Go to Post So we developed AI... it figured out the clue... already... made itself accordingly... and is currently walking to the peachtree regional if you find him ask him what the objectives are, we'd sure like to know! - Collmandoman [more]
Unread 17-04-2016, 07:43
epylko epylko is offline
Mentor!
AKA: Eric Pylko
FRC #3181 (Pittsford Panthers)
Rookie Year: 1970
epylko is an unknown quantity at this point
Re: ethernet cable type
Also, if you're making your own cables, make sure you have the wires in the correct order. Follow the order specified in TIA568-A or -B. Pick one of those standards and stick with it. A crossover cable is really 568-A on one side and 568-B on the other.
Finally, make sure you have a cable tester if you are making your own. Bad crimps and kinked cable can cause all sorts of intermittent, maddening problems.
Unread 18-04-2016, 12:35
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
A cable tester is probably a good investment even if you don't make your own cables, especially for the kind of "mission critical" environment our cables will often see.
If you don't have a crimper to make/fix cables, then plan to keep a few spares, and if a cable starts acting up (and you can confirm the cable is bad), toss it in the garbage.
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
Unread 18-04-2016, 18:57
Brutick's Avatar
Brutick Brutick is offline
E/M/P Mentor
AKA: Brandon Jutras
FRC #1360 (Orbit Robotics)
Brutick is an unknown quantity at this point
Thumbs up Re: ethernet cable type
I'd recommend getting a cable tester and a bunch of LONG (50ft+) pre-made ethernet cables from Monoprice. Moulded cables, in my experience, last significantly longer than any cable I've made myself, especially given the abuse they receive from a team.
