those actions were part of the strategy that the offending team was playing (presumably defense.) Whether or not this determination was correct is a different matter (head referees are humans and need to make decisions,) but by the letter of the rule, the head referee is certainly in their realm to make this determination.
As a side note, other reasonably astute observers made the same determination as the head referee. In the seconds leading up to the tip in this case, the GA said "But 3548 is just really playing the hardest D," which gives clear indication of the strategy that that observer believed the team was playing. The resulting action of that strategy, "the tipping", is what resulted in an invocation of G24. Now we follow the sentencing through: FOUL and Yellow, but incapacitation occurred, so Red.
Interpreting this makes the call seem feasible.
  #40   Spotlight this post!
Unread 18-04-2016, 12:22
BotDesigner's Avatar
BotDesigner BotDesigner is offline
Design/CAD/Strategy/TeamManagement
AKA: David Gedney
FRC #4418 (Team Impulse)
BotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud of
I am curious about how to define "harm or incapitation". When would a yellow card ever be called because of a flip when a flip always results in incapitation?
  #41   Spotlight this post!
Unread 18-04-2016, 12:24
Chris is me's Avatar
AKA: Pinecone
"Defense" does not meet the definition of the quote above - it does not inhibit a robot through any of those methods, normally. It is only a "strategy" if the tipping is an intentional part of the defense. Under your logic, literally any time a robot tips over when someone is playing defense on that robot would result in a Red Card. Lots of teams would build robots very differently if that was the case!
  #42   Spotlight this post!
Unread 18-04-2016, 12:29
AdamHeard's Avatar
Lead Mentor
Sounds like an excellent chokehold strategy.
  #43   Spotlight this post!
Unread 18-04-2016, 12:34
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
I personally am more upset at the inconsistency of these calls.
I mean waterloo qf1-1 we were in a pushing match that resulted in our opponent getting underneath our bumpers and then driving us from the secret passage to the front of the tower (defense 3) before we finally flipped (we are 13" high and have been almost vertical on the field wall without flipping) and that was not given any card at all.
I'm fine with that decision on its own, but its upsetting to compare that decision to the one shown in the OP video. That was a clear bump and retreat defense on a tall, tippy robot, in a tall, tippy position.
The comparison between the two calls is the thing that is the most frustrating. Either call on there own is fine.
As long as its called consistently then there is no problem. The issue is that it is not being called like that.
  #44   Spotlight this post!
Unread 18-04-2016, 13:01
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Al,
I am not sure what rule was called against FRC3548. I was busy picking up the laptop and joysticks when I saw the red card in front of the driver station. I will ask the driver tonight whether or not he remembers what call was given. I do assume G24.
RED CARD
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
  #45   Spotlight this post!
Unread 18-04-2016, 13:12
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Regarding tipping....
Intent has to be there... if a robot starts to tip another bot but backs off then no harm or foul. If instead they tip and "follow through" to actually tip then a foul will be called most likely.
As for "incapacitate or harm" if a bot gets tipped and rights itself then neither of these have been met... first they were not incapacitated "action of righting self" nor "harmed".... now if the intent "on purpose" tip occurs and the bot could not right itself (effectively taking that bot out) then I can see the "incapacitate" coming into play. Harm if something broke may come into play as well.
As for High CoG...that is a design choice and has no bearing on the calling of a foul its crazy to think FRC would have a High CG rule..that is tin hat stuff. They would never institute that as refs would not follow it if not in game rules.
As for bots playing Defense...yes the fouls are stacked against your favor. By design. No one told you to play defense in the first place. Your risk/reward decision.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
[IMG] code is Off
